Koolmoody Koolmoody is offline
Car: F80 M3
Default BM3 E30 OTS map with JB4 Map 8 log review - 08-01-2019, 09:49 PM
hello
im currently testing the ots maps from bm3 with the jb4 and i don't notice any difference between 91 stage 2 map and E30 map in terms of logs and dragy 100-200 times... so i just need some clarification as my times are slower than other forum members with similar tunes.
Mods:
BM3 E30 OTS map
JB4 map 8 (60 meth add)
meth injection (Dual CM5)
chargepipes
two step colder NGK plugs gapped to 0.18
weather is 26 degree Celsius with 70% humidity with 1100 DA
dragy times won't go below 7.2 secs 100-200.
any help would be appreciated
Default 08-02-2019, 09:16 AM
Log looks clean to me, you're certainly running more boost than your flash only map (see DME BT target vs boost).
Car: F80 M3
Default 08-02-2019, 09:47 AM
Thanks for the reply terry any idea why im running slow times 100-200 then if the log looks clean and there is no issues ? Im very confused
Default 08-02-2019, 05:35 PM
I don't see why it would be slower, no. Maybe car wants more timing? It's an M3 right? I'll move it to the right area BTW.
Car: F80 M3
Default 08-02-2019, 05:47 PM
Yes it's an M3 s55...i have no clue if it needs more timing i thought the log looked fine
Default 08-02-2019, 09:01 PM
Try loading up up our E85 BEF for example and doing a run for comparison.
Car: F80 M3
Default 08-02-2019, 09:23 PM
Okay will do thanks alot 😊
