slenser's Avatar
slenser slenser is offline
Car: 335xi
Default retorque oil pan bolts? - 02-24-2018, 03:39 PM
I've had a very small leak in my oil pan for some time now, but I just recently replaced the left motor mount using a 2x4 and a floor jack to lift the engine by the oil pan. Since then, I've noticed heavy oil spots on the ground. I really don't want to replace the gasket if I don't need to.
I don't think I've seen any thread of someone just retorquing the bolts on BMWs, but I've done this before on other vehicles that developed small leaks with some success.
Let me know what y'all think!
Thanks,
Sam
2010 535i E60 Alpine White M-Sport
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 02-24-2018, 05:02 PM
If you tighten the oil pan bolts down and it stops leaking, great. If it still leaks then you're right where you started, no harm no foul.
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
Boland01's Avatar
Boland01 Boland01 is offline
Car: 535ix
Default 02-24-2018, 08:20 PM
The oil pan bolts on the 335i are aluminum so be careful and don't over-torque them.
slenser's Avatar
Car: 335xi
Default 02-24-2018, 09:18 PM
Thanks guys!
Eric: That's what I figured too. It's just that I never see it done on these forums, so I didn't know if it was a big no-no.
Boland: I'll be using a torque wrench to make sure I don't.
135hoser 135hoser is offline
Default 02-24-2018, 10:15 PM
Hey,
I wish you the best of luck. Be careful as the single use, stretch-to-fit factory bolts may break, or loosen over time if you attempt to tighten/torque them again (to any spec)
I wish BMW had a core charge on the old stretched bolts to offset the cost of new ones.
E92 420 E92 420 is offline
Default 02-25-2018, 03:49 AM
Should be fine. I had my motor build recently and after torquing the pan bolts correctly I had oil seeping from gasket area on sump pan. Went back around and gave them all a nip up. Problem fixed and have had no issues since.
UK V8Bait Tuned
Built Motor
TD Turbo 335i
guancho34 guancho34 is offline
Car: 2008 335i e92
Default 02-25-2018, 05:20 AM
want to echo the word of caution on the aluminum pan bolts breaking / overstretching... the book says 8nm then additional 1/4 turn for the short ones and 1/2 turn for the handful of long ones along the transmission housing. i dont know what the final torque value becomes but you are pulling pretty good on the additional turn rotation. (8nm is practically nothing)
erichale's Avatar
Car: 335i coupe
Default 02-25-2018, 09:11 AM
Same here. No problems at all since.
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 02-27-2018, 05:25 PM
Could always just buy a set of new bolts and replace/torque them one at a time.
