(#101)
Default 04-25-2013, 01:47 PM
Here is a photo of the stat installed in our 2013 F30 335. It's been in there for a few thousand miles without issue.
raceyBMW's Avatar
raceyBMW raceyBMW is offline
king of the hills
Car: E92 335i
Default 04-25-2013, 08:15 PM
Question, do you need to drain oil to pop this cover of without oil spilling? Or is there no oil in that chamber unless the tstat is at operating temps?
Bobdudeman1988's Avatar
Bobdudeman1988 Bobdudeman1988 is offline
Car: 07 E90 335i
Default 04-25-2013, 08:17 PM
No just pop the covet off when its coldn little to no oil should flow out
raceyBMW's Avatar
king of the hills
Car: E92 335i
Default 04-26-2013, 12:42 PM
Thanks! I will look at mine this weekend.
jim66 jim66 is offline
Car: 335is
Default 04-27-2013, 02:52 PM
Installed mine yesterday, temps came down to 200-210 from 240-250... i like.
muzzammil15 muzzammil15 is offline
Car: 07 e92
Default 05-03-2013, 09:28 AM
Terry are you going to make one for us older T-stat guys?
Default 05-03-2013, 10:18 AM
Yes we're working on it. Sent out a new tstat housing and waiting for the old one to get back so we can get to work.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 05-03-2013, 11:42 AM
Can't wait till I open up mine, 09/2006 built. Just picked up my car from recent wreck, and about 55 outside, temp went up to 240, which is ok to me, but if that can stay at around 210-220 all the way thru commute, it's super!
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 05-06-2013, 06:42 AM
I should be knocking this out this week. Worked 100+ hours last week and never saw the daylight to do it. Gaskets finally came in and I'm ready.
Sorry for the delay.
Default 05-06-2013, 11:33 AM
No problem. We're ready to go as soon as it gets here.
Slowb00st Slowb00st is offline
Default 05-07-2013, 12:18 PM
Originally Posted by NICKTENN
Anyone attempt this on an F30? I just tried and I swear the the thing is too long. Tried 4-5 times and decided that there's no way I'm doing something wrong. The cap just doesn't come close to closing (somewhere in the neighborhood of a 1/4" -3/8" off). Help.
Same thing happened to me on a e90 335i by hand it would still have the gap but slowly tightened the screws alternating them and it got in all the way. Could be the case of a bit to thick coating.
So far no leaks that I can see. On a 77f rainy day it hits 220f when normally it would be at 230-240f with the stat. Not much of a change but at least it's something.
shaunlsone shaunlsone is offline
Car: 09 e92 335i sport
Default 05-07-2013, 11:02 PM
does the oil have to be drained to install?
Default 05-07-2013, 11:56 PM
No
najin23's Avatar
Car: 335i CDV
Default 05-21-2013, 06:58 PM
Originally Posted by Vroom
Here is the set up from my 09/06 Build. It's different than the #1 Tstat. My oil temps are normally 210-220 but < 250 when tracking for 1/2 hr.
Attachment 12813
Just confirmed my stat is same as this....different than #1 nor #2
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Car: 07 e92
Default 06-03-2013, 03:21 PM
any update?
Default 06-03-2013, 04:01 PM
On 2007 models? I know we have the housing but not sure where we are on machining for the stat for it. Will update the thread when I have a firm date though.
najin23's Avatar
Car: 335i CDV
Default 06-03-2013, 08:00 PM
I tried to put the pin the shorter side first. Then the disc portion of the pin sealed the mid section of the inner housing b/w the inlet and outlet holes completely. But the longer end was simply too long to close the housing cap. In this case, can I simply grind or cut the pin to make it shorter?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Stucks Stucks is offline
Default 06-03-2013, 08:01 PM
Prob my fav mod done to this car so far above everything else. Oil temps are so much cooler.
Current: 2008 e92 335i coupe.
Young_Man Young_Man is offline
Car: E90
Default 06-04-2013, 07:19 PM
I can't wait til these are available for us with 07 models
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
Administrator
Car: M340i,X5,Raptor,C7 ZR1
Default 06-04-2013, 07:43 PM
Did you check yours and it was #1 in the pic?
robc1976's Avatar
robc1976 robc1976 is offline
Default 06-04-2013, 08:23 PM
Jason, my buddy has a ER sport cooler and the thermostat looks like #2 but the rod is recessed in the top (not sticking out) and the housing had a pretruding part that would meet up with recesses rod and when BMS thermostat is installed it is really hard to get housing back on.
Administrator
Default 06-04-2013, 09:14 PM
That photo is a little confusing. The #2 stat looks like the attached pic when you take it out of a cold car. Those were taken out of a warmer car.
Bellow is an update picture of the #2 thermostat.
najin23's Avatar
Car: 335i CDV
Default 06-05-2013, 06:04 AM
I am really considering modifying the bms thermostat pin by shortening the longer end so that I can close the housing cap. My housing snugly fits the bms pin's disc portion right in the middle between the inlet and outlet of the oil passage only if I put the shorter end in first. What do you think Jason?
I have a 09/2006 built e92 with the factory oil cooler.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Administrator
Default 06-05-2013, 11:32 AM
You can grind a little off of the top until it fits. Your lid is tapered more than normal on the inside. Try it but don't take off too much.
najin23's Avatar
Car: 335i CDV
Default 06-05-2013, 12:13 PM
Certainly, will let you all know how it went.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
