Car: 2007 335i
Inside pics of a N54 PCV system -
07-10-2014, 11:52 PM
I decided to replace valve cover so I cut apart old one to see how clogged/dirty PCV was and all I can say is wow! It was clogged in a lot of areas and can see how it would clog easily.
My car specs cover came off
1. 135,000 miles
2. valve cover gasket replaced once
3. always premium gas
4. Motul oil changed every 4,000 miles.
5. Extremely well maintained
Car: 335is DCT
07-11-2014, 02:15 AM
Very cool
07-11-2014, 05:49 AM
Oh wow. I think you have discovered another important preventative maintenence item that we need to watch out for! Is this something that can be cleaned or something that just should be replaced?
Current: 2008 e92 335i coupe.
07-11-2014, 06:12 AM
Rob I admire you for all those DIYs. You do keep that N54 engine looking beautiful. Thank you for the info!!!
 2008 e93 MODS: BMS JB4 G5 ISO, bms trunk, RB PVC, Lukeperformance flash, mount meth kit, OCC, ******* ********, VRSF 7" FMIC, charge pipe, DCI, Alpina flash,
Car: 2007 BMW E90 335i
07-11-2014, 07:07 AM
How easy is it to clean the ports in the valve cover?
Probably being sarcastic
Car: e46 323i & e90 335i
07-11-2014, 07:13 AM
Did you notice any hairline cracks in your valvecover? I did mine just before 100k and had a few cracks it seemed developing on it. Plastic valve covers are always a good idea to change out, its just buying those little bolts that KILLS you
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar dp's SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
Car: 2007 335i
07-11-2014, 10:34 AM
no way to access this, has to be replaced. Clogged PCV can cause a ton if issues....crank case pressure, issues with turbos ect.
Car: 135 I N54
Rob Amazing your topics!! I follow your DIY to change my RB Turbos.
Wich Motul do you use? I use xcess 5-40...
135I - 6 MT -JB4 G5 ISO Map 3 - BB Race Flash - Riss Rasing ******* DP - AFE CAIs - BMS SDL - 93 Octanes - Sistem X wather meth - SPEC 2+ - RB Twins!!
Car: 2007 335i
07-11-2014, 10:36 AM
Valve cover comes with bolts and gasket from BMW.
Car: 2007 335i
07-11-2014, 10:37 AM
awesome! I use access it 300V.
Car: 2007 335i
07-11-2014, 10:38 AM
honestly no way to clean them...If you blue the ports it will just go into the PCV system father....sucks.
Car: 2007 335i
07-11-2014, 10:39 AM
I appreciate that, more info we have the better the platform.
king of the hills
07-11-2014, 10:46 AM
Awesome detective work, things like this are great for the community
You don't think we could soak the valve cover in degreaser overnight to clean? I occasionally do the same thing in my E34 M60 intake manifolds because those PCV plates love to spit oil into the covers and make a mess....it works very well to clean them out (soak in degreaser, then rinse).
Car: E90 LCI M-Sport
07-11-2014, 06:07 PM
Have you considered the rb pcv setup?
Car: '07 335i e92
07-11-2014, 06:08 PM
Nice... :-)
Car: 2007 335i
07-11-2014, 06:20 PM
I had one of the first ones, I am local to him lol!
Car: 2007 335i
07-11-2014, 06:21 PM
You may be able to do that but if you have it off I would just replace it.
Car: 2007 335i e92 Coupe
07-12-2014, 09:40 AM
Awesome stuff man! Glad I went ahead and replaced mine last month.
Car: 2007 335i
07-12-2014, 01:46 PM
Total piece of mind!
Car: Bmw 328i F30
07-12-2014, 02:15 PM
great post ! question off post what do you think of Motul 8100 X-cess 5w40 or Castrol edge 5w40 ?
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE dp, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
07-12-2014, 08:22 PM
Great information here!
Car: 2008 BSM 135i
07-12-2014, 10:01 PM
How much does a new valve cover kit cost?
Car: 2007 335i
07-13-2014, 01:46 AM
Motul no question.
Car: 2007 335i
07-13-2014, 01:47 AM
386.00 & comes with gasket and bolts
Car: 2007 335i
07-13-2014, 01:49 AM
thanks T
Thread Tools |
Display Modes |
