robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default Inside pics of a N54 PCV system - 07-10-2014, 11:52 PM
I decided to replace valve cover so I cut apart old one to see how clogged/dirty PCV was and all I can say is wow! It was clogged in a lot of areas and can see how it would clog easily.
My car specs cover came off
1. 135,000 miles
2. valve cover gasket replaced once
3. always premium gas
4. Motul oil changed every 4,000 miles.
5. Extremely well maintained
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 07-11-2014, 02:15 AM
Very cool
335is DCT
Stucks Stucks is offline
Default 07-11-2014, 05:49 AM
Oh wow. I think you have discovered another important preventative maintenence item that we need to watch out for! Is this something that can be cleaned or something that just should be replaced?
Current: 2008 e92 335i coupe.
Luke0818's Avatar
Luke0818 Luke0818 is offline
Default 07-11-2014, 06:12 AM
Rob I admire you for all those DIYs. You do keep that N54 engine looking beautiful. Thank you for the info!!!
2008 e93 MODS: BMS JB4 G5 ISO, bms trunk, RB PVC, Lukeperformance flash, mount meth kit, OCC, ******* ********, VRSF 7" FMIC, charge pipe, DCI, Alpina flash,
Car: 2007 BMW E90 335i
Default 07-11-2014, 07:07 AM
How easy is it to clean the ports in the valve cover?
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 07-11-2014, 07:13 AM
Did you notice any hairline cracks in your valvecover? I did mine just before 100k and had a few cracks it seemed developing on it. Plastic valve covers are always a good idea to change out, its just buying those little bolts that KILLS you
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar dp's SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
robc1976's Avatar
Car: 2007 335i
Default 07-11-2014, 10:34 AM
no way to access this, has to be replaced. Clogged PCV can cause a ton if issues....crank case pressure, issues with turbos ect.
Alex!'s Avatar
Alex! Alex! is offline
Car: 135 I N54
Rob Amazing your topics!! I follow your DIY to change my RB Turbos.
Wich Motul do you use? I use xcess 5-40...
135I - 6 MT -JB4 G5 ISO Map 3 - BB Race Flash - Riss Rasing ******* DP - AFE CAIs - BMS SDL - 93 Octanes - Sistem X wather meth - SPEC 2+ - RB Twins!!
robc1976's Avatar
Car: 2007 335i
Default 07-11-2014, 10:36 AM
Valve cover comes with bolts and gasket from BMW.
robc1976's Avatar
Car: 2007 335i
Default 07-11-2014, 10:37 AM
awesome! I use access it 300V.
robc1976's Avatar
Car: 2007 335i
Default 07-11-2014, 10:38 AM
honestly no way to clean them...If you blue the ports it will just go into the PCV system father....sucks.
robc1976's Avatar
Car: 2007 335i
Default 07-11-2014, 10:39 AM
I appreciate that, more info we have the better the platform.
raceyBMW's Avatar
raceyBMW raceyBMW is offline
king of the hills
Car: E92 335i
Default 07-11-2014, 10:46 AM
Awesome detective work, things like this are great for the community
You don't think we could soak the valve cover in degreaser overnight to clean? I occasionally do the same thing in my E34 M60 intake manifolds because those PCV plates love to spit oil into the covers and make a mess....it works very well to clean them out (soak in degreaser, then rinse).
beakmoney beakmoney is offline
Car: E90 LCI M-Sport
Default 07-11-2014, 06:07 PM
Have you considered the rb pcv setup?
Wedge1967's Avatar
Wedge1967 Wedge1967 is offline
Car: '07 335i e92
Default 07-11-2014, 06:08 PM
Nice... :-)
robc1976's Avatar
Car: 2007 335i
Default 07-11-2014, 06:20 PM
I had one of the first ones, I am local to him lol!
robc1976's Avatar
Car: 2007 335i
Default 07-11-2014, 06:21 PM
You may be able to do that but if you have it off I would just replace it.
AUbeast86's Avatar
AUbeast86 AUbeast86 is offline
Car: 2007 335i e92 Coupe
Default 07-12-2014, 09:40 AM
Awesome stuff man! Glad I went ahead and replaced mine last month.
robc1976's Avatar
Car: 2007 335i
Question 07-12-2014, 01:46 PM
Total piece of mind!
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 07-12-2014, 02:15 PM
great post ! question off post what do you think of Motul 8100 X-cess 5w40 or Castrol edge 5w40 ?
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE dp, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
Default 07-12-2014, 08:22 PM
Great information here!
suspenceful's Avatar
Car: 2008 BSM 135i
Default 07-12-2014, 10:01 PM
How much does a new valve cover kit cost?
robc1976's Avatar
Car: 2007 335i
Default 07-13-2014, 01:46 AM
Motul no question.
robc1976's Avatar
Car: 2007 335i
Default 07-13-2014, 01:47 AM
386.00 & comes with gasket and bolts
robc1976's Avatar
Car: 2007 335i
Default 07-13-2014, 01:49 AM
thanks T
