vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default Rear toe & camber lockdown kits available for E and F chassis $135 + s/h - 08-10-2017, 12:55 PM
When the suspension is modified (firm dampers, stiff springs, solid RSFB) and matched with sticky tires the eccentric bolts become a weak point. You hit a pothole? You go off track? You do a lot of hard launches? Guess what? You alignment will get off! The stock eccentric bolts for small camber adjustments tend to slip under high cornering loads, causing changes to the rear alignment. My rear camber lockdown kit eliminate the stock eccentric bolts to keep your rear alignment where you set it. These lockdown plates will ensures zero change in alignment even in the toughest driving conditions. The plates are CNC machined from stainless steel and supplied with CAD plated grade 10.9 hardware for absolutely zero-slip. Bolts are M14x2x100 with self-locking nut. The shims are installed with the U shape pointing down and can be used in either face up or face down position that will yield a total of 9 possible fixed camber settings because the plates are cut into 1mm increments. Please note that these plates won't allow for more negative camber than what BMW designed the rear end for. Compatible with all M and none M E-chassis and F-chassis.
vwetish's Avatar
Default 08-10-2017, 12:57 PM
Example of slid eccentric bolt and the result from it.
quick99si quick99si is offline
Default 08-12-2017, 09:43 PM
Awesome seller
VRSF ** | VRSF 7" FMIC | ER CP | HKS BOV | BMS DCI | BMS OCC | JB4 G5 | CM10 | Alpina B3 Trans Flash
vwetish's Avatar
Default 08-18-2017, 06:20 AM
I'm ready to start on new orders.
vwetish's Avatar
Default 09-14-2017, 02:39 PM
New sets ready!
N54QC N54QC is offline
Car: 07 BMW 335i
Default 09-19-2017, 01:16 PM
Do you get all the spacer plates in the picture above and how do you know which one you'll need to use? I'm assuming the mechanic will drop the correct one in while doing the alignment?
vwetish's Avatar
Default 09-19-2017, 01:34 PM
Total of 10 per side (2 sets of 5 shims with different offsets) that can be used in either the normal orientation, or flipped, resulting in 9 different positions, divided into 1mm increments. Mechanic will select the appropriate combo depending on the rear comber desired.
hughrd1_e90 hughrd1_e90 is offline
Car: 07 335xi
Default 02-03-2018, 10:17 PM
Are these still available?
vwetish's Avatar
Default 02-04-2018, 08:49 AM
Yes, I have two sets left.
vwetish's Avatar
Default 02-23-2018, 09:34 AM
One toe and two camber sets available. $135 shipped with in USA
vwetish's Avatar
Default 03-27-2018, 05:59 AM
Only one camber kit left.
vwetish's Avatar
Default 04-04-2018, 06:42 AM
I have made more camber lockdown plates
vwetish's Avatar
Default 04-12-2018, 07:30 AM
Currently only one camber kit left. Order now.
vwetish's Avatar
Default 05-08-2018, 11:08 AM
One camber kit left!
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 05-11-2018, 01:13 PM
Do I need both kits or just the camber kit. I had an issue exactly as pictured above.
The post is for camber kits, but toe kits are mentioned in the post. I'm not that familiar with alignment.
vwetish's Avatar
Default 05-11-2018, 02:47 PM
Currently I've sold all toe kits. I can have set made for you. Let me know.
Car: 07 335xi
Default 06-30-2018, 10:57 AM
Hey if anyone is interested I have my toe and camber kit available. I never got around to installing mine. Hit me up if your interested. 6465935812
ajsmithvmi ajsmithvmi is offline
Default 07-12-2018, 12:48 PM
Any more camber kits available?
Car: 07 335xi
Default 07-12-2018, 12:59 PM
I have 6465935812
vwetish's Avatar
Default 07-12-2018, 01:25 PM
Currently I have two available.
Default 07-18-2018, 08:46 AM
Kit received, thanks. I will be installing myself, any general correlation between mm of shim used and camber angle on the e90/e82 chassis?
vwetish's Avatar
Default 07-18-2018, 05:12 PM
I don't install these so honestly don't know exact numbers but feedback from shop is 0.1 to 0.3 per mm depending on ride height.
