04-09-2020, 08:40 AM
Originally Posted by Cali_Q50
Hey Terry, can you take a look at these 2 runs running on E30 map 4
Seems OK to me
04-09-2020, 08:42 AM
Originally Posted by jsbowling42
Here is ff =70, map 2.
curious why the timing doesn't drop to zero like it typically does during a shift?
Not much improvement so ff = 60 is probably best for you. Timing always drops during shifts for a moment. Sometimes too quickly for logging to pick it up.
Car: Q50 Red Sport
04-09-2020, 08:55 AM
Here is ff=70 on map 1. Just for kicks to see what’s better.
04-09-2020, 09:32 AM
You probably need a dragy to see what is giving the best real world performance but I'd guess map2 FF = 60.
Car: Infiniti Q50
04-10-2020, 08:30 AM
Seems OK to me
Here's a run on map 5 from a dig.
04-10-2020, 09:42 AM
What is the fuel mix here?
JB4
Car: Q60 Redsport
04-10-2020, 12:52 PM
Terry, here are a couple of runs with across the board duty bias and FF set to 55 on a Q60rs and 93 octane. See any issues here?
04-10-2020, 01:59 PM
Looks fine to me. With the RS models we don't have the same low end fueling limitations we do on the SS models so you should be fine at FF = 60 or 65 too. See what feels the most responsive to you.
Car: Infiniti Q50
04-10-2020, 03:04 PM
E30
Car: 2016 Q50 3.0t
04-11-2020, 12:08 AM
Originally Posted by Serstylz2
I've been refreshing so many times a day trying to purchase the EWG connectors lol
Same here. I noticed the price went up from $60 to $80 too.
Car: Infiniti Q50
04-11-2020, 10:14 AM
E30
Same map and E30 but from 3rd gear at 40mph saw target drop from 7-0...
Car: 2016 Q50 Red Sport
Additional install instructions??? -
04-12-2020, 07:59 PM
Is this all that is available for install instructions? I looked for a video and could not find anything. And the link from BMS takes you to the Stinger install. Am I missing something?
04-12-2020, 08:09 PM
Just what's in the first post currently, hopefully some users will share additional photos in the thread we can use to develop a VR30 specific install guide. Our car has a development harness on it so isn't very photo worthy at the moment.
Car: q50
04-13-2020, 02:45 PM
This site is so annoying with the image upload limit. I'm trying to post from the phone and upload pics directly but it exceeds the limit.
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
04-13-2020, 04:42 PM
Sorry our weak server can only handle so much. Resize down below 250k or maybe use a 3rd party host?
JB4
Car: Q60 Redsport
04-13-2020, 04:47 PM
Terry, here are some photos from my install. The driver side is pretty easy to connect. Passenger side is a little more difficult if you have fat hands! I routed passenger-side connector around back of engine bay.
Car: Q50 RedSport
Couple of pulls -
04-14-2020, 12:19 AM
Can you check my log. Fw off. Thanks
Car: 2019 Q50 Luxe
04-15-2020, 10:30 AM
EWG connectors are back on sale, just placed my order.
12.64 @114mph
0-60 4.46
Car: 16 Infiniti Q50 3.0t AWD
04-15-2020, 02:28 PM
Me too!
2020 BMW M340ix Portimao Blue
K&N drop in, JB+, Intake muffler delete
2016 Q50 Premium 3.0t AWD (GONE)
K&N drop ins
Megan Racing Lowers
Megan Racing Y p!p3
BMS Heat Exchanger
JB4 W/fuel wires Map 6 custom
E20ish mix made 413whp 410wtq (17-18psi peak)
Car: infiniti
04-15-2020, 03:20 PM
ordered mine as well yesterday.
any one else do a dyne with these on yet?
and how much HP is this looking to help you gain?
Car: 2019 Q50 Luxe
04-15-2020, 04:01 PM
I plan on doing a delta dyno session. 1st pull JB4 only, 2nd pull JB4 and fuel wires enabled, 3rd pull JB4 fuel wires and EWG connectors
12.64 @114mph
0-60 4.46
Car: infiniti
04-15-2020, 04:07 PM
wow may i ask when
that IS GREAT!
04-15-2020, 04:13 PM
Sounds like a recipe for disappointing results to me. The fuel wires and EWG wires just allow additional tuning options. The power gained by each is entirely dependent on the settings used to optimize the vehicles overall tuning.
Car: 2019 Q50 Luxe
04-15-2020, 04:30 PM
Won't be disappointing for me. I had some extreme lean conditions the 1st time around on the dyno. With some logs and experience I now believe I have dialed in a good Map 6 for the car, so my dyno time will be used to see the power across the band, not an attempt to see a better peak WHP number. The deltas I'll be looking for are significant difference along the curve. With the EWG connectors, I hope to see some power gains on the low end if I understand correctly. Most importantly I hope my curve is smoother than before, with better power delivery due to the 1 psi tapered steps I set up on the map
12.64 @114mph
0-60 4.46
Car: 2019 Q50 Luxe
04-15-2020, 04:31 PM
wow may i ask when
that IS GREAT!
Going to wait until the COVID quarantine is lifted, so sometime in May if the date holds
12.64 @114mph
0-60 4.46
