Car: 08 535i
Default First logs from a ST set up - 06-24-2020, 06:55 AM
Hey all, here is a log from an on3 single set up. Mods are...
-On3 kit w/on3 tubo
-44mvr with 11.6psi spring
-gplus intercooler w/oem ends
-vrsf cp/hks
-stock fuel
-stock tmap
This is a log in map2. I am new to the jb4 but set all the dutybias to 50, the FF to 20, & WDP to 75...I am hitting just under 14lbs on map 2. I thought map 2 was 17psi, do I have to change the FF to get more boost or do I have a boost leak? Map 1 hit WG spring pressure @11.6 just fine very consistantly.
Lmk what I can do to better to dial it in. Any help is appreciated.
