(#76)
Razodo Razodo is offline
Car: 2008 335
Default 04-09-2013, 08:21 PM
Originally Posted by yandyr
I did mine, the car was somewhat warm, not really hot, no mess was made. I can at least confirm that driving around, even doing 4-6 logs 3rd gear to redline the temps dont' go beyond 220-230, then fall right back to 220.
If this stays true for the track (road course), then my temps wills tay within the 250-260 range and that's acceptable to me. But will test it out there on 2/10.
Yandy,
Did you try this in the track? How where your temperatures?
Thanks,
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 04-09-2013, 08:31 PM
Just did a half mile event using this. With this and max cool the car was almost cooling below operational temp in between runs lol.
I can definitely see that I'll be swapping back to stock for winter. Took 12 miles on the highway to warm to 160* the other morning (~40* outside).
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
Car: 2008 335
Default 04-10-2013, 03:19 PM
Anybody used it in a road track? Temps before vs after?
WDBi's Avatar
WDBi WDBi is offline
Car: any
Default 04-11-2013, 12:23 AM
for an 08/07 build date auto is this plug and play or does it need to be cut
Always listen to experts. They'll tell you what can't be done and why. Then do it.
WDBi's Avatar
Car: any
Default 04-11-2013, 01:23 PM
just installed this today. All i can say is wow. Before oil temps would go up to 240 then go past it and then back to 240 and it was just a back and forth the oil cooler turning on temps going down oil cooler turning off and repeat. Now temps stay much cooler i dont want to say a number because it varies what you are doing as well as ambient air temp which right now is 90 here in florida. This mod wont eliminate the need for an upgraded oil cooler for people who do road course days but it certainly helps keep the temp down on hard drives and pulls
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 04-11-2013, 03:25 PM
Sounds like your old oil thermostat was binding up.
My oil temp never just cycles up & down.
WDBi's Avatar
Car: any
Default 04-11-2013, 03:35 PM
well it would go over 240 the thermostat would come on and the oil temp could come down and then raise again because the thermostat was off again
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 04-21-2013, 03:49 AM
Originally Posted by Jason @ BMS
I am finding out some 2007 models might actually have the correct factory thermostat needed to swap out with the BMS low temp stat. If you have a 2007 1, 3 or 5 series with a factory oil cooler you might be in luck. You just have to check before ordering.
I'm thinking the early 2007's that have the #1 Tstat open at a lower temp. (220-230) and also have a 210F mid point on the oil temp dash gauge.
Just curious if anyone w/ the #1 Tstat can confirm their oil gauge mid point is 210F?
Car: 335 coupe
Default 04-21-2013, 01:25 PM
2007 here, gauge midpoint is 210F. I had the #1 thermostat.
muzzammil15 muzzammil15 is offline
Car: 07 e92
Default 04-23-2013, 03:28 PM
03/07 build and I have the old thermostat.
Craig Craig is offline
Car: 2007 335i Coupe
Default 04-23-2013, 05:15 PM
This build date sharing could prove helpful. Mine is an August 2007 build date and I have the newer #2 style thermostat.
The midpoint on my dashboard oil temp gauge is 250 degrees.
Space Gray, 6MT, Sport and Premium Pkg., JB4 G5 ISO, VRSF 7" FMIC, BMW Performance Exhaust, BMS DCI - OCC - CDV - and Clutch Stop, M3 Spoiler, Clear Bra, 20% Tint
Vroom's Avatar
Car: 335i 318ti
Default 04-23-2013, 05:29 PM
+1
My #1 Tstat & 210 midpoint is an 09/06 Build.
Default 04-23-2013, 05:31 PM
We need to get our hands on one of those early 2007 housings to make a special stat for them. If anyone has the old housing and is willing to swap it for a free new housing with our low temp stat in exchange, email me. Once we have the old housing and stat in house we can design something for it.
Vroom's Avatar
Car: 335i 318ti
Default 04-23-2013, 05:32 PM
Is the gauge midpoint 210?
What your oil temps on the highway?
boostaholic boostaholic is offline
Car: 2008 AW e92 335i
Default 04-23-2013, 06:11 PM
Have mine installed for a couple days now just to see back to back pulls, spirited driving, and city driving. My temps never got above 230 degrees and usually sit at 190-205 or so. AMAZING product especially for us guys in the summer down here in Texas!
E92 A/W JB4 G5 ISO w/WEDGE PERFORMANCE FLASH+FBO+RB's+LSD+60% E85/93 mix 508whp 531 ft lb torque 11.73 @121mph on street tires with a 2.1 60'!!! NO METH!
Vroom's Avatar
Car: 335i 318ti
Default 04-23-2013, 07:03 PM
I don't know where others are at but my early Tstat opens just past the 210 midpoint on the gauge.
Car: 07 e92
Default 04-23-2013, 10:02 PM
Nope my midpoint is 250. Terry if you guys can fab one up for us early build guys I will definitely buy one.
raceyBMW's Avatar
raceyBMW raceyBMW is offline
king of the hills
Car: E92 335i
Default 04-24-2013, 07:44 AM
I can't see why the oil temp midpoint would have anything to do with this (this is not the oil temp stat, it is just for the oil cooler). The midpoint on the gauge was just shifted, but the oil still warmed to the same temp (240 to 250) whether or not your gauge was centered at 210 or 250.
Car: 335 coupe
Default 04-24-2013, 09:46 AM
I will send my early version in
-Alex
Default 04-24-2013, 09:52 AM
OK looks like we have someone.
Car: 07 e92
Default 04-24-2013, 11:05 AM
Terry I am in. Once you fabricate one for the older T-stat I will buy one.
Vroom's Avatar
Car: 335i 318ti
Default 04-24-2013, 12:14 PM
Here is the set up from my 09/06 Build. It's different than the #1 Tstat. My oil temps are normally 210-220 but < 250 when tracking for 1/2 hr.
raceyBMW's Avatar
king of the hills
Car: E92 335i
Default 04-24-2013, 12:31 PM
Mine is a 10/06 build, with 210F as the center, and my temps easily get to 240-250 (I have an oil cooler that was retrofitted as part of the early AT's w/ZSP that did not receive one)
Same here, if you make one for the older style Terry, I will get it.
NICKTENN's Avatar
NICKTENN NICKTENN is offline
Car: F30 335i Sportline on order
Default 04-24-2013, 05:11 PM
Anyone attempt this on an F30? I just tried and I swear the the thing is too long. Tried 4-5 times and decided that there's no way I'm doing something wrong. The cap just doesn't come close to closing (somewhere in the neighborhood of a 1/4" -3/8" off). Help.
2016 F30 340i M Sport Alpine White, JB4
RIP 2012 F30 335i Sport Line Mineral Gray, JB3/Stage 1
Stock 335i 1/4 mile time
Default 04-24-2013, 05:13 PM
We have one on our F30. If you need assistance email photos to jason@burgertuning.com. Ensure you're sticking the long end in first and that there are no burrs, etc, interfering with the lid.
