Car: 2008 BMW 335i coupe
Log review please - Misfire, vacuum leak, boost solenoid?? -
11-09-2019, 01:21 AM
Can someone please help me?
Currently running map 5. I at wot keeps jerking then at higher RPMs pulls hard.
Idle is really bad keeps jumping.
Just replaced Vanos solenoids & vacuum hoses.
Replaced coils and spark plugs in August.
Can someone please point me in the right direction please?
2008 E92 335i coupe
JB4 G5
MHD BEF on Pump tune
5" Arm motorsports FMIC
Arm motorsports CP/D P
50mm Tail BOV
VRSF relocated inlets
Muffler delete
Car: 07 E90 335i
11-09-2019, 10:05 AM
Logs are done in 3rd gear 2k to redline traction off
enable 6cyl timing logging - without this enabled you wont be able to see what all the other cylinders are doing only cyl 1
what type of fuel are you running?
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
11-09-2019, 11:34 AM
Thanks so much for the reply. I am so new at this my bad I'll post a log today and see what you can see.
I am running 91 octane at the moment.
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
11-09-2019, 02:11 PM
Throw up some better logs
11-09-2019, 05:57 PM
Ok guys got some better pulls today with 6 cyl enabled.
Running map 5 with 91 octane.
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
11-09-2019, 08:30 PM
Just checked my JB4 settings. Everything is on default numbers except FF/Wastegate Adaptation.
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
Car: 07 E90 335i
11-10-2019, 09:04 AM
Looks like you are targeting stock boost 8 psi
Your oil temp at minimum needs to be at 160 - could be why you are only targeting 8 psi
JB4 locks you out until then - built in safety
Drive around till oil is up pass 160 (hazards should flash notifying you it’s ready) and try doing some logs again
07 E90 AT - xHP
FBO
Hybrids
11-10-2019, 12:08 PM
Nice!! Thank you!!
I'll make sure to get the temp over 160. I was wondering about the blinking lights on that.
And I think I may have little problem I've been having with rough idle and power loss 🙏🏻
Turns out I don't have the O-ring for my Tial BOV
I go back home in a couple of days (out in oilfield) so it's the first thing I'll do.
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
11-10-2019, 02:51 PM
Manually lower your FF as well to 70-80
11-10-2019, 02:55 PM
Thank you I'll make the change right now for the FF manually.
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
Car: 07 E90 335i
11-11-2019, 08:02 AM
OE couplers on the aftermarket Intercooler are known leak points check those as well if after you install the o ring on the BOV doesn’t completely fix your issue
07 E90 AT - xHP
FBO
Hybrids
11-11-2019, 01:00 PM
I'll make sure to double check on the couplers if it continues 🙌🏻
Can't wait to get home and do this! I'm literally in the middle of nowhere with no auto parts store or anything close by.
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
11-11-2019, 02:53 PM
Car: 08 E60 535i
Might be able to help -
11-11-2019, 06:54 PM
Originally Posted by lucky_335i
Nice!! Thank you!!
Hey Lucky. You mentioned that your stuck in the oil fields for a few days working. You wouldn't happen to mean Western North Dakota would you? If so, I may be able to help a bit. If that's where you're at, I'll be in Williston this Tues and Weds visiting family. I wouldn't mind at all helping out and bringing my N54 specific boost test set-up (hot and cold side). I can just throw my small compressor in my car before I leave tomorrow morning. Takes 2 minutes from the time you pop the hood.
I also have a brand new extra TIAL BOV O-ring (Factory new, never used, brown colored one that comes with the valve). Bought it as an extra when I bought the BOV but after installing it I see no way it'll ever just "go bad" so if it helps you can have it. The missing O-ring will cause a boost leak if you don't have one in the car now, but it wont affect vacuum loss as it's on the charge side of the BOV, vacuum only pulls from the upper section on the BOV specifically the top side of the piston inside. You may still have a vacuum leak elsewhere of course. What lines have you changed so far? Testing your idle vacuum with a gauge is the easiest way to see the leak, finding it can take a bit of poking around but easily narrowed down.
If your building target boost with the o-ring missing, that would say to me that your boost solenoids are working. If they weren't functioning and you had a big boost leak as well, you def wouldn't build any boost close to your target.
As far as your logs go Dave and Haynpunch, who've already been responding in this thread, will get you squared away for sure by looking at your logs. I haven't seen them but I'll look. I can only point out the obvious though, no expert here.
Let me know. Get this thing on the road and melting tires fast as possible!!
Brandon
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
[/SIGPIC]
11-14-2019, 10:05 AM
Thanks so much for the offer Brandon I really appreciate it 🙏🏻 I work out in Pecos TX.
Here's an update:
Installed BOV O-ring
RB PCV valve upgrade
NGK 95770 spark plugs installed gapped .022
Running 3 gallons of E85 with 91 octane
When I first replaced the PCV valve and installed O-ring made no big difference.
But once I replaced the OEM spark plugs it changed the car completely. Smooth idle but every now and then it still shudders at stand still.
As for the vaccum hoses replaced, I replaced all lines going to turbos, bypassed canisters for now a nipple broke off, lines above valve cover.
I did 2 pulls after changes have been made. The boost did go up almost double.
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
11-14-2019, 12:47 PM
You arent using the BEF correct?
I'd start- that'll help with the trim issue & the small amount of e85
11-14-2019, 03:07 PM
I'm gonna try to get the BEF done tomorrow via MHD. I already have everything ready just need to get me a battery charger and I'm set.
As soon as it's done I'll post up some more logs to see how we stand.
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
Car: 08 E60 535i
11-14-2019, 04:57 PM
Here's an update:
You bet, anytime.
I had one of the nipples break on the canisters as well and have had it replaced since. However, during that time I had to "tee" both the incoming vac lines into the remaining good canister (lines running under the valve cover from the vac pump). I noticed running the line and skipping the canister directly into the boost solenoid worked, but it can quickly (as in less than 1 second) tax the available vacuum in the line without a volume buffer (canister). It would work for a second then bleed off so quick the solenoid would close even though it was getting the signal to stay open, at least partially. Caused what I thought were boost leaks (surging, etc) and I was chasing my tail. So get that fixed soon!!
Hope the BEF works well for you. I tried the PUMP BEF and had strange problems. Loaded the Race BEF flash and it's been running good, even on only 92 octane, no Ethanol, etc.
Brandon
Hayden, Idaho.
[/SIGPIC]
Car: 07 E90 335i
11-14-2019, 07:39 PM
15 Min metal vaccum canister DIY
One of my canisters nipple broke and I basically did what this guy did but I only had to replace one nipple so for looks I flipped the canister upside down so the replaced metal nipple doesn't show. also did a vac test and no leaks. pretty simple to do instead of buying new ones
07 E90 AT - xHP
FBO
Hybrids
02-23-2020, 10:25 AM
Hey guys! Super late reply on the issue I had before with the rough idle and stalling.
Decided to go with am experienced BMW tech to see what the heck I was having this issue.
We ended up swapping throttle body, double checked for vacuum leaks and valve cover leaks.
After 3 hours of taking the car apart I mentioned that I swapped the sensor on the intake manifold with a OEM TMAP. Finally swapped out that sensor with one he had from another n54 and problem solved. *♂️*♂️
Idles great and just needs a little adjustments here and there that I'm working on but this whole time I had gotten a defective TMAP sensor
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
Car: 2008 E93
02-23-2020, 11:17 AM
Is it possible the sensor is good and you used the wrong part ?
You said tmap that you replaced on intake was no good out of the box.
Tmap goes on chargepipe. MAP sensor is on intake manifold.
02-23-2020, 11:21 AM
I made sure it was the sensor that went on the manifold. But you may be right. I was completely new to the n54 when I ordered the the first bolt-ons.
I'm just glad it's running great now
2008 E92 335i coupe
JB4 G5
50mm Tail BOV
Muffler delete
Car: 2008 E93
02-23-2020, 12:06 PM
I'm just glad it's running great now ��
At the end of the day, thats all that matters !
