(#51)
EdHunter69 EdHunter69 is offline
Car: e92 335i
Default 08-12-2013, 01:20 PM
they are OEM m3 Parts fits for e9x dunno about e8x but part no. are:
64-31-6-958-817
64-31-6-958-818
64-31-6-958-815
64-31-6-958-816
64-31-9-159-606
51-71-8-045-623
robc1976's Avatar
robc1976 robc1976 is offline
Default 08-12-2013, 01:56 PM
Originally Posted by EdHunter69
Nice Mod, i did m3 conversion last week, if not it would be my first Option.
64-31-6-958-817
64-31-6-958-818
64-31-6-958-815
64-31-6-958-816
64-31-9-159-606
51-71-8-045-623
thanks man!
Marz Marz is offline
Car: BMW 335i
Default 08-12-2013, 06:04 PM
I like the m3 option, but I think the point of this was to maintain easy access to DME..
BMWpurist's Avatar
BMWpurist BMWpurist is offline
E90post reject
Car: Overpriced Econo Box
Default 08-12-2013, 09:32 PM
64-31-6-958-817
64-31-6-958-818
64-31-6-958-815
64-31-6-958-816
64-31-9-159-606
51-71-8-045-623
What's what on that list of parts? Thanks!
My friend died doin what He loved,Heroin.
raceyBMW's Avatar
raceyBMW raceyBMW is offline
king of the hills
Car: E92 335i
Default 08-13-2013, 12:14 PM
64-31-6-958-817
64-31-6-958-818
64-31-6-958-815
64-31-6-958-816
64-31-9-159-606
51-71-8-045-623
How much did that run you for the swap? This is pretty nice.
ElSaigel ElSaigel is offline
Car: E93 335i '07
Default 08-14-2013, 10:04 AM
So with M3 mod you could probably empty BMW OCC without removing the cowl? ...I as well would like to know how much those parts cost.
Car: e92 335i
Default 08-14-2013, 10:42 AM
With the mod ist's just 3 screws.
The complete Setup is around 100$.
Yes u can Access the occ, friend got it installed.
I am very happy with this mod.
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 08-14-2013, 11:09 AM
Only $100? On realoem, microfilters alone are $127. Let us know if you got these from somewhere cheaper.
http://www.realoem.com/bmw/showparts...=64&fg=10&hl=2
|2007 E92 SGM 335i|
Cobbv3 • BMS DCI & OCC • VRSF *** & FMIC • E85 • Custom Backend & Alpina TCU flash • ER CP • RB PCV+Cap
Walbro 255 • Rohana RC5 19s • Nittos 555 245/275 • Cyba Scoops • LUX V3 • M3 Cowl • ST Coils • LCI Tails
Car: e92 335i
Default 08-14-2013, 11:23 AM
Hi got em form ebay, but i am form Germany
Slavo Slavo is offline
Default 08-14-2013, 12:46 PM
Can you spot the small engine bay accessory Burger labs is whipping up?
hey terry i tried installing the jb4 with g5 board last night i connected everything perfectly it didnt want to work at all then i connect the 2 sensor for stock and the car cranked right up , is this usual to happen? I DONT know whats going on maybe it can be something with the board or? Can you please help me out call me 708 7902021!! i cant pm you either.
BMWpurist's Avatar
E90post reject
Default 08-14-2013, 04:40 PM
I was thinking the same thing, I'm not gonna spend close to $300 on OEM covers and filters if Terry's solution will be around $150.
bigdaddycain's Avatar
bigdaddycain bigdaddycain is offline
I love me some used mods!
Car: nothing at the moment....
Default 08-15-2013, 05:09 AM
Try Tischer www.getbmwparts.com as their prices have to be better than REALOEM.com. I only use REALOEM.com to reference part numbers, not prices.
COBB AP|CP-e|ETS|ER|Forge DVs|KW V1|M3 Sways|BBS CH|BMS|
aquajon aquajon is offline
Car: N54 e90
Default 08-15-2013, 08:23 AM
$226.86 from getbmwparts.
Car: 2007 335i E92
Default 08-15-2013, 08:27 AM
Thanks. Prices are a lot better there. I'll wait for Terry to finalize his product first before I decide.
|2007 E92 SGM 335i|
Craig Craig is offline
Car: 2007 335i Coupe
Default 08-15-2013, 07:16 PM
If it helps.....I'm able to reach the oil catch can, unscrew, remove, clean and fully return it while leaving the complete cowl and the dual cone filters in place. Attack it from the driver's wheel side! Tilt it.
Space Gray, 6MT, Sport and Premium Pkg., JB4 G5 ISO, VRSF 7" FMIC, BMW Performance Exhaust, BMS DCI - OCC - CDV - and Clutch Stop, M3 Spoiler, Clear Bra, 20% Tint
deamon32 deamon32 is offline
Default 08-19-2013, 02:16 PM
Must have this!
I have been too lazy to put my cowl back on for the better part of the last 3 years now.
LeMans 135i ///M-sport 6MT
BMW SSK - CDV - Golf Tee
18" CSL Rep's - 22/255 Michelin
MathR601's Avatar
MathR601 MathR601 is offline
Default 08-20-2013, 12:34 PM
I want it too
JB4 G5 ISO, BMS DCI, 3" AR ***, E85, BMS OCC, BMS Spacers, ECS Blackout Kidney Grille.
beakmoney beakmoney is offline
Car: E90 LCI M-Sport
Default 08-27-2013, 06:00 PM
Not to muck anything up for Terry, but I just received my m3 cowl and filter cover parts from reeves bmw, won't disclose the price but it was cheaper than the realoem/tischer options mentioned previously including shipping...all oem including filters.
Will post review after I've driven the car!
Default 08-27-2013, 06:02 PM
That's a good option too. Just too heavy for my tastes, though.
Lifted07Duramax Lifted07Duramax is offline
Car: bmw 335i
Default 08-27-2013, 06:04 PM
Originally Posted by robc1976
I see a see a 10 degree drop in oil temps and that is over my oil cooler. It does let out heat.
How does putting just those bolt on cabin filters drop oil temps? Am I missing something here lol
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
Default 08-27-2013, 06:10 PM
Without the cowl, there is a ton of air that gets let out at the back of the hood. I will be testing this later with removing the weather strip and otherwise leaving the ducts on.
bmsportzn135i's Avatar
bmsportzn135i bmsportzn135i is offline
Default 08-28-2013, 02:53 AM
Terry, any update on these filters?
I would love to remove my cowl on race days. Theres just too much heat trapped under the hood.
537.75HP 540.63TQ
Mick J Mick J is offline
Default 08-28-2013, 02:24 PM
Terry, any idea how for out this is? I'm ready to order whenever its ready to go because I'm thoroughly tired of taking that thing on and off.
Gone but not forgotten: 447WHP - 458WTQ: JB4 G5 ISO / BB-BMS flash / AR DP / ETS 5in FMIC / ER chargepipe & Tial BOV / BMS 2.2gal meth / AFE intake / BMS Thermostat / BMS OCC / Custom exhaust - removed resonators, 3.8" Cyba tips, single center cutout
Wheels: VMR V710 19x8.5 ET20 & 19x10 ET25 / Bridgestone Potenza S-04 Pole Positions 245/35/19 & 285/30/19
Default 08-28-2013, 02:56 PM
300 sets are en route to us. Once we have them we'll post them up on the site.
Default 08-28-2013, 09:54 PM
Awesome, i want a set!
537.75HP 540.63TQ
