Originally Posted by AWSAWS
I can give you some scientific data.
Methanol takes way more energy to vaporize than ethanol
You can burn about twice as much meth for the same amount of air as ethanol so methanol makes more power.
Water takes way, way more energy to vaporize than methanol. So...
Hate to dig up an old post but the above is scientifically inaccurate
For the same amount of air the energy released by ethanol and methanol for combustion is almost identical. Enthalpy of combustion is 1367 kJ/mol for ethanol, 726 kJ/mol for methanol so once you consider that for the same amount of air (always the limiting factor) you burn twice as much meth but meth produces half the energy, the result is more or less the same.
The WMI being injected also doesn’t actually vaporize in the intake charge (at least not by much), it atomizes (tiny liquid droplets as opposed to undergoing state change to become a gas). So given the amount of this fluid undergoing state change is minimal, the specific heat capacity is the metric we want to use, not the heat of vaporization. Specific heat capacity of ethanol and methanol are almost identical so there’s very little if any benefit for one versus the other.
