Go Back   N54Tech.com - International Turbo Racing Discussion > Non-Engine Related > General Tech Support, Tuning Advice, Logs, and Help Me Posts
Reload this Page Recurring Code: 2C31 (Lambda probe in front of catalytic converter, trimming control)
Jamesholden Jamesholden is offline
Car: Bmw e92 335i
Default 06-19-2018, 12:56 AM
Someone solve this issue? I have the same issue i just updated firmware with latest version and after that all 02 sensors codes pop up and i dont know wat to do
Ps:sorry for my englesh! Thank you!
Car: '06 e92 335i
veer90's Avatar
veer90 veer90 is offline
Car: '09 335i sedan 6MT
Default 06-24-2018, 06:02 PM
Bump I'm having the same problem. single turbo though.
AFRs look fine on WOT but cruising normally at highway speed it will pop up after some time. I think it's O2 readiness / emissions / drive cycle related. All 4 O2 sensors are brand new.
I tried enabling single rear O2 in my BEF and it didn't appear to help. Any thoughts?
Default 06-24-2018, 09:48 PM
Did you reset adaptations ?
What are your FUD settings?
veer90's Avatar
Default 06-25-2018, 06:09 AM
I did, multiple whenever an issue came up. Sometimes with MHD reset adaptations (lambda sensor and lambda regulation), sometimes with JB4 (menu 1/2). Is there a difference which method I use or do they do the same thing?
My settings are:
bit0 - Disable steering wheel controls (NO)
bit1 - Disable wastegate adaption (YES)
bit2 - Enable E85 cold start fuel enrichment (YES)
bit3 - PI Tip In Enrichment Logic BETA (NO)
bit4 - Enable BETA Anti-Bog-Logic (Manual Trans Only) (NO)
bit5 - Block anti-lag from engaging off brake pedal. Use only volume down button (YES)
bit6 - Disable o2 pressure correction (NO)
bit7 - Disable lambda adaption reset each startup (NO)
Default 06-25-2018, 09:11 AM
My settings are:
FUD settings look right.
Try resetting both lambda options via MHD.
Is this happening during longer drives @ cruising speed ?
veer90's Avatar
Default 06-25-2018, 09:16 AM
Yes longer drives at highway speeds. The first time it happened I was actually trying to complete a drive cycle to set the O2 sensor monitor readiness, the part where it calls for 40-60 mph for 15-20 minutes.
Default 06-25-2018, 11:30 PM
Ok, Iíll dig Into this a bit more...
When you monitor, is one bank of your AFRs pegged @ 20?
What O2s do you have, stock? Upgraded?
veer90's Avatar
Default 06-26-2018, 08:02 AM
Ok, I’ll dig Into this a bit more...
Not pegged at 20, it will go to 17, then hover around 28. Car will feel like it's misfiring until I reset adaptations or clear the code.
If it helps, in general bank 1 AFRs seem to be slow to hit target. When driving I noticed it will oscillate around 14.7 before hitting target. Can go find a log if you need.
New Factory O2 sensors with ~300 miles on them. I'll also clean the MAP sensors and check the harness.
Default 06-26-2018, 08:20 AM
Find the log if you can- curious thanks.
Car: Bmw e92 335i
Default 06-28-2018, 12:18 PM
For me problem with o2 senssor its gone i upgrade my jb4 with g5 board and no more codes. Thank you
white330 white330 is offline
Car: 07 335i
Default 09-09-2018, 10:26 AM
Did you ever get this figured out? Iím having the exact same issue
Car: 08 535i
Default 07-17-2019, 06:46 PM
Same issue on my buddies 09 335xi. Car runs great! About to start trouble shooting, unless someone has the answer? No jb4 installed....
Lone Patrone Lone Patrone is offline
Car: BMW 135i
Default 10-30-2019, 07:16 PM
Bump. I have the same issue. Getting 2c31 code on my foxwell scanner. Emissions tests is showing P2096 code. I just put on catted AR ********* and 5" stepped FMIC. I do not have a tune on the car.
I am aware that the P2096 code means the car is "supposedly" running lean; i.e. most likely bad rear o2 sensor on bank 1, or ** gasket leak, or possible weak injector performance.
Where should I start to correct this issue? All advice welcome. TIA.
