Car: 11 135i
02-25-2019, 03:40 AM
Originally Posted by JacquesN55
Are you not happy with your current set up?
I would think it's a lot of coin and effort for a small gain?
Car: 2011 N55 135DCT
02-25-2019, 07:28 AM
I want to change my manifold to t3 twinscroll and do bigger turbo. At the moment im at 26 psi doing 450wkw. But i want more. So i want to go the GTX3584R. But dont want a laggy laggy turbo.
Car: 11 135i
02-25-2019, 12:49 PM
450kw but want more lol. Enough is never enough right.
Good luck with it all.
Maybe I PM you and buy your current RHD bm kit
02-27-2019, 02:04 AM
Im going with the GTX3584R 11 blade. 6762mm. Also changing my manifold to twinscroll. Will keep u updated
02-27-2019, 07:42 AM
I am at the same power level and want more. But not enough to change setups. Plus how much more is the question. Im thinking of just upping boost a little and add some NOS. I have plenty of octane.
I think you made the right choice between the options you are considering. I dont think it will be overly laggy, and you can always play with the vanos to gain a few hundred RPM spool.
02-27-2019, 11:03 AM
Thanks buddy. Ya think also it will be a awsome turbo. Keeping it Bottom mount and changing Twinscroll will help allot.
Car: N55 135i
02-27-2019, 11:18 AM
Hey Jacques, seems like a good choice and given our 3l displacement it should be marginal in the lower rpm range. If we were working with 2l then it would probably be different.
I think the gtx may also be worth a bit more power Vs the gt.
Are you still bottom mount? No issues with one of these and steering column?
02-27-2019, 12:13 PM
Yes the GTX3584R is a 1000hp turbo. My current GTX3576R is same size. Just smaller wheels. Yes i will still be bottom mount but changing my manifold completely and making it also twinscroll.
Car: 11 135i
03-28-2019, 12:50 AM
Mate, I'm about to go 6266. I gues you would strongly advise going twinscroll mani and turbo?
03-30-2019, 10:44 AM
Howzit. Im changing my setup. PTE 6266 T4 twinscroll 0.84 turbine and new Twinscroll Manifold.
Car: 11 135i
03-30-2019, 02:33 PM
That's exactly what I want to do
