Manjot Manjot is offline
Car: 2008 535i 6speed
Default 535i wonít read boost correctly - 09-20-2019, 06:37 PM
Late this March I picked up a 08í 535i Msport and have slowly worked out all the issues the car had. But I have one last issue I just canít figure out. Looking at the logs the car wonít recognize boost as my Aem gauge shows around 18 psi but the car fails to read anything above 11psi. Iíve replaced the boost pressure sensor and the map sensor. Also put in a vtto upgraded pcv valve. The car does have Bms dual cones with vrsf ********* and charge pipe with a synapse bov and stage 2 mhd map
Default 09-21-2019, 02:48 PM
The car does have wastegate rattle but why would the boost gauge be reading 18psi and I’ve tried multiple gauges
Default 09-23-2019, 11:16 AM
Logs?
Default 09-23-2019, 02:05 PM
You'd need some JB4 logs for us to evaluate.
Are you using JB4, or MHD / flash only?
Default 09-23-2019, 08:06 PM
I did buy a jb4 have not installed it as was waiting till the car was 100%. Iím guessing Mhd logs wonít help. But the simplest way for me to explain is the cars hitting and much boost the wastegates can hold proven by the boost gauge and how the car starts to lean out. But the dme does not see the boost. The car isnít throwing any check engine lights and I have replaced both sensors
Default 09-23-2019, 10:53 PM
Could be hardware or tube related
When you get the JB4 installed - if there’s still a problem we’d be happy to assist
Default 09-23-2019, 10:59 PM
When you get the JB4 installed - if thereís still a problem weíd be happy to assist
Alrighty I will update you
Default 09-24-2019, 07:37 AM
