guwakjai010 guwakjai010 is offline
Car: E92 335i
Default Log Review: Fuel issue - 09-22-2019, 11:04 PM
I have two logs. One with Map 6 and this went to Map 4 for low fuel pressure, second log in map 7 which mostly is fine. Recently was able to hands on e85 so needed to dial in on some settings. Was wondering if someone can confirm if the low fuel pressure is caused by LPFP, pump is 2 years old and this is one of the first time i ran e85 on this set up. Not sure if the PI is too aggressive in spraying or the LPFP can't keep up.
Fuel is half e85 and half 93
Relevant Mods:
Pure stage 2 DD
MMP PI
JB4 latest firmware
backend flash via MHD latest flash
Fuel It stage 2 inbucket pump
MMP aluminum inlets
VTT outlets
VRSF 7in Intercooler
VRSF **
N20 Map
Car: 2008 E93
Default 09-23-2019, 01:01 AM
I would run a stage 3 lpfp.
Default 09-23-2019, 06:18 AM
Could upgrade LPFP or try lowering ethanol to e40
Car: E92 335i
Default 09-25-2019, 04:02 PM
found a crack on the sending unit of the gas tank. not sure how deep or close to the actual feed line portion. I'm hoping this might be the main contributor for low FP. even idle i see around 52PSI.
Default 09-26-2019, 12:21 AM
Fingers crossed!
