Default Oil thermostat bypass - 01-25-2013, 02:57 PM
We've been testing a thermostat bypass for the last couple of weeks on two of our development cars. It's easy to install and allows oil to flow through the oil cooler full time, rather than only flowing through when oil is > ~240 degrees.
I did a series of cold start warmup tests and oil warm up time went up only around 45 seconds. But during warmer weather back to back runs oil temperatures were consistently 15+ degrees lower.
It's one of those inexpensive and easy to install mods. Worth playing around with especially for those of you in warmer climates.
http://www.burgertuning.com/low_temp...W_235_335.html
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 01-25-2013, 03:57 PM
sounds very promising T
2011 335is DCT, FBO
steve.kodra steve.kodra is offline
IXLR8
Default 01-25-2013, 03:59 PM
What material is this made of?
Default 01-25-2013, 04:23 PM
Aluminum.
dfjaws's Avatar
dfjaws dfjaws is offline
Car: 2007 335i 6MT
Default 01-25-2013, 04:32 PM
I like things that maximize the performance of existing hardware. This is one of those things. I want it!
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 01-25-2013, 04:57 PM
would this be a bad idea for the fall/winter time?
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
Default 01-25-2013, 04:58 PM
I've only been able to test it down to 50 degrees but as I said no issues there. We'll have to see how it does with 20 degree weather but I don't expect any issues other than a slightly longer oil warmup.
jdmc_dusty jdmc_dusty is offline
Car: 07 335i
Default 01-25-2013, 05:00 PM
too bad i have the old style oil filter housing!
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 01-25-2013, 06:29 PM
Send one out if you need cold weather data. Single digits in the am & 20's in the pm.
Buildbright Buildbright is offline
Car: 2013 335i 8AT
Default 01-25-2013, 08:25 PM
Not for F30?
Dirty Dog's Avatar
Default 01-26-2013, 01:14 AM
Look forward to testing this out Terry. It was 110 degrees Fahrenheit here one day last week.
135i - JB4 15ohm l Mr 5 Intake l AA C@tless ********* l ETS Intercooler l BMS Methanol Injection l Berk Tech Mids l Berk Tech Axleback l BMS OCC l ER CP l Turbosmart BOV's. SOLD
335i DCT - JB4 G5 ISO l AA C@tless ********* l ETS Intercooler l Custom Intake l Meth l BMS E85 Flash l BMS OCC l ER CP l Walbro 255 l Turbosmart BOV's. CURRENT
Luiggie135i Luiggie135i is offline
Car: 2009 BMW 135i, 2006 Nissan Altima SE-R
Default 01-26-2013, 03:09 AM
It will be a good an excellent mod for warm weather countries like Puerto Rico...
2009 135i
FBO + Meth = 426whp/474max torque + Toyo R888 = pure fun
seroga1986's Avatar
seroga1986 seroga1986 is offline
Default 01-26-2013, 10:08 AM
It was -15F here this morning and it took my oil 20min of highway driving to get to 160 (jb4 to kick in) then it only got to ~200 by then end of my 35min drive to work. So it might be a bad idea to use the bypass in colder climates since you do want your oil to be around 212 at least. But hotter climates this bypass is going to be good. Terry how long on the install?
2008 135i Sport 6at
JB4 G5 ISO, MHD E85 KR, Fuel-it S1, E55 Mix, Alpina Trans Flash, afe Scoops, My own custom 2.5" inlets, ER CP, Synapse BOV, 3.5 Tmap, 7.5" Phoenix FMIC, NGK 5992, 3" BMS downtubes, N55 Mids, Berk Race, BMS OCC, 48 plate oil cooler, 36 plate trans fluid cooler, PSS, R888, Hoosier DRs.
11.92@123.6 (JB4 ISO, DCI, IC, **, DR, on e45 & 17psi)(2013)
444whp/481wtq @19psi and e60 (2013)
2013 X3 xDrive28i M-package
JB4, K&N drop-in, ER downtube, Map 2 @ 22psi on 93
Stangorang's Avatar
Stangorang Stangorang is offline
Car: Car
Default 01-26-2013, 01:47 PM
Takes no more than 10 mins. Two bolts is all that holds the T-Stat in there.
seroga1986's Avatar
Default 01-26-2013, 03:37 PM
I would assume its reversable like for winter time? I would use it here june through august then go back to stock for winter.
2008 135i Sport 6at
Default 01-26-2013, 03:44 PM
Yes easily reversible. Takes 5min to install.
If you have a consistent warm up time in that winter weather it would be interesting to see how that changes with this. In 50-60 degree weather here I noticed barely any change.
seroga1986's Avatar
Default 01-26-2013, 03:52 PM
Maybe you can send me one for testing!! (: My mornings are below zero almost everyday.
2008 135i Sport 6at
Default 01-26-2013, 03:57 PM
Drop me an email.
Dirty Dog's Avatar
Default 01-26-2013, 04:24 PM
Assuming user's have the basic understanding of how oil temps can affect turbo's and turbo life then this is yet another great little mod for all.
WDBi's Avatar
WDBi WDBi is offline
Car: any
Default 01-26-2013, 05:52 PM
is there a way to machine it so the oil cooler kicks in at say 200. This way the car will warm up normally but stay cooler. Also does this bypass make the jb4's warmup safety ineffective?
Always listen to experts. They'll tell you what can't be done and why. Then do it.
Default 01-26-2013, 06:04 PM
This is all we offer. But the warmup has not been much of an issue in testing as I mentioned. Has nothing to do with the JB4. That stays off until 160 still.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 01-26-2013, 06:14 PM
Once your highs are under 55, I woukd swap. This def will help when highs are over 90s. Def looking forward to it.....can't wait.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
WDBi's Avatar
Car: any
Default 01-26-2013, 06:15 PM
ok so if i bought this i could maybe machine it down a bit to bypass starting at 200 worth a shot
seroga1986's Avatar
Default 01-26-2013, 06:24 PM
No i dont think you will machine it down because a thermostat consists of a special interior that melts inside and pushes the spring open. Youtube "thermostat" and see how they work and how they are made. Very interesting.
2008 135i Sport 6at
