(#5651)
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 09-12-2020, 08:18 AM
That seems logical but I don't know for sure...AFR does not seem to be suffering when this happnens...maybe the car starts to compensate when it runs out of available fuel to keep the AFR in acceptable range? Maybe someone with more expertise can chime in.
NINaudio NINaudio is offline
Car: 17 Q60 Premium
Default 09-12-2020, 08:51 AM
Hey all, about to join the JB4 family. Getting a used JB4 shortly. I've got a 2017 Q60 3.0 Premium, mostly stock, but I did put on the Infiniti resonated sport exhaust.
Will I need to do anything since I'm getting the JB4 used? I remember reading that some people needed to call in order to get the app working for them when buying used.
roshg roshg is offline
Default 09-12-2020, 09:50 AM
Did a couple runs last night on my 17 q50s, running only a e15 mix. Can you guys analyze my logs and let me know if everything looks proper?
Default 09-12-2020, 11:37 AM
Looks normal to me!
Default 09-12-2020, 06:11 PM
Looks normal to me!
Thanks Terry!
azsuptt azsuptt is offline
Car: Q50RS400
Default 09-13-2020, 04:04 PM
QUOTE]17Q50 RS Stock (No Mods) 93Oct fuel
Looking for the default settings with disable Fuel wire and disable egw for Stock RS
Firmware; 50/8/5
User Adjustment settings
** No Map 6 (If you have a conservative please sent it to me )
Flat boost
- Boost safety:20
- DWP = 0
- PID Gain = 20
- AutoShift Boot Redux = 60 (These I'm not sure)
-FF wastegate Adaption = 60 (These I'm not sure)
** All other = 0
BITS:
- Bit 1 =disable(Fuel) fuel not connected
- Bit 6 Enable RS
- Bit 5 = disable for now as my EGW not connected
[B][COLOR="Blue"]Any Other settings I may need to be aware for now ?
Car: Q50RS400
Default First log stock Rs - 09-13-2020, 04:11 PM
Connected with above settings, tested map 0 map 1 and map 2 conservative and notice improvements.
Log P50_M2_R2_200913_1627.csv
maybe too small of a log this was map 1 no fuel no egw
importroller importroller is offline
Car: 2016 Q50 3.0t
Default 09-13-2020, 04:50 PM
Need help on this log. Lately I've been getting a lag when I floor it, and the trans doesn't downshift fast enough. But then it's like the car isn't sure how much boost it should be under. I don't know if I have a vacuum leak somewhere, but then I decided to do some logging, and noticed my car does go rich in the AF. It seems to go on the lean side instead. I understand when I completelylet off the throttle, it will go into the 20s, that's normal. But I see some parts on the log while under throttle on the high teens. Am I reading the log correctly, or should I start inspecting the car more for issues.
Redgoyabean Redgoyabean is offline
Car: Q50
Default 09-13-2020, 05:43 PM
Hey, trying to post a log but the attachment button keeps popping up n asking for a URL. Tried android Apple.
Car: Q50
Default 09-13-2020, 05:46 PM
Also tried the button right next to the globe
Car: 2016 Q50 3.0t
Default 09-13-2020, 05:48 PM
Are you trying to do the quick reply?
Car: Q50
Default 09-13-2020, 06:33 PM
I'm trying to post not reply if that makes a difference. Is there another way to post other than the quick reply section.
Car: 2016 Q50 3.0t
Default 09-13-2020, 06:36 PM
Bottom left. "New reply"
Car: Q50
Default 09-13-2020, 07:14 PM
Awd 2016 q50 premium with HKS lower down ***** n tanabe axleback. Was running map 5 on 93 no problems pre previous logs n I i just installed ewg wires n will reinstall the fuel wires shortly. I feel like now its runs stronger on the lower rpms but I think I might be pulling timing. I set all the settings per the n54tect page for the ewg wires. Thanks in advance who ever views my logs. Just want it running smooth.
Car: Q50RS400
Default First log stock Rs - 09-14-2020, 06:13 AM
Log Attachment 98530
DO you need the Graph? How to take it out (Print Screen)?
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 09-14-2020, 06:39 AM
Redgoayabean - your car does not seem to be happy on any of those logs. Where did you get your 93 Octane gas? Was it a very hot day? Timing values are very low and don't want to recover after shifts. AFR's are rich - don't know that I have seen values of 10.0 in other logs - seems like high 10's are where they bottom out on most cars without the fuel wires.
Car: Q50
Default 09-14-2020, 07:09 AM
Those logs are only after installing the EWG wires, had no issues running map 5 prior to ewg. I get shell 93 vpower n thats all I use. It was warm but b4 i did the 30mph run my trans temp was around 90 degrees. Are there any values I can change to help with the ewg. I love the low end power they provide.
marmet2010 marmet2010 is offline
Car: infiniti q60 3.ot ss
Usually with the colder weather it will need more fuel, so theoretically that does make sense. Got any logs so we can look at?
hello, for the cold weather in Quebec, would I be better off not putting the fuel wires during the winter?
thank
Car: q50
Default 09-14-2020, 07:24 AM
Your timing is definitely low. I'd pull out some boost below 5500 rpms.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Car: Q50
Default 09-14-2020, 08:42 AM
Hey ddnspider, thanks for checking my logs on the q50 forums. I'm still trying to figure out why I'm having timing issues with the ewg wires. Also, are the ewg wires active only in map 6 or act across all maps after install.
Car: Q50
Default 09-14-2020, 08:48 AM
Need someone who can help me out with the tuning, where's Terry at lol. I really want to keep the ewg wires.
Car: q50
Default 09-14-2020, 09:55 AM
EWG wires are on all maps. I think your EWG wires are fine, you're just commanding too much boost down low.
Q50 Premium RWD
BMS HE
Low cost LSD
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 09-14-2020, 09:56 AM
Are you able to disable the EWG control and see if the timing returns to normal? I don't recall if there is a setting to disable them or you have to unplug the wires. I realize that would be a bit of a pain but might be worth doing to ensure that the EWG control is what is causing the problems. I don't recall mine having any effect on timing or AFR when I activated them.
Regarding the fuel wires - I would leave them off for now until you figure out this issue. I wonder if enriching the mix is another way for your car to cope with the knock issue.
Car: Q50
Default 09-14-2020, 10:47 AM
Going to try n get better lofs today on map 4 n 5
Car: Q50RS400
Default New log looking for advice - 09-14-2020, 07:48 PM
[QUOTE=azsuptt;674443]Connected with stock RS NO FUEL NO EGW
Let me know if graph needed or new log .
Advice .
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Jeff @ BMS
