tim421gg tim421gg is offline
Car: 2009 335i coupe
Default N54 oil pan gasket question - 02-08-2018, 07:40 PM
when installing the new oil pan gasket do i NEED to use glycerin? I saw in a DIY a guy recommended using it, Im not sure if it is essential, or even what it does. if someone could explain further thatd be great
Boland01's Avatar
Boland01 Boland01 is offline
Car: 535ix
Default 02-09-2018, 07:33 AM
I'm not sure what you would use glycerin for. When I did mine I just dropped the sub frame and had to move a couple other things around to do it.
Default 02-09-2018, 11:07 AM
did you use any gasket sealant or anything of that sort? or did you just put a new dry gasket back in?
Boland01's Avatar
Car: 535ix
Default 02-10-2018, 07:03 AM
I just put the new dry gasket back in. Make sure you torque the bolts in the right sequence and correct spec. They are one time aluminum bolts so I would NOT reuse the old ones.
Gnasty Gnasty is offline
Car: 2008 335 coule
Default 02-10-2018, 07:17 AM
Did you remove the subframe completely, or just drop it down to gain access?
Default 02-10-2018, 03:27 PM
I dropped it completely since im doing turbos at the same times, personally makes it so much easier
Car: 2008 335 coule
Default 02-10-2018, 06:39 PM
Thank you!
N54QC N54QC is offline
Car: 07 BMW 335i
Default 02-10-2018, 09:03 PM
I just dropped my subframe down and did it. I just used some permatex hi-tac to hold The gasket in place. 20k miles and no sign of leaks.
748adam 748adam is offline
Default 02-11-2018, 02:29 PM
Did mine rod a long with turbo oil feeds and drains, dropped the subframe down and had moree than enough room to remove the sump. Didn’t use at sealers just bolted up dry
Car: 2008 335 coule
Default 02-14-2018, 06:01 PM
Thanks for the info guys.
