slewis140 slewis140 is offline
Default Spark plug second opinion - 11-03-2017, 08:23 AM
Please review spark plug pic below. Just looking for a second opinion as I am not an expert! I feel like the darker one on the left(1) is running rich. Injector maybe? Also just changed valve cover gasket and new plugs. Thanks for your help.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 11-03-2017, 08:40 AM
Faulty injector highly possible
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Boland01's Avatar
Boland01 Boland01 is offline
Car: 535ix
Default 11-04-2017, 06:35 AM
Agree the one on the left looks like the cylinder is running rich. How many miles on the plugs? Just out of curiosity, are the plugs in order on how you pulled them? if yes is the one on the left from cylinder 1 or 6- Cylinder 1 is closest to the radiator and 6 is the one closest to the firewall on the car?
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 11-04-2017, 07:24 AM
Did plug one smell of gas?
Boland01's Avatar
Car: 535ix
Default 11-04-2017, 09:05 AM
Smell of gas on the black plug is a good indicator it could be an injector. Good point.
Default 11-06-2017, 02:51 PM
I need to check for the smell of fuel. I plan on pulling the #1 spark plug again soon to see if new one looks like the old one it replaced. The plugs are from left to right 1-6(1 being the black one closest to the rad). I dont have long starts or reduced power...but think I will change bank one injectors as im at 118000 and FBO and they have never been changed to my knowledge. Also O2 sensors just went...connected I wonder. You slap some fresh snails on there and it all goes to ****.... thanks everone for input!
Default 11-09-2017, 03:39 PM
Case closed. Injector on spark plug 1 was dirty and looked horrible. The injectors got cleaner looking as I worked my way through the cylinders. Replace index 08/06 injectors on bank one with index 12. Smoother now and O2 sensor codes haven't returned.
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 11-09-2017, 03:45 PM
Plan on replacing bank 2 injectors soon. Old injectors and new ones don't play nice together. 12s and 11s should be fine but not anything older than that.
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
