panda340i panda340i is offline
Car: 340i Xdrive
Default WMI VS CPI - 09-02-2019, 11:53 AM
Has anyone swapped there WMI for CPI? I running PS2 with WMI with E50 in the tank. I was thinking CPI would be smoother...
2016 340 xdrive - JB4 - Dinan Midpipe - Dinan Muffler - Dinan Shockware - PS2 - BMS methkit - Dual DO7 nozzles - HCP BEF
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 09-02-2019, 10:24 PM
I would think there is no point. Only benefit is you don't have to buy meth all the time since the CPI taps into the fuel system. Are you running E50 in the car gasoline tank or in the actual meth tank?
2013 335is: V8Bait tuned, M4 DCT flywheel, E50 + AEM meth kit with dual BM5 nozzles, MMP relocated inlets, VRSF outlets, CTS 7" IC, DCI, BMP Stage 2 fuel pump, PR coils, 3" DP, BMS charge pipe
2018 340i: Pure Stage 1 turbo, BMS meth kit, BMS intake, JB4 + MHD, DP
2011 335d: BRR tuned
Car: 340i Xdrive
Default 09-03-2019, 05:24 AM
I'm running e50 in the main tank and X98 in the meth tank
dRDiesel's Avatar
Car: BMW
Default 09-03-2019, 06:36 AM
I been wanting to try X98 in the meth tank. What are your thoughts?
Default 09-03-2019, 09:43 AM
CPI better if you have e85 access. Methanol if you don't have e85 access lol.
dRDiesel's Avatar
Car: BMW
Default 09-03-2019, 10:44 AM
Payam since he's running X98 wouldn't the meth setup be more beneficial since its a higher content of ethanol spraying inside the engine?
Default 09-04-2019, 10:23 AM
Not if you have the ability to run full e85 and no supplemental pumps and tanks needed
I'm running CPI on my M5 and my Turbo S.
Car: 340i Xdrive
Default 09-04-2019, 12:17 PM
so you would swap the meth set up for CPI. I like the idea of not messing with the getting meth. Would you run straight e85? I'm running e50 at the moment
Default 09-04-2019, 02:10 PM
Yes, exactly. No more filling the methanol tank, or worrying about it etc.
I have CPI now and just fill up either e50 blend or full e85.
Daily I do e50 blend, when I go to race event I to full e85 and change a few values for the CPI to add more fuel. Simple
ecarver2's Avatar
ecarver2 ecarver2 is offline
Established but no O.G.
Car: 2016 BMW 340i xDrive M-Sport
Default 10-01-2019, 11:12 AM
Why not run both MWI and CPI?
Default 10-02-2019, 09:37 AM
Not needed, pick one lol. They do the exact same thing.
ecarver2's Avatar
Default 10-03-2019, 09:12 AM
But CPI is better since it can dynamically add fuel, rather than the BMS WMI kit, which is basically on/off?
Default 10-04-2019, 09:49 AM
No, the WMI controlled with the JB4/FSB does the same.
It just depends what's easiest for you based on fuel accessibility.
jovonni31 jovonni31 is offline
Default 10-04-2019, 10:52 AM
is there CPI out for the B58? where do I get one or how is it different from WMI I have access to e85. not sure what route to go
2016 340i trackpack , JB4,MHD BEF e85 tune, BMS intake, BMS CC
Default 10-04-2019, 02:29 PM
B58 Charge Pipe Injection (CPI) Kit - FUEL-IT!
RMM RMM is offline
Car: 120i
Default 10-09-2019, 03:13 PM
My personal experience is PWM is not working well in v14 FW, flow is lower even when you set it to 100, and it jumps all over the place, however if you disable PWM it is stable and higher flow. I would not recommend PWM for v14. Old FW it did work very well however. Also the RPM trigger control is not working for me either. It will come on at 2000 RPM or whenever boot hits teh threshold setting and throttle over about 80% regardless of that the meth trigger settings like RPM are set to.
Default 10-10-2019, 10:34 AM
Please post some logs so we can take a look.
Do you have logs on previous firmware to compare?
RMM RMM is offline
Car: 120i
Default 10-11-2019, 07:46 AM
ignore the 2015 date these were all done in the last 2 weeks
-on the v11 runs the RPM trigger looks to work and the PWM control is stable
-on the V14 runs there is no RPM control, and the PWM jumps around
I did measure the actual PWM duty cycle with oscilloscope and I did confirm that the PWM signal to the pump is dropping I even saw it drop to 20% at some times in v14 when it should have been 50% for example, and down to 50% when it should have been set to 100%, so what is shown in the log is really happening at the pump
also note that when I disable PWM in v14, the actual pump PWM is totally stable at about 95% over the whole pull, with a 100ms ramp up and ramp down in the PWM signal, when it turns on and off, however personally I would not ramp it off, I would only ramp it on, if your off throttle I would just cut it immediately, but maybe there is reason for the ramp off I am now aware of
Default 10-11-2019, 01:46 PM
Not really practical to evaluate on a thread but if you want to email in a couple examples I can look over it when I have the firmware in front of me to see what might account for the difference.
RMM RMM is offline
Car: 120i
Default 10-11-2019, 06:53 PM
posted in support a week ago with 3 example as well , can you check that or you will only respond by mail
"v14 PWM meth control unstable - 09-30-2019, 12:37 AM"
v14 PWM meth control unstable - N54Tech.com - International Turbo Racing Discussion
