inline6xi inline6xi is offline
Car: 2008 bmw 535xi
Default 01-25-2020, 06:01 PM
Went to my dealer today and they told me that they couldnt look up the service bulletin, and my BMW had no outstanding recalls. June '08 build, E60 N54.
hopefully its not in the system, but lots of speculation. Its shocking to hear they are doing recalls on 12-13 year old cars.
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 01-25-2020, 06:20 PM
Where is your dealer? Iím in Kansas City and my dealer confirmed the service bulletin but like you it says my car 9/6/08 build has no outstanding recalls. They are calling BMW to find out why since it falls into the dates of the service bulletin. The service advisor says it should especially since it didnít have the injectors replaced on the previous recall.
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5Ē RACE FMIC
VRSF DPís - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - PFS STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
MISHIMOTO 15 ROW TRANSMISSION COOLER
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
Car: 2008 bmw 535xi
Default 01-25-2020, 07:18 PM
Sounds promising for you, and thats encouraging that you actually have confirmation from BMW that all this hype about the new bulletin existing is real. My dealer is located in central CA.
Let me know what they say when they talk to BMW.
Side note- I checked my injectors and I've got four index 8s, a 7 and a 9.......
Rule77's Avatar
Car: 08 E90 335i
Default 01-25-2020, 08:06 PM
I will definitely keep you posted.
Imaaronnn Imaaronnn is offline
Default 01-27-2020, 09:18 AM
Just made my appoint for 2013 335is n54 took less than 5 minutes this recall is true.
Rule77's Avatar
Car: 08 E90 335i
Default 01-27-2020, 09:22 AM
Howís that? 4/1/07 to 11/30/2008 build dates.
Default 01-27-2020, 09:25 AM
i have no clue i called them and they said my car is eligible i have a 2013 n54
so i think its all n54s
codesx's Avatar
codesx codesx is offline
Default 01-27-2020, 10:57 AM
I'd need to see more like this to believe. I suspect SA error. I'm wrong enough though.
The Recall only exists because these old Injectors leak fuel while sitting, which largely doesn't get burned and is pushed out the *****. At scale, this is seriously hard on the environment, so I'm glad BMW was pushed hard enough that they had to do the right thing.
They certainly aren't helping because an old part failed.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Neckbeard Neckbeard is offline
Car: 2008 135i Manual
Default 01-27-2020, 12:11 PM
Another update. Possibly. Here's what my Friend at BMW sent me. It seems they added a clarification of recall document.
tks535i tks535i is offline
Car: 08 535i 6spd
Default 01-27-2020, 01:23 PM
How does it work for getting recall work done with modifications? I read I need to disable my JB4, what do I do about MHD back end flash?
Dayton, Ohio
2008 E60 535i 6speed Sport Suspension
JB4, MHD BEF, DCI, D0wnp1pes, 7" VRSF FMIC, CP and BOV, H20/Meth Injection, Stage 2 LPFP, OCC
BettyWhite6six6 BettyWhite6six6 is offline
Default 01-27-2020, 06:14 PM
Called up portland bmw and no recalls open for my vehicle at this time. '08 with a build date 10/07 last 7 p155804
I'll go talk to the parts manager Friday and see if I can get some info out of him ���� car is still being built anyway. Would be nice to come up on some new injectors aswell huh lol!
Makes me wonder what injectors I have!?
'08 e92 white/coral red
Aka ketchup and mayo
VRSF cp/Tial wg, VRSF d p ' s, mhd flashed
Vrsf 7" stepped intercooler, PR coilpacks
Spoolperformance stage 3 lpfp dual 450 fuel pumps
Spoolperformance x4 helix overdrive hpfp (beta testing)
ProMeth water/meth port injection w/7th injector in cp
MMP stage 3 v2 td04's
MMP silicone outlet relocation wrapped in gold for her pleasure
MMP aluminum inlets/cones
Radium oil catch can, N20 3.5 bar map sensor
Car: 2008 bmw 535xi
Default 01-28-2020, 01:07 PM
Hey guys, I talked to a competent BMW enthusiast that works at BMW. The highlighted info that was posted yesterday is key. THIS IS ONLY AN UPDATE TO THE EXISTING RECALL. If you have had any warranty work done on injectors you will not be qualified for the new update.
This got super hyped up by insta and YouTube, and it's really just an update to an old bulletin from 2011.
Default 01-28-2020, 05:29 PM
Sad. I checked what index I had and turns out I have -11! Guy that own it before me was a bmw tech. Explains why there was no open recalls for my vehicle
Zoom753 Zoom753 is offline
Default Taking care on 2/5 for recall - 01-31-2020, 06:15 AM
Called local BMW dealership and was told no recall but, when I pressed and gave them the SIB #, they booked an appointment to bring care in. They called it a voluntary warrantee update. I will update the thread after the appointment on 2/5 to see if they actually replace all injectors.
2007 335i E92 MT6
2011 X5 3.5 E70 A/T
Default 01-31-2020, 09:06 AM
I called the service manager who was my old boss and he said that it wasn't covered because the injectors have already been changed. 5 of them. When the car had 9k miles. It's an 08 135i
07N54E90 07N54E90 is offline
Car: 07 BMW 335i E90
Default 02-05-2020, 05:10 PM
Any updates on this? hope this recall is a thing. Would be great for me as well since I have a production date of 5/07.
Car: 2008 bmw 535xi
Default 02-05-2020, 09:17 PM
Just a bunch of hype from social media. isnt a thing
N54_ABQ's Avatar
N54_ABQ N54_ABQ is offline
Car: 2007 BMW E92 335i
Default 02-06-2020, 08:06 AM
The recall IS a thing. Its just an updated version. It did get a lot of hype BUT it is still a real recall.
The original recall goes back to 2010 and has been updated at least twice since then.
If your vehicle has NEVER had injectors replaced and falls within the date range, the dealer will replace them if you press them hard enough.
The problem is that 90% of the vehicles within the date range have had injectors replaced by now.
There are specific injector part numbers that get replaced under the recall. Once you no longer have those part numbers the dealer will tell you you're all good and send you on your way.
There may be a few success stories coming here and there but this isn't the glory recall we were all hoping for.
2007 335i E92 6MT FBO, Stock Turbos
Car: 2008 bmw 535xi
Default 02-06-2020, 08:44 AM
Originally Posted by N54_ABQ
Tthis isn't the glory recall we were all hoping for.
It's literally nothing new bud.
N54_ABQ's Avatar
Default 02-06-2020, 09:06 AM
Uh... Yup. Its from 2010
codesx's Avatar
Default 02-06-2020, 11:05 AM
Looked at my injector numbers.
Seem to be outside of the 'faulty' ones listed, even though they have the same symptoms.
My only real hope now is that there is a 3rd revision of this recall... unlikely.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Andrey.kvotchenko Andrey.kvotchenko is offline
Car: E92 335i Sedan
Default 02-07-2020, 09:53 AM
Went to the dealer today over my lunch break and asked about SIB 13 01 20.
They know about it. As mentioned elsewhere, VINs may not be flagged yet.
It states in the defect code description "N54 US Replace piezo injectors". So yep US only...
I had them print it out for me. Here it is.
Why do they exclude Jan, feb, March models I got a 01/07 build and mine isnít under the recall very frustrating
videoaudioman videoaudioman is offline
Car: 2008 335XI
Default Injector recall - 02-10-2020, 12:29 PM
Will highly modified vehicles still be able to get the recall done?
codesx's Avatar
Default 02-10-2020, 01:06 PM
Likely more about your individual dealer and relationship.
I find they like you more if you spend there. If not... meh.
It's more about your Injector Numbers.
20% of us might fall into the build date, but it seems a small %age of that has qualifying Injector Numbers. (Not rev, but stamped number)
So, worry about the dealer after you look at your individual build numbers... (car build date, injector build number (not just rev), then work on a dealer)
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Beemermane Beemermane is offline
Default 02-11-2020, 06:10 PM
Hey everyone!
I just left my car at the dealer today!!
This is LEGIT!!!!!
Iíve made a post on e90post but hereís the content....
ďEVERYONE THIS IS REAL!!!!!
I read the entire thread on this topic along with a few other ones on other forums..... decided to call my local dealer. The SA asked for VIN but I clarified that Iíd like to also provide the SIB number that was mentioned earlier in this post. I was on hold for about 20 minutes before I was told that I need to bring it in to have it completed.
Got to the dealer. Great SA, handled everything in about 5 minutes. Getting an enterprise rental on BMW. Everything went literally super smooth!!!!Ē
ď Ok guys so to clarify a few things... BMW kept my car. Right now I am in a rental 2020 530i! The SA said it would take a few days.
Also, for those who are wondering if they qualify or not, I think Iíve figured out the criteria....
So my 335i is a 09/2007 built. Before all of this Iíve called BMW to see what recalls have been performed prior to when I bought the car. Found out that in 2011, I had 3 injectors replaced on bank 1 with index 7s. These must be on currently because on bank 2 I had a 4-4-5 index.
Basically, if you had them replaced before, it doesnít matter. If your VIN doesnít show, also doesnít matter. The idea is that if you have the correct build date and you NEVER had ALL SIX installed, then they will replace them all with index 12, along with new spark plugs.Ē
