importroller importroller is offline
Car: 2016 Q50 3.0t
Default Boost target question - 05-07-2020, 09:52 PM
I posted a question on FB, but since I'm running jb4, I think this is a better venue.
With a jb4, with FW and WG connectors, bms x, ldp and cbe. With this setup, what is the highest psi I should set to not blow the turbos? I'm in Cali, so we don't have 93. So usually running 91 and occasionally 91/e85 mix?
jrobohm's Avatar
jrobohm jrobohm is offline
Default 05-08-2020, 12:56 PM
For a non-red sport VR30 and 91 octane fuel - start with Map 1, log, and submit to the forum for review. If all looks good, move up to Map 2 and repeat. There is no golden rule in how much boost psi your car can handle for a given fuel and all of the other variables. Logging is the only way to know how your car is doing and be safe with adding more boost.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS WMI w/ PM8’s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • AMS CAI
  • Fast Intentions Res. Touring 2.5” CBE
  • Mishimoto Oil Catch Can
