(#76)
Default 04-15-2020, 04:50 PM
Won't be disappointing for me. I had some extreme lean conditions the 1st time around on the dyno. With some logs and experience I now believe I have dialed in a good Map 6 for the car, so my dyno time will be used to see the power across the band, not an attempt to see a better peak WHP number. The deltas I'll be looking for are significant difference along the curve. With the EWG connectors, I hope to see some power gains on the low end if I understand correctly. Most importantly I hope my curve is smoother than before, with better power delivery due to the 1 psi tapered steps I set up on the map
If you're renting the dyno for an hour or two to do real time tuning that is another story and well worth it. If just doing a handful of runs probably a waste of time.
importroller importroller is offline
Car: 2016 Q50 3.0t
Default 04-15-2020, 05:32 PM
I see they aren't in backorder anymore. Just placed my order. Is there a chart showing what each map is for in the 8 firmware? I downloaded it, but haven't installed it yet.
Liveseyd238 Liveseyd238 is offline
Car: 2016 q50 premium
Default 04-16-2020, 12:34 AM
Hello! I'm looking for help with wastegate control settings. I have been playing around a bit and wound up getting way more torque down low and more top end charge!.... I'm sure its not good to run it on kill all the time,,, oh well
here is a log from last night. It starts around timestamp 5,516. The boost is a bit "spicy" haha. E30ish mix with 92 oct.
mods: Helmholtz alxe back, hks bov, jb4 w/ fuel and ewg wires.
File Type: csv 4-15 boost control test (short vr.).csv (379.4 KB, 75 views)
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-16-2020, 06:25 AM
In the main Infiniti Q50/Q60 thread all of the Map/Firmware info and changes are in the 1st few posts
12.64 @114mph
0-60 4.46
Default 04-16-2020, 09:19 AM
Runs are too short for me to really evaluate anything. But I can see boost response is improved with the EWG on there.
Car: 2016 Q50 3.0t
Default 04-16-2020, 08:53 PM
Thanks, found it.
Car: 2016 Q50 3.0t
Default 04-16-2020, 09:31 PM
I set up map 6 according to the instructions. The wires should be here Saturday. Is this how it should be setup? Just want to be sure I followed instructions correctly.
Default 04-16-2020, 09:36 PM
Yes, you can set FF to 60 also. That has been working fine for most.
Car: 2016 Q50 3.0t
Default 04-20-2020, 10:06 AM
Just curious, I didn't see it mentioned earlier. Are these still active when not using map 6? Or are they still
Active even in the other maps?
Default 04-20-2020, 10:22 AM
Terry, here is a log with a 0-60 and a long 3rd/4th gear pull. I got my best 0-60 time here too! 4.37! stock runflats and a pretty much stock car!!
this was vs. a 392 scatpack with no cats, full exhaust, and hp tuners tune. (he pulled about a car on me on the top end) 0-60 starts at timestamp 1100. 3rd/4th starts at 2100.
Car: 2016 Q50 3.0t
Default 04-20-2020, 02:06 PM
got mine today. i took the entire unit off the car to do pin wires, as it was easier that way to do in my free time. The actual install back on the car was only about 20 minutes. the passenger side one wasn't as bad as it looked at first, if you position your fingers correctly when you reach down. and i have big hands, but skinny fingers. I'll get some logs maybe tomorrow as i have an appointment in the morning to get to.
Default 04-20-2020, 03:46 PM
Nice! log looks good to me.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-20-2020, 05:08 PM
AWD I assume?
12.64 @114mph
0-60 4.46
ckakka2 ckakka2 is offline
Car: 2016 Q50 3.0t
Default 04-20-2020, 07:26 PM
Just got the EWGC wires installed today, was a little difficult but managed to install both sides without removing anything. How do these map 6 logs look? 7psi peak, ~E30 fuel.
Side note, what does the timestamp column correspond to?
Cali_Q50 Cali_Q50 is offline
Car: Infiniti Q50
Default 04-20-2020, 11:25 PM
When you say set ff to 60 do we also change duty bias to 60 across the board Or leave it at 50?
Car: 2016 Q50 3.0t
Default 04-21-2020, 11:50 AM
got to take the car for a drive this morning to get my exhaust adjusted. How do these logs look?
Default 04-21-2020, 01:08 PM
Looks good to me. Timestamp is ths of a second.
Default 04-21-2020, 01:09 PM
Normal
Car: 2016 Q50 3.0t
Default 04-21-2020, 01:41 PM
so i don't need to make any adjustment? i'm good to go?
Default 04-21-2020, 03:03 PM
Yes!
Car: 2016 Q50 3.0t
Default 04-21-2020, 03:29 PM
Hey Terry, on the main thread you posted a dyno sheet with EWGC + E40. There were no fueling upgrades required with that? What PSI were you pushing?
2016 Q50 3.0t Premium AWD - JB4 + EWGC
DWS 06 - F: 245/40-19 R:285/35-19
Default 04-21-2020, 04:11 PM
We pushed things close to the max for that. We're not ready yet to push customer cars that hard but we're working our way up as more EWG data comes in.
jsbowling42 jsbowling42 is offline
Car: Q50 Red Sport
Default 04-22-2020, 02:07 PM
just for curiosity and data, ive been slowly lowering the E85 mix to just see what i could get by with. here is a quick log(there was people walking near the track) of what should be ~e14
Car: Q50 Red Sport
Default 04-22-2020, 02:22 PM
do you have a link to the post? i looked through Terry's posts yesterday and didn't see it.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 04-23-2020, 03:27 PM
I dont have any clue which connectors I am going to be connecting these to haha. Seemed easy until I got out here. I'll disconnect my catch can and BOV for now until someone can confirm the 2 connectors I photographed. Are these the ones?
12.64 @114mph
0-60 4.46
