Car: 08 535i
Default First log from a ST set up - 06-24-2020, 07:48 AM
Hey all, here is a log from an on3 single set up. Mods are...
-On3 kit w/on3 tubo
-44mvr with 11.6psi spring
-gplus intercooler w/oem ends
-vrsf cp/hks
-stock fuel
-stock tmap
This is a log in map2. I am new to the jb4 but set all the dutybias to 50, the FF to 20, & WDP to 75...I am hitting just under 14lbs on map 2. I thought map 2 was 17psi, do I have to change the FF to get more boost or do I have a boost leak? Map 1 hit WG spring pressure @11.6 just fine very consistantly.
Lmk what I can do to better to dial it in. Any help is appreciated. I am new to jb4 set up. I usually use mhd only for single n54s.
Default 06-24-2020, 09:38 AM
Probably a good thing that car didn’t make anymore boost.
Need more details...
Which ST flash of ours are you using?
Fuel?
Fuel bias settings- set to 0, yours are all over
Dirty bias- set to 0
Car: 08 535i
Default 06-24-2020, 10:09 AM
Fuel?
I loaded jb4 firmware: N54_G5_MAC_136_T4.hex with a mhd backend flash.
The car is on stock fuel running 93.
I will be back by the car in about 6 hours to continue troubleshooting
Car: 08 535i
Default 06-24-2020, 10:11 AM
I will relog map 1 and post it as soon as I am buy the car.
Default 06-24-2020, 12:44 PM
Sounds good
Car: 08 535i
Default 06-24-2020, 04:48 PM
https://photos.app.goo.gl/SQJZ9ZV1j4TuzW6T6
Here are the map 1 settings. I will be posting a log soon once the oil temps are up to par.
Car: 08 535i
Default 06-24-2020, 05:17 PM
Here is the map 1 log
Fuel bias all set 0
I set duty bias all to 50 per the set up instructions.
Please let me know if you think I am safe to try map2.
Thank you very much for your help
Default 06-25-2020, 08:30 AM
Let’s see 2
Car: 08 535i
Default 06-26-2020, 07:56 AM
Let’s see 2
after some research I found I have some setting wrong for this log. I have changed them to what they should be. Here are the notable changes and then the settings as they were set for this log.
N20 TMAP was @ 15 I changed to 0
6-cyl timming was @ 15 I changed to 4 for I8AOS
Map1
Fuel bias all.......0
Dutybias all.......50
Boost Safety.......18.0
Default Wastegat position...........75
PID Gain..................................25
Auto Shift Box Redux.................60
FF/Wastegate adaptation...........20
Fuel open loop..........................47
Meth safety mode(1-3)..............0
Meth Trigger Mode(1-3).............100
Max Boost 1st..........................0
Max Boost 2nd.........................0
Max Boost 3rd..........................2.0
Future A..................................0
options(tap button to view)............Never open this
N20 TMAp (0/1).......................0
6-cyl timming logging(0-6)........4
Here is a new log in Map 1 wit the setting as listed above.... not sure if things changed. If this looks good then I will load map2 with the same settings....
Car: 08 535i
Default 06-26-2020, 07:59 AM
I also notice that when I switch out of Map1 to Map0 or Map2 then back to Map1 all the Dutybias values return to *0* for Map1. In Map2 they hold the dutybias value to 50 regardless of leaving the map and returning.
Default 06-26-2020, 12:38 PM
That’s normal.
Jump up to map 2
Car: 08 535i
Default 06-26-2020, 03:23 PM
Here is a map2 log it felt good in 2nd, but seemed to break up in 3rd. I had a lambada code...
2c6e lambada probe behind cc 2, aging
I am assuming the o2 sensors need replacing. There are no o2 sensor codes in map1, only map2.....
Thank you so much for the help!
