(#501)
Default 05-30-2020, 10:51 AM
Originally Posted by tZe
Hi
I was just wondering. If I set Options bit6 (FUD) to on, and use Map 1, does this mean that the JB4 unit is not controlling any of the tuning (boost, AFR, timing etc)?
I already have the JB4 with Bluetooth and love the logging/gauges. I am thinking of trying a couple of different flash maps (both custom and OTS) just for kicks. I was wondering if I could just load the flash map and use the JB4 purely for logging/gauges.
For example. I want to try BMS/MHD OTS tune. I load the tune in, set FUD bit6 and Map 1. Will this work? I don't want the JB4 interfering with the flash map in any way.
You can always use map0 to fully disable the JB4 and use it for logging only.
tZe tZe is offline
Car: F32 440i
Default 05-30-2020, 11:16 AM
I didn't know I could do that on Map0; learn something new everyday. However, I think the live gauges would not work on map 0 right? I need to use Map 1 with FUD6 on?
Default 05-30-2020, 12:42 PM
Right if you want in dash guages. App works on map 0 though for logging.
ipetey ipetey is offline
Car: 2020 m340i
Default 06-20-2020, 01:52 PM
Hi Terry,
I just got my MHD OBD2 wifi connector, I have a JB4 on my m340i right now. I also have the MHDF+G app on my iPhone. I see the setting for BEF and jb4. Could you answer a few questions for me or just put me on the right path here.
Thank you in advance
Default 06-21-2020, 03:36 PM
For G20 email us for the specific map as it's not posted in this bundle yet. Uses the same map as our Supra BEF.
RMM RMM is offline
Car: 120i
Default 06-21-2020, 08:14 PM
Is it possible to have METH on when in map 0? I tried different meth safety and trigger but cannot get any meth flow in map 0 no matter the setting.
For now I am using map 6 with all all setting disable or set to 0 as much as I can or know how. But I would prefer to use map 0, if I can get METH working on MAP 0 that is ideal for my setup.
Also is it possible to make a log using lets say BM3, with meth working but without JB4 connected to ODB, even in a more simple mode, like if boost > 12 psi, then flow 80%. I understand that without ODB the JB4 will no have RPM so progressive meth will not function, however it does know boost, so it can still do a simple boost dependent meth control.
The reason why I need this is that meth will influence the boost control and fuel trims, so I would like to get the full BM3 logs with the boost control PID info with meth flow for better custom tuning of the boost control in BM3. Right now I go back and forth between JB4 with meth, and BM3 without meth many times, to get it dialed in but that takes a lot more time, and I do not really like doing too many pulls without meth, it would be much better if JB4 allowed customizing tuning with meth flowing for those of us using JB4 as a meth controller + daily logger .
510W_MPP340 510W_MPP340 is offline
Car: Zhp 340 ‘18
Default Customizing map 6 - 06-22-2020, 03:35 AM
When customizing map 6 on jb4 do need to touch fuel bias / duty bias? Also what is recommended to set starting for rest of the values
B58 340
Which BEF to use?
RACE: Intended for most applications including good pump gas fuel like 93 octane up through 30% E85 mixtures, can also be used with WMI.
PUMP: Intended for lower grade fuels such as 89-91 octane or in applications where less overall timing advance is needed than RACE.
E40-E60: Intended for most E85 mixtures.
STRAIGHT-85: Intended for those customers running 100% E85 generally in conjunction with the TU or upgraded high pressure fuel pump.
WMI: Indicates a decaying fuel scalar for vehicles equipped with higher volume WMI or CPI systems.
PURE: Indicates mapping intended for use with PS2 and other larger turbo options.
JB4 B58 map guide as of v13+ firmware:
Note Options (formerly FutureUseD) bit6 must be enabled for correct mapping when flashed
Map0: Stock tuning, fully disable JB4
Map1: Flash mapping with JB4 active for in dash gauges, boost by gear, CAN flap, etc
Map2: Absolute target map peak boost of 16psi
Map3: Absolute target map peak boost of 18psi
Map4: Absolute target map peak boost of 20psi
Map5: Absolute target map peak boost of 22psi
Map6: Custom tuning map allowing both additive (below 10psi) and absolute (above 10psi) targeting
Map7: WMI map (boost varies based on WMI additive and map settings)
Map8: VALET/Low boost safety map
Default 06-22-2020, 09:21 AM
With latest JB4 firmware meth trigger = 4 allows meth to flow regardless of map or OBDII status.
B58 340
Just the boost levels you want, fuel bias and duty bias won't be changed.
Car: Zhp 340 ‘18
Default 06-23-2020, 04:33 AM
What kind of a fuel pump does a ‘18 B58B30M0 have? Is it actually worth replacing with a90 Supra’s?
Default 06-23-2020, 08:41 PM
I think the TU pump didn't start until the G20 and Supra. If you have a fuel pressure issue then yes it's worthwhile. But use your own log as a guide.
Thechrisjones Thechrisjones is offline
Car: 2019 X3 M40i
Default 08-04-2020, 11:11 AM
Newbie here so sorry in advanced but I am learning so much from you guys so thank you!!!
I have a 2019 X3 M40i (daily driver) with a JB4 and a K&N closed air filter. I only run 93 octane. I was told by Burger to just run map 3 and have fun and that I am!
I’m reading a lot about BEF and thinking about adding the MHD BEF to get a little more excitement. I don’t plan on making modifications to the exhaust, or start mixing fuels as that’s a little over my head right now. With that being said, what kind of benefits would I see adding the MHD BEF? More HP? more torque? Boost? Changes in gear shifting?
Also, are the maps now dialed in for plug and play with the kinks worked out and pretty safe now? I’m not experienced enough to make a lot of adjustments.
BPUKiller BPUKiller is offline
Car: 340i
Default BEF JB4 issues - 08-14-2020, 10:07 AM
When I try to upload these maps I’ve attached I get the error that I’ve also attached. I’m new to this. First of all the files Don’t appear the right size.
Any help will be appreciated.
Sam
JBoe JBoe is offline
Car: M240i
Default 08-15-2020, 04:59 PM
Sam
No attachments? Can't help if we can't see what's wrong.
AFE Drop-in Filter
BMS Meth Kit (100% M1)
Muffler Delete
CA 91 Piss Gas...
(8oz Boostane 95ish Oct)
E85 (2Gal/Fill)
BEF (Race_WMI)
JB4 (Map 7 - Add 45... 19-20psi)
Default 08-15-2020, 05:25 PM
It depends on the situation we're able to improve response, hold more power up top, you can enable MHD's flash options if you want like exhaust burbles, remove the speed limiter, etc.
tntman tntman is offline
Car: BMW 135i
Default BEF map 2 - 08-17-2020, 04:13 PM
just loadead bef race. jb4 on map 2.
feels strong and consistent.
please check logs ok
just 98 ron fuel and burger open intake.
M240i
eomacue eomacue is offline
Car: BMW M240
Default MHD Flash end for M240i - 09-11-2020, 10:28 AM
Hello!
I have recenlty flashed my M240i with the MHD flasher licence. All went super good.
Now im looking to upload the JB4 Maps or looking to get a custom one.
Can you help me on this one, should i just go and upload the maps contained in the link above "http://n54tech.com/flash_files/mhd_b58_backend.zip"?
Or is ther any other process i should follow?
KnifeEdge87 KnifeEdge87 is offline
Car: BMW G30 520i 2019
Default 09-14-2020, 06:01 PM
Is there anything in the works for those with B48 engines ?
dannyq2 dannyq2 is offline
Car: 2016 340i Xi
Default BEF with TU HPFP - 10-07-2020, 10:26 AM
If you replace the 2016 HPFP with the newer TU (supra, M340i) HPFP do you still need to check the Dorch HPFP check box in the MHD BEF settings?
Also what HP/ mods would a newer TU HPFP support?
Ldenne123's Avatar
Ldenne123 Ldenne123 is offline
Car: M135i 2014 EWG JB4 MAP 2 + MHD BEF *****
Default BEF Which file to choose with pure turbos pump fuel - 11-23-2020, 04:58 PM
Hi bit confused hope you could help me , which BEF do i use with the PS2 setup and hpfp upgrade on only pump fuel shell v power, but no WMI or e85 etc as i notice only PURE files have RACE_PURE_WMI or PUMP_PURE_WMI both with WMI ? Is There a PURE file to flash just for pump fuel alone ? And which JB4 map would i use combined with the BEF i.e MAP 1,2,3 ETC ...thankyou
135kev 135kev is offline
Default 11-29-2020, 07:54 PM
Did the price of MHD go up? Its $304 on their website. In this thread it states to purchase it for $249
mike082802 mike082802 is offline
Car: vw passat
Default 12-27-2020, 06:44 PM
@Terry
what are the differences in the pure turbo bins 1,5, and 7? also all the upgraded turbo bins have _WMI in the title, are they all using meth? also you think these pure maps would work on a Vargas GC turbo for the B58?
thanks
Default 12-28-2020, 09:45 AM
Not sure on that, for the JB4 you only need the flashing license. Nothing else.
Default 12-28-2020, 09:47 AM
Originally Posted by mike082802
@Terry
thanks
The BEF maps are all just starting points. If you need specific tuning advice post a log of your setup and we can evaluate it.
Main difference between maps are PUMP, RACE, or E85, depending on fuel being used.
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default BEF Files - 01-14-2021, 09:49 AM
I am trying to download the BEF files, but every time i click on the download link nothing happens, this is the link i am clicking on.
I want the file that is for the larger turbos + the Dorch stage 2 pump
What am i doing wrong ? (apart from getting out of bed this morning )
