N54 oil pan gasket question -
02-08-2018, 07:40 PM
when installing the new oil pan gasket do i NEED to use glycerin? I saw in a DIY a guy recommended using it, Im not sure if it is essential, or even what it does. if someone could explain further thatd be great
I just put the new dry gasket back in. Make sure you torque the bolts in the right sequence and correct spec. They are one time aluminum bolts so I would NOT reuse the old ones.
Did mine rod a long with turbo oil feeds and drains, dropped the subframe down and had moree than enough room to remove the sump. Didn’t use at sealers just bolted up dry
