Default Kickdown blocker DIY - 10-24-2012, 05:20 PM
We've been toying around with making a nice CNC machined kick down blocker for automatic transmissions. Also considered doing an electronic one. But other projects have become a higher priority and this simple DIY works pretty well.
Kickdown blocking is useful for the following:
1) When drag racing it allows you to perform a 2nd gear launch without accidentally downshifting in to 1st gear. Critical for good track times with boosted automatics.
2) When doing dyno testing this will prevent you or your unaware dyno operator from pressing the kick down during a run ruining the run.
3) Some of us prefer to manually downshift when racing and this eliminates the chance of the car downshifting when we don't want it to.
The photo shown is a 135 gas pedal. The 335 pedal is a little different but the same basic procedure should work.
skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default 10-24-2012, 05:37 PM
N i c e !!
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 DP
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
tofu tofu is offline
Car: 335i e92
Default 10-24-2012, 05:47 PM
thanks
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 10-24-2012, 05:53 PM
You rock Terry!!
e90man's Avatar
e90man e90man is offline
N54ever
Default 10-24-2012, 07:13 PM
It's not every day you stumble across a <$10 DIY that works exactly the way intended, will never fail, and tremendously stealth!
I_Want_535i I_Want_535i is offline
Car: 2008 535i
Default 10-24-2012, 08:14 PM
Will this safely work on a 08 535i ?
Default 10-24-2012, 08:17 PM
I'll take a few photos on the 335 gas pedal implementation tomorrow. The 535 uses the same pedal as the 335 as far as I know.
Car: 2008 535i
Default 10-24-2012, 08:20 PM
Thanks!!!
A trip to Home Depot tomorrow. Will be adding this diy, g5, and ww meth install for the weekend to do list.
Ramjet's Avatar
Ramjet Ramjet is offline
Car: Z4 s35i 7DCT
Default 10-25-2012, 01:44 AM
Very simple thanks Terry. Hope that the electronic fix also makes it on your list at some stage too!
E89 N54 / Wedge / RB Turbos / AFE DCI / HPF FMIC / Stett CP / Forge DV's / AR Cattless DP's / BMS OCC / RB PCV2 / BMS Spacers
Default 10-25-2012, 04:57 PM
Added photos of the other two pedal types to the first post.
robc1976's Avatar
Car: 2007 335i
Default 10-25-2012, 05:44 PM
My Home Depot didn't have it ....damn!!
Default 10-25-2012, 08:10 PM
Try Lowes. If you still can't find em I'll add them to the site for $3 shipped or something.
robc1976's Avatar
Car: 2007 335i
Default 10-25-2012, 08:24 PM
lowes has them!
jlcolon2001 jlcolon2001 is offline
Car: 335i 2007
Default 10-25-2012, 08:50 PM
Please do it!
ajm8127 ajm8127 is offline
Car: '07 335i
Default 10-26-2012, 06:46 AM
Nice find. I actually have some of those in my garage already.
Car: 2008 535i
Default 10-26-2012, 10:01 AM
Originally Posted by robc1976
lowes has them!
+1 my Lowes has them also !
robc1976's Avatar
Car: 2007 335i
Default 10-26-2012, 10:32 AM
it works flawlessly!! Way better than the washers!
stilov stilov is offline
Car: 07 335
Default 10-26-2012, 11:00 AM
Is there any situation that you would actually want the kickdown to work?
e90man's Avatar
N54ever
Default 10-26-2012, 11:02 AM
328i
robc1976's Avatar
Car: 2007 335i
Default 10-26-2012, 12:30 PM
Originally Posted by e90man
328i
Roflmao!!!
Car: 07 335
Default 10-26-2012, 01:02 PM
ha ha...No I mean like from a higher speed roll, the extra kickdown, could it benefit to get you to right gear?
I guess in others words...what is the drawback to doing this mod?
SaferTransport's Avatar
SaferTransport SaferTransport is offline
Car: e92 335i Coupe
Default 10-26-2012, 01:08 PM
This... is.... AWESOOOOOOOME!!!
JB+RB=
robc1976's Avatar
Car: 2007 335i
Default 10-26-2012, 02:25 PM
no, say you are in 3rd and you slam on the gas...it ill kick own to 2nd and your rpms will shoot up and yiu are out of the powe band and loose power and go to redline in a instant....with the mod it stays in the gear you want.
MathR601's Avatar
MathR601 MathR601 is offline
Default 10-26-2012, 04:19 PM
Let's see if we have those gripper bars here in Canada.
Now if we could have something to prevent the god damn car to shift automatically!
JB4 G5 ISO, BMS DCI, 3" AR ***, E85, BMS OCC, BMS Spacers, ECS Blackout Kidney Grille.
lecsoman lecsoman is offline
Car: 2007 E90 335i A/T
Default 10-27-2012, 06:44 AM
Originally Posted by mathr601
now if we could have something to prevent the god damn car to shift automatically!
amen!
Slow, stupid and angry...
2007 E90 335i AT, G5 ISO, FSB, BMS flash, RB's, RB PCV, DP's, ER OC's, Injen DCI, BMS OCC, FMIC, ER CP, Tial Q BOV, Walbro 455 LPFP, Snow meth kit injecting E85, runnung on E40-50, Alpina TCU flash, Wavetrac LSD.
Coming: BT FMIC, bigger better water rad.
