(#5276)
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 04-16-2020, 10:02 AM
Nice times - sorry I missed them in your signature line! Thanks for sharing your Map 6 settings.
Car: q50
Default 04-16-2020, 10:06 AM
With my old tires I was dialing back 3.5 psi in 1st, no longer needed with the Indy 500s on the rear (as long as I shift on time, that is). Consistent 4.4--4.5 results on Dragy.
Geez, I destroy the Indy 500's in 1st and 2nd. I think I'm going to have to add a huge pull in boost by gear.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-16-2020, 10:41 AM
No worries, and you're welcome. Enjoy!
Well, you have meth and EWG connectors, I'm just on 93, you have superior torque and whp so it makes sense that you aren't catching traction. I'm right on the cusp with just 93. Also, if I try any of my runs at 45 or below, its a crap shoot for traction, which sucks because the DA is usually below 0 with those temps.
12.64 @114mph
0-60 4.46
Car: q50
Default 04-16-2020, 10:52 AM
Cant believe I didn't buy an AWD
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-16-2020, 11:00 AM
You and me both.
Won't make that mistake twice tho
12.64 @114mph
0-60 4.46
Car: q50
Default 04-16-2020, 11:10 AM
The saving grace is that I know if I put a real tire on the car it'll be as quick or quicker than the AWD peeps because drivetrain efficiency.
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-16-2020, 04:09 PM
Certainly can roll out with the commitment. Check out the unofficial Top 10 time list, 2 RWD guys on there. I would love 11.91 on an AWD with JB4
12.64 @114mph
0-60 4.46
Tipsquad22 Tipsquad22 is offline
Car: 2016 RS Q50
Default 04-16-2020, 04:11 PM
Whatís a good map6 to run on my 2016 Q50 RS AWD?? Iím new to the JB4. No mods yet
Car: q50
Default 04-16-2020, 04:15 PM
In the real world of racing rwd>awd. All these awd cars being on the list just because it takes less work to go fast when you're not serious about going fast lol. Where is that list on?
Q50 Premium RWD
BMS HE
Low cost LSD
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-17-2020, 04:50 AM
Facebook. VR30 Tech Talk page. Lots of things happening
12.64 @114mph
0-60 4.46
Car: q50
Default 04-18-2020, 05:37 AM
Interesting. Of all the things the vr30 needs I'm not sure that's at the top of the list but hey good to see the aftermarket moving on the platform.
Q50 Premium RWD
BMS HE
Low cost LSD
djslug2000 djslug2000 is offline
Car: 2017 q60 ss
Default 04-19-2020, 01:00 PM
V8 firmware is still showing as BETA , is this still the case ?
Default 04-19-2020, 03:50 PM
Technically yes but it's going in to production shortly with no changes expected.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-20-2020, 12:06 PM
EWG Wires arrive today, not sure I'll be able to install this evening but soon enough.
12.64 @114mph
0-60 4.46
importroller importroller is offline
Car: 2016 Q50 3.0t
Default 04-20-2020, 12:46 PM
I'm almost done with the install. All wires ran, just need to plug them in.
Dgvr6's Avatar
Dgvr6 Dgvr6 is offline
Car: 2016 S6 and 2018 q50
Default 04-21-2020, 01:13 AM
Hello guys, just got a JB4 and I’ve been running some logs on map 6.
I filled with e85 and 93 to try and achieve an e30 mixture, did a pull on a progressive taper to 7 and back down towards redline.
I noticed power cut around 4k and adjust the boost back down after I looked at logs and determined the car did not like what it was seeing.
This is the first time I’m playing with the q50 and pretty much a noob to this platform but not all that new at tuning. AFR seemed too lean around that rev range and dropped about 4 degrees. Don’t see a way to log knock so I’ll just base the correction on ign timing.
Looks like a decent spike in boost and AFR may have cause the ecu to say nope from what I can see on the graph. Can anybody confirm? Would FW make a difference with AFR when running E85 and any advice on a good setting for map 6?
Map 5 looks better, set it back to 3 at the meantime in hopes for the ECU to adapt to the mixture
2018 Q50 Luxe Stock with JB4 BT and no FW
Edit - Feels like the ECU adapted to e85 , added a few more logs—first run is a decent 3 gear pull running +6psi.. looked great.. others are just a mix of random WOT with AUTOLOGGING on. Think FW would be beneficial on a e30 mix to keep that same AFR of that first run.
jsbowling42 jsbowling42 is offline
Car: Q50 Red Sport
Default 04-24-2020, 07:01 AM
if you are on 93 fuel i would recommend starting with this(or map 1) then log and go from there:
3.0 '1500
3.5 '2000
4.0 '2500
4.0 '3000
4.0 '3500
4.0 '4000
4.0 '4500
4.0 '5000
3.5 '5500
3.0 '6000
2.5 '6500
2.0 '7000
Default 04-24-2020, 08:22 AM
Runs seem OK but I wonder if you just wouldn't be better off on map3 or map4 on the v8 firmware.
arunprasath arunprasath is offline
Car: Infiniti Q60 Red Sport AWD
Default 04-24-2020, 05:32 PM
Hey Guys,
I am new to tuning and am planning on getting the BMS Stage 1 Tuner for my Infiniti Q60 Red Sport AWD. I had a question regarding switching the map. I know the stage 1 comes preset with +3 PSI boost, if I wanted to increase this to +4 PSI, would I need to get the BMS Data Cable/Wireless Mobile Kit or can I do it another way without these?
Thanks,
Arun
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-24-2020, 06:01 PM
Got a problem. Installed EWG connectors, revs in driveway were fine, started driving and limp mode but no CEL. Parked and turn off, back on, driving again, as soon as I hit significant boost, car rocketed forward, TC disabled, I almost went sideways and then I got a CEL and it says Warning Malfunction See Owners Manual. JB4 codes are 2562 and 2586. Any ideas?
12.64 @114mph
0-60 4.46
Default 04-25-2020, 05:54 PM
Sounds like an EWG related install or setting so post a log up in the EWG thread and we can help you get to the bottom of it!
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-25-2020, 06:02 PM
Forgot to reply back to this thread, it was the settings, once I set them it ran HARD and the CEL went away.
Here's some logs from a night of racing
12.64 @114mph
0-60 4.46
jrobohm's Avatar
jrobohm jrobohm is offline
Default 04-26-2020, 08:16 PM
PSA: Just to wrap up this thread and for others - What settings did you set which cleared up things for you?
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS WMI w/ PM8ís
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • AMS CAI
  • Fast Intentions Res. Touring 2.5Ē CBE
  • Mishimoto Oil Catch Can
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-26-2020, 08:33 PM
All of them from the 1st post lol I literally didnt change a single one before test driving
12.64 @114mph
0-60 4.46
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-26-2020, 09:30 PM
I have them disabled now, I think, until I get feedback from the logs.
12.64 @114mph
0-60 4.46
