str8shot str8shot is offline
Car: N54 135i
Default Intercooler mister... - 06-19-2014, 07:43 AM
Anyone run any type of misting setup?
I see a high degree of temperature rise while idling and after a pull.
I've read on other forums where people have see success with an external mister to pull some heat from the IC.
I was thinking something like this:
http://www.amazon.com/ACI-99300-Wind.../dp/B00495UQT2
$13 bucks, plus figure 5-10 more for some finer nozzles.
Might be worth a shot?
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
raceyBMW's Avatar
raceyBMW raceyBMW is offline
king of the hills
Default 06-19-2014, 07:52 AM
Couldn't hurt...they do help, I know at the drag strip I go to the water station between runs to spray off the intercooler, cools IATs down by about 20deg. People also use nitrous spray to cool, but that seems like more hassle than its worth.
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 06-19-2014, 01:07 PM
after seeing this I want to do it but no idea how
http://www.youtube.com/watch?v=3Ve-C-X6AOw
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE dp, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
Car: Bmw 328i F30
Default 06-19-2014, 01:28 PM
That's weird because DEI sell same product for $100
http://www.designengineering.com/***...er-sprayer-kit
black535xi's Avatar
black535xi black535xi is offline
Car: 535xi
Default 06-19-2014, 01:32 PM
Ive asked about this before as well and never got an answer. The evo/subi crowd swear by em, and while the fmic and meth really do a great job, im usually seeing 120* or more IAT in the staging lanes... anything to bring that down a little would be awesome
I know the guys with top mount ic like to lay a bag of ice on top while waiting
2010 535xi
ALL black, murdered out FBO jb4+flash
Fuel It! stage 2 LPFP on the way
12.400@112.16/1.731 60'
4205lbs
Car: Bmw 328i F30
Default 06-19-2014, 01:38 PM
anyone knows how to install & how they work ?
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 06-19-2014, 01:56 PM
sounds like a great idea. Very cheap for sure.....but how do you do this?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Car: Bmw 328i F30
Default 06-19-2014, 02:15 PM
I think it's easy, someone has to try it sooner or later..
why not on the whole radiator not just the intercooler ?
http://www.designengineering.com/fil...tersprayer.pdf
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 06-19-2014, 07:42 PM
If the track people catch you droping water on the track they will kick you out.
NJrep335I's Avatar
NJrep335I NJrep335I is offline
Car: BMW 335I
Default 06-19-2014, 08:08 PM
+1 to this, forgot to turn AC off and got yelled at once. Imagine this would be much more then condensation dripping.
raceyBMW's Avatar
king of the hills
Default 06-19-2014, 10:16 PM
Yeah be careful with that....have to stop it before you hit the track and make sure its done dripping. That's why I like the water station, it's done dripping by the time I line up again.
Car: Bmw 328i F30
Lightbulb 06-19-2014, 10:33 PM
wth, i think a drop of water might make the car behind you slip & lose traction... but still not on street & not where i live it's a must even with upgraded ic the temperature here reaches 50 degree Celsius (122degrees Fahrenheit). so if it works with stock this is a bright idea
Spxxx's Avatar
Spxxx Spxxx is offline
Default 06-20-2014, 11:07 AM
Just bought the pump & reservoir, I want to wire it to my JB4 and use the meth controller to power the pump.
Anyone know if this is feasible? Without the "FSB" control box that BMS makes...
I just need switched 12v power based on some criteria, I think throttle position or boost psi...?
Car: Bmw 328i F30
Default 06-20-2014, 12:50 PM
which one did you buy ? so you don't have the Meth. kit ? I saw a video attached with throttle I have no idea how, would appreciate if you posted pictures where you're mounting & how to install it.
Spxxx's Avatar
Default 06-20-2014, 01:13 PM
Will do, I'm considering buying a boost pressure switch from eBay and throwing a T into my Vac line and having the pump running off this switch @ any boost level above 7 or 10psi. These are about $30 and super easy to setup
Spxxx's Avatar
Default 06-20-2014, 01:14 PM
I don't have a meth kit, I just bought this http://www.amazon.com/ACI-99300-Wind.../dp/B00495UQT2
and will probably buy a boost pressure switch from eBay if I can't run the pump off my JB4 directly.
Torgus Torgus is offline
Default 06-20-2014, 01:15 PM
How is installing this any harder than a meth kit which will give significantly better gains?
Got Boost?
Car: Bmw 328i F30
Default 06-20-2014, 01:20 PM
If it's possible, to do it with map switch like map 1 or any ect. under certain load from throttle this would be awesome
Spxxx's Avatar
Default 06-20-2014, 01:28 PM
Cheaper and less risk of catastrophic failure if pushing the car hard, I just need some slight additional cooling with my stock FMIC
A <$40 mod to reduce IAT by ~20* is worth it for me...
black535xi's Avatar
Car: 535xi
Default 06-20-2014, 01:36 PM
Fail safe box... otherwise known as FSB
2010 535xi
4205lbs
Spxxx's Avatar
Default 06-20-2014, 01:40 PM
Lol good to know what that stands for.
Still don't like the idea of running octane levels below what my car needs to run proper timing. I know W/M injection has been extensively tested but I'm just "trying" to stay away from it... for now
Car: Bmw 328i F30
Default 06-20-2014, 01:54 PM
Same here, I just got a reply from tuningwerk which are great company for tuning in Germany asking about products for 328i F30 & of course they offer much more for 335i but that was their reply, so I guess I can manage larger fan which I am hoping with this mod can make an effect.
- Inter cooler
- Additional Cooling Kit (depends on your VIN)
- Larger Vent. (bigger fan)
- LSD (here we have professional multi disc LSDīs, no torsion toys) 90% lock
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 06-20-2014, 02:10 PM
I understand dropping temps prior to a run, but how is this helping once you under acceleration 1-2-3-4- gears ?
Car: Bmw 328i F30
Default 06-20-2014, 02:28 PM
without spraying the intake reached 65 degree, after spraying for couple seconds it was lowered to 51 degree that's 14 degree Celsius in a 50 degree HOT day !!
https://www.youtube.com/watch?v=FWHxbgkN3Lk
andydna15 andydna15 is offline
Default 06-20-2014, 06:02 PM
I tried this with my windshield washer tank.removed the line going to the windshield sprayer and extended the line to the front. Bought 2 spray nozzles and hooked it up.it was activated by pulling in the windshield washer lever. it worked great the first time but the issue was that it acted like a siphon. It would pull all the water that was in the take because the tank was higher than the nozzles. It may need a check valve for this setup to work also.
Copyright Đ 2007 - 2020, N54tech.com
