dmikhael619 dmikhael619 is offline
Car: 2008 e92 335i
Default 335I Crank But no Start, DME Failure? - 11-05-2019, 09:32 AM
Could use a bit of help. Car is a single turbo N54 was driving fine all day parked it at night and now it wont start, it just cranks over. It seems to me like it is a DME failure but I don't want to throw parts at it so any help would be appreciated I attached some pictures of the original fault codes that I got then I cleared them and got almost of them back. I removed the JB4 to narrow down any culprits. I originally tried to read codes through the JB4 but I could not connect and I could not access the steering wheel controls either. Only way I was able to see the codes was through the OBD port on MHD. I attached images of the error codes in the link Thank you !
Car: 2008 e92 335i
Default 11-18-2019, 11:23 AM
If anyone is interested I put a new DME in the car, put in a new engine harness, check every ground, a new JBE module. tested my relays and still no luck. Same codes. I'm pretty much done with this platform. I will be buying an F80 next weekand will be doing a full part-out of a 6mt N54 Black sapphire e92. Doc race 6266 kit makes about 730 whp has about 20k in mods done to it will be listing everything soon. Thank you to everyone in this forum who contributes!
Default 11-18-2019, 04:56 PM
I donít see any images..
F80 isnít a bad upgrade choice either
Milehighbmw Milehighbmw is offline
Car: 07 335xi
Default 11-18-2019, 07:00 PM
I'm starting over with another e92. When you get a part list with prices together let me know. Ready to purchase alot of stuff. Like I said starting over with a completely stock 335.
Car: 2008 e92 335i
Default 11-24-2019, 05:23 PM
FULL 6266 335I PARTOUT - N54Tech.com - International Turbo Racing Discussion
here you go sir! Thanks and good luck with the build
Closed Thread
