importroller importroller is offline
Car: 2016 Q50 3.0t
Default Map 6 with wgc and fuel wires - 05-15-2020, 11:09 PM
my car doesn't seem to be as powerful as it used to be. Almost like it's not holding the boost. How does this log look to the professionals?
unforgettable7 unforgettable7 is offline
Car: 2016 Q50SS
Default 05-15-2020, 11:19 PM
your fuel trims are consistently maxed out resulting in high AFR.
i have never worked with fuel wires, so i can not comment if you can correct for this with any parameters, i would advise you to turn the boost down for the time being.
2016 Q50ss
ams downs
hks bov
Car: 2016 Q50 3.0t
Default 05-15-2020, 11:27 PM
Since I have some e85 mixed with 91 still in the tank, the fuel wires are activated. I usually turn them off if I'm only running 91
iamafrayedknot's Avatar
iamafrayedknot iamafrayedknot is offline
Car: 2019 Q50 Red Sport AWD
Default 05-20-2020, 09:57 AM
Not a pro at reading logs however initially I set fud.5 to ON, this disables the EWG inputs and it ran normal. This may be the first thing to do in order to isolate your issue to EWG settings.
Josh
2019 Q50S AWD
Default 05-24-2020, 04:44 PM
Was not warmed up enough first run. Do you have EWG connectors? I'd lower the boost target a bit to get get down.
Car: 2016 Q50 3.0t
Default 05-24-2020, 05:37 PM
Yes, I have the WG connectors. I had to redo the map 6 settings anyways as the other day the jb4 did some weird stuff and reset back to zero, and put my car in limp mode. I logged into the app after it happened and non of the map 6 settings were there. All went back to zero
