Car: N54 135i
05-08-2013, 02:27 AM
Hi Rob,
Any update on these, or is it looking like the 15th still? I've just sent you payment for one to be sent to me in the UK.
Having my intake ports cleaned as we speak, so want to try to keep them as clean as possible.
Many thanks
Russ
P.S. Out of interest, does anybody have any ideas on keeping the intake ports clean? I know Seafoam does nothing to a gunked-up intake port, but what about if it's used regularly, like once a week or once a month after the ports have been cleaned? Just to stop it building back up? I really don't want to be spending a load of money to have them cleaned all the time, and here in the UK nobody does it. I'm the guinea-pig car for my local BMW stealer, and it ain't cheap.
05-08-2013, 10:42 AM
Originally Posted by TheRuss
Hi Rob,
Many thanks
Russ
methanol had kept mine clean....it is not hats to do the valves yourself. I do mine every 15,000 miles.
Stalker
Car: 335I
Got your payment thank you. My supplier is telling me that their ETA (to their warehouse) is 5/15. At that point they ship to me and I need a 1 day turn around. I have a bunch of these sold and am just as anxious to send them out as you guys are all to receive them. Unfortunately this backorder has caused many dated orders and thus many messages requesting status. Doing the best I can to get them all out, just in a holding pattern though at the moment.
Hi Rob,
Many thanks
Russ
Car: N54 135i
05-08-2013, 11:35 AM
Really? Looking on 1Addicts it looked a pretty tricky and time consuming process, removing the intake manifold and everything around it, then trying to turn the engine to close ports etc. Not sure I'd find it that easy.
Car: N54 135i
05-11-2013, 03:42 PM
Out of interest, if oil catch cans are installed on the positive crankcase ventilation side, but most of the gunk comes on negative ventilation, can't an ICC be put on that feed as well?
Stalker
Car: 335I
05-11-2013, 03:49 PM
Unfortunately not without lots of modifications to the whole PCV system (mainly that it is primarily built into the valve cover).
Rob
05-16-2013, 04:37 PM
any news rob??
Stalker
Car: 335I
05-16-2013, 08:14 PM
I wish. Big headache this has become. Will call again tomorrow. May be big trouble in river city with the supply on these valves and the manufacturer.
Stalker
Car: 335I
05-18-2013, 09:39 AM
FYI- I just ordered a large amount of the valves (the "core" component) from 2 other separate suppliers. I will await these orders to be shipped and expect it will be a week or less before that happens. If they come back and tell me the same thing (that the manufacturer "seems" to be tapped out on them), then I have a couple options as follows:
1) start ordering some "aftermarket" items that are supposed to function at least the same as the original and check for fitment.
2) redesign using a different "core" valve.
3) refund customers and discontinue item until a source is obtained.
I really do not want to jump on any of these options until we know it is requirement. I have loads of $$ into the other components that make up these valves already as I was trying to prepare for all these orders but now maybe left holding the bag if the source doesnt pan out which will be a drag, so I'm hoping to these other sources (at least one of them!) come through. Should know this within one more week. Thanks again for all the patience.
Rob
Stalker
Car: 335I
05-20-2013, 03:03 PM
Great news. Just got an update that another supplier says they are good to the tune of about 50 units. This will get me about caught up.
Will let you all know when actually in hand...
JB4
05-20-2013, 09:33 PM
Good to hear Rob!
05-20-2013, 09:44 PM
Yippee, i cant wait! That really is great news, thanks Rob!
 537.75HP 540.63TQ
Car: 08 335XI
05-22-2013, 08:05 AM
Great news!!
Stalker
Car: 335I
05-24-2013, 08:45 PM
Good news is that 10 came in today! I am still awaiting on more, but just happy that at least "some" trickled in. I expect that all other materials will be in on Tuesday, and should be able to get these all shipped out Wednesday if that is the case.
Rob
JB4
05-26-2013, 12:17 PM
Sweet!
05-26-2013, 02:53 PM
Would a really bad/clogged pcv affect timings a lot?
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
Stalker
Car: 335I
05-27-2013, 11:21 AM
I would not think so. But if you have that issue its best to just fix it for the sake of fixing it and then see if it resolves whatever else.
Car: E92 335i
05-27-2013, 11:34 AM
Any updates on PCV for me ?
Stalker
Car: 335I
05-27-2013, 11:45 AM
All will be shipped off this week.
Car: E92 335i
05-27-2013, 01:54 PM
JB4
05-27-2013, 03:50 PM
Stalker
Car: 335I
05-31-2013, 08:02 AM
Bad news is it is not going to be this week...
Good news is that I do finally have the tracking information for the remaining components, due in 6/4. This means I should be able to have most if not all of these out by 6/5 or 6/6 latest.
Sorry, this has literally been a 2.5 month backorder situation. Apologize for the delays, looking forward to getting these all out to you guys.
Rob
Car: e92 n54 xi
05-31-2013, 09:44 AM
Rob
No worries Rob, we know you're doing the best you could given the circumstances. We appreciate your hard work and constant updates. I'm sure I speak for most when I say we are willing to wait for QUALITY products which you have definitely provided the n54 community.
Car: E92 335i
05-31-2013, 09:47 AM
Throw in some goodies for us who wait and wait and wait and wait but remain super cool ...
I`ve been waiting forever on many parts ... you are not the only one...I dont care anymore ...
But you have the balls to be honest ... better that then just letting us hang there and wait
Stalker
Car: 335I
05-31-2013, 10:50 AM
Thanks man. Truly appreciate it. It is nice to feel trusted from others who have their hard earned $$ on the line. I know there are quite a few of you who have these orders aged quite abit and have been very patiently awaiting without a peep. I never thought it would go this long, now I'm just happy to see the light at the end of the tunnel finally...
I'm all about calling a spade a spade, and I try my best. Fortunately there is a thread like this where I "hope" most who have purchased follow along for updates.
I can see how some other vendors may not follow up as it is very hard to give follow ups on a one off basis. If I had to one off updates to every person throughout this ordeal it would've been 50x as stressful as it has been already... and nothing would ever get done in the meantime.
I have all packages ready, just awaiting the contents... there are QUITE a few of them. This still amounts to many emails requesting updates, which takes much time to address them all so sorry if I come off short at times to those who have. I am praying I am stocked well enough after this is all done to where we don't run into a traffic jam like this again... that is for sure!
