geniushmp geniushmp is offline
J_Park
Car: 2021 520i (B4620B engine)
Icon1 2021 520i B4620B MAP 3 & 5 logs - 10-13-2021, 02:26 AM
I got my jb4 installed today
I have 520i with B4620B engine (same as 30i engine ?)
I tried map3 and map5
Please review the logs, Thanks
0-60 tested
stock - 7.6 sec (184horse power)
map5 - 6.3 sec (same as 530i with 252 horse power)
J_Park
Default MAP 5 logs on firmware ver.20 - 10-13-2021, 06:58 AM
MAP 5 logs on firmware ver.20 attached!
Car: Evo VIII
Default 10-13-2021, 09:46 AM
Car looks to be running just fine. WGDC and trims are getting high, so for your current setup you are pretty much maxed out on what the car can currently handle.
J_Park
Default MAP 3&4&5 3rd gear WOT - 10-14-2021, 08:28 AM
I just did 3rd gear WOT in MAP 3, 4, and 5
Which map is best for my car?
Looking forward to warm support!
I'm really beginner to JB4.. difficult logs... Thanks!
Car: Evo VIII
Default 10-14-2021, 10:21 AM
Map 3 looks best and probably felt the best. If you are looking for some more power, try Map 6 with 7 psi additive. If you try map 6, please upload another log to make sure everything looks good.
