zaidsparrow zaidsparrow is offline
Car: Bmw 435i
Exclamation charge air temperature!!! Need advice - 09-05-2018, 08:59 AM
Hello all,,
Guys I have 435i 2015 xdrive,
It have this Modification list below
Pure turbo stage2
Methanol burger tuning
Intake
Cooler
Charge pipe
Down pipe
Diverter
Plugs NGK 0.020
Map sensor 3.5
Jb4 n55 f serious
Car is tuned throw MHD stage 2 plus and have custom flashed throw pureboost.com
I have code after every push i made and till today cannot find where the issuse from
108A10 charge air temperature sensor, electrical: Signal implausible
120408 Reduced power mode
Jb4 system adjustment map sensor n20 tmap is 1
MHD 3.5 bar opetion if i write it the car will turn off it self,
As I say to you guys the code comes after every push
Check last log file attached
Default 09-05-2018, 12:04 PM
Have you tried a new sensor?
Car: Bmw 435i
Default 09-05-2018, 12:09 PM
Yes I did , i have 3 new map sensor 3.5 bar and same code it’s giving
Default 09-05-2018, 03:08 PM
Hmm, could be Jb4 harness or board then. Have you tried pulling the JB4 and see if the code comes up?
Car: Bmw 435i
Default 09-06-2018, 03:09 AM
Yes bro i just tried it, and same code its still coming,
Do you think its from IAT tempreture is high ,
Check in log file
Default 09-06-2018, 11:06 AM
It is very hot actually, have you looked into a methanol kit?
Car: Bmw 435i
Default 09-06-2018, 01:26 PM
I got one issue in the methanol kil,,
The Solenoid is leaking air inside the pipe which going from Solenoid to charge pipe only,
So I tried to switch off the meth and I give it push 6 times and there was no codes, I tried to push the car in map 0 1 2 3 4 with no meth and there was no codes and i switch on the meth in all maps was all with codes
Whatdo you think bro! Is it from the Solenoid!
Default 09-06-2018, 04:00 PM
Have you tried to pull the solenoid and run without it? Might need a new solenoid.
Grab one here on this page:
http://www.burgertuning.com/meth.html
Car: Bmw 435i
Default 09-13-2018, 08:10 AM
Hello,
I got a new solenoid and i got same code, i try to pull car and take black cable From the Pressure pump and the car start cutting down and move to map4 and I pull it on map zero and it takes me to map 4 too,,
I checked all cables but can’t find any mistakes on the cabling,,
M-terkait's Avatar
M-terkait M-terkait is offline
M-Terkait
Car: F30 335i
Default 09-13-2018, 12:39 PM
Hello all,,
You must select only one of these either JB4 N20 sensor enabled or MHD 3.5bar option.
N55 - Doc race 6266.
Car: Bmw 435i
Default 09-14-2018, 04:08 PM
It is only in JB4 chosen, its giving me the code if the meth goes to charge pipe after I finish my push , so we are trying to solve it but with no idea what the mistake is,,
Drag_n54's Avatar
Drag_n54 Drag_n54 is offline
Car: '09 BMW 335i
Default 10-04-2018, 03:05 AM
Did you figured out what's causing the codes? I decided to give straight mhd flash a try. I completely removed jb4 and I get just those 2 codes as soon as I turn the ignition on (without starting the car). I also have a meth kit but it works with no issues and there are no codes with jb4 w/bef
F30 335i PWG AT l MHD Stage 2+ E30 l WMI l VRSF D.P l VRSF FMIC l VRSF C.P l FTP Outlet l FTP Inlet l GFB DV+ l OCC l NGK 97506 .020 l Stage 2 LPFP l Resonator Delete w/ Stock Muffler
