2BIG4A3 2BIG4A3 is offline
Car: E60 535I
Default Aftermarket twins - 05-16-2020, 01:14 PM
Looking for users with 30k miles plus on their aftermarket twins.
Would like to know
Company
Housing size
Boost
Fuel
Other mods
WHP (estimates okay)
This is not supposed to be a aftermarket company bash fest so much as an attempt to see if there seems to be common denominators in aftermarket twin set ups that 'last' vs the ones that die at 10k.
Thanks.
E60 535i FBO MHD
zomski101 zomski101 is offline
Car: 2009 335i
Default 05-16-2020, 02:05 PM
Mmp stage 3
70k miles at 18-21psi, stage 2 lpfp e50 mix
15k miles at 22-26psi, stage 3 lpfp and helix 3x, motiv flex fuel, e70
Supporting mods:
Vrsf 7.5 intercooler, cp and dp
Whp idk
MMP stage 3 turbos with inlets and outlets, FBO, e50 mix tuned by Ken
Car: E60 535I
Default 05-16-2020, 03:00 PM
105k miles
That's wild.
However this does sort of fit into my theory about aftermarket twins and failures
I have always suspected that if someone sized out a pair that was significantly larger than needed, trading of some drivability and then ran those turbos well below their capacity they might actually last for a while.
As opposed to sourcing a turbo that is not sufficient for your power goals and then finding someone to squeeze that much power out of the setup anyway.
Thanks for your response.
E60 535i FBO MHD
Car: 2008 E93
Default 05-16-2020, 04:19 PM
Would like to know
Company
Housing size
Boost
Fuel
Other mods
Thanks.
Should post up your goals and ask the same question. The broad range of hybrids has been asked many times and if you search, you SHOULD find what you are looking for , for your power goals
