Z4ROWEN Z4ROWEN is offline
Car: BMW E89 Z4 N20
Exclamation Z4 E89 N20 JB4 EWG ISSUE - 08-06-2021, 05:50 AM
I have an issue with connecting with jb4 to ewg.
I got fault code 002CAF EWG position sensor shortcut
I connected the wiring connections correctly according to the instruction. (purple pin 9 and blue 16)
every time i connect the ewg connector it maintains the pressure.
I tried to use these files n20_jb4_x1_3.hex and n20-obdII-ewg-7.hex.
Firmware version:70/3//5
When i convert jb4 harness to oem the car runs normally and no fault occurs
I look forward to your help on the matter.
Default 08-06-2021, 10:53 AM
Send pictures of your install in to our support@burgertuning.com team. They can assist you and replace the harness if needed.
Car: BMW E89 Z4 N20
Default 10-13-2021, 01:46 AM
I still can't start the jb4. We have checked the connections at least 100 times. We can't run ewg when the unit is changed. Turbo does not work even on map 0. I have been waiting for an e-mail from Ando for 6 days, please help.
Default 10-13-2021, 08:24 AM
There is no EWG support for the the Z4 models.... If you added a connector leave it unused.
Car: BMW E89 Z4 N20
Default 10-13-2021, 09:33 AM
if that was so, what have we been striving for for how many months? You asked why I was redirected from the mail, if I made the right connection. Why are you selling this device then what's the point?
Default 10-14-2021, 08:04 AM
You said above you added in the JB4 EWG connector yourself. Just unplug it from the wastegate and set it aside as Z4 N20 firmware does not support it.
