Default F Chassis N63 JB4 - 06-27-2016, 01:12 PM
This thread is to discuss and share results on the N63 JB4 BETA
Note this thread applies to the n63 engine only and DOES NOT apply to the n63tu which uses twin DMEs.
Dyno results:
Just got back from some dyno tuning with our 2011 550. The car is unmodified other than the new development JB4 system. Testing was done on 5 gallons of E85 with the rest 91 octane. Around an E30 mixture. These are the preliminary results from today. Power was right about as expected. With a little stronger E85 mix, colder weather, and a little more boost I expect 520whp will be possible on factory turbos! This takes the n63 platform to "untuned" M5 levels. Not bad considering.
n63 JB4 MAP GUIDE:
Map 0: JB4 disabled
Map 1: 4psi over stock additive
Map 2: 6psi over stock additive
Map 3: 3psi over stock additive
Map 6: User defined boost additive map. Enter boost over stock values to use. Requires experienced tuner.
Map 8: WMI Progressive
All other maps are not defined
Firmware Updates:
JB4_N63_OBDII_3_T2:
1) Moved bank2 boost from "timing avg" to "boost2" in interface and logs.
2) Added scaling adjustment to compensate for bank to bank boost variances under "6cyl timing". Setting to 0 disables. Setting to 50 is no compensation. Lower than 50 will raise boost in bank2 relative to bank1, while higher than 50 will lower boost in bank2 relative to bank1.
Current dash settings as of OBDII v1 firmware for non-X5 models:
'OBDII In Dash Menu
'0 map menu, map shown on tach (TACH shows Map)
'1 Unused
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 50% or more and turns itself off when you resume low throttle use. (OFF tach = 0, ON tach = 1000)
'3 Unused
'4 Delete fault codes.
'5 1st gear boost limiter. (Tach = boost cap / 3)
'6 2nd gear boost limiter. (Tach = boost cap / 3)
'7 3rd gear boost limiter. (Tach = boost cap / 3)
Basic overview of the wheel controls:
Copyright Notice:
JB4 Software is Copyright 2006-2016 by Burger Motorsports Incorporated. All rights are reserved. De-compilation, disassembly, reverse-engineering, alteration, and redistribution in any form without the prior written consent of Burger Motorsports Inc. is prohibited.
Default 06-27-2016, 01:27 PM
Here is a comparison to our previous best using the Stage2 system.
Default 06-27-2016, 01:52 PM
We've changed around the N63 JB4 so add on fuel wires and add on BCM are no longer offered, supported. The only connections that should be installed are TMAP connections and OBDII for CANbus for non-X5 models or CANwires in ECU box via posi-taps for X5 models. If your system is equipped with extra wires just tuck them out of the way they are no longer supported.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 06-27-2016, 01:58 PM
Awesome stuff
conquistador conquistador is offline
Car: 2012 335is
Default 06-27-2016, 03:20 PM
Sleeper
335ilurker's Avatar
335ilurker 335ilurker is offline
Car: X5 50i Beast
Default 06-27-2016, 03:44 PM
Wow, as a Stage 2 owner, I'm completely psyched.
If we're using a max of regular 93 octane, the BCM module would be unnecessary then?
Thanks Terry.
Currently:
2015 GTi w/PP, JB4
2020 Mazda CX9 Grand Touring
Gone but not forgotten:
2012 X5 50i MSport, JB Stage 2
2009 335i JB4
2006 330i
Default 06-27-2016, 05:17 PM
Yes the BCM and even the fuel wires don't need to be installed for just 93 octane.
BCK2BLN BCK2BLN is offline
Car: 550i
Default 06-27-2016, 06:48 PM
timeframe of when this will be available?
I know this will be a FAQ, if we purchased stage 2 used, will we still be able to fall under the stage 1 upgrade category? or have to pay full purchase price?
Default 06-27-2016, 07:40 PM
Should be able to ship some early units this week.
For non-original purchasers you can still upgrade, you just get to pay the $350, like a Stage1->JB4 upgrade.
Car: 550i
Default 06-27-2016, 07:58 PM
Nice!! Can't wait to purchase, will go nice with my AA cattless DP, Badblack N63 CAIntake, custom straight/h-pipe exhaust, and replacing my current BMS N63 Stage 2
Too bad I'm in Southern California though, so i'll have to figure out how to get it shipped to me from another state.
SirApoc SirApoc is offline
Car: 2011 550xi
Default 06-27-2016, 08:07 PM
So I just picked up a 550xi which has the Dinan intake and exhaust setup, and just found out today that it also has the Dinan stage 4 tune. Would I benefit at all from the JB4, and if so, should I be getting this flashed back to stock? The Dinan stage 4, with these mods claims 507/580 crank hp/torque. What do you think I'd see compared to the JB4 on 92 (Oregon) pump? Would love to run a JB, as we previously come from the 335 world.
And before the naysayers come in, I didn't purchase the Dinan stuff, so I let someone else pay the Dinan tax .
HR F10 HR F10 is offline
Car: 2011 550i M-Sport
Default 06-28-2016, 11:59 PM
I have a stage 1.
Is this new stage 2 different from the old stage 2?
If so, does it run safer than the old stage 2? (coil or maf going bad)
Is it worth it to upgrade to this new stage 2 if we plan on running 93 most of the time?
550i M Sport - Alpine White - Vossen CV4 Graphite / H&R Sport springs / Active Autowerke Down pipes & Exhaust / BMS Stage 1
335ALIV 335ALIV is offline
Senior Lurker
Car: E90 335i Black/Black
Default 06-29-2016, 01:55 PM
I'm really glad i waited to pull the trigger on the S2 module. Terry, two questions:
Any reason this won't work on an X5 (N63)?
Also, if one plans to be on 91 oct most of the time, does the S3+BCM help at all?
2020 G01 X3 M40i
2013 E70 X5 xdrive50i - Sold after engine replacement
2007 E90 335i - SOLD
Default 06-29-2016, 01:59 PM
For 91 octane zero need for BCM. Probably no need on 93 octane either. That's mainly for E85 and race gas mixtures.
On the X5 N63 support we don't have one here for development. I suspect it will work normally as is or with some minor firmware changes.
335ilurker's Avatar
Car: X5 50i Beast
Default 06-30-2016, 09:55 AM
So on 93, you would expect current Stg 2 power levels (i.e. from my Stg 2 box) but with the convenience of CANBUS features.
Or is there a little bit more power in there without the fuel wires or BCM?
Currently:
2015 GTi w/PP, JB4
2009 335i JB4
2006 330i
Default 06-30-2016, 09:59 AM
Just don't know yet. It's early days...
cb224 cb224 is offline
Default 07-03-2016, 05:28 PM
This is awesome news!! Will there be a CANflap option with this?
Morebs4me Morebs4me is offline
Car: 2013 550i m-sport
Default 07-03-2016, 06:28 PM
It includes maps changable from the bc button, but anyone able to give me a rundown of the indash settings? My cable comes this week along with bluetooth. I tried setting the left arrow and right arrow to both 1 and under wot felt a lot of bucking. So now i must wait for someone more experienced to help out. Or if your in south florida, and want to help me figure it out, along with borrow your cable for a few, id pay.
Default 07-04-2016, 05:00 PM
Behind on making an installation guide for the setup. Even though it's pretty straight forward. For those going at it take some photos and post them to this thread. Will help me save some time when making the full guide.
We don't have the flapper commands currently for the N63 models but the structure is in place if we're able to find them.
agunner23 agunner23 is offline
Car: 08 535i
Default 07-05-2016, 02:02 PM
So in dash map changing in the beta?
Default 07-05-2016, 02:45 PM
Yes in n63 dash menu works the same as s63tu. Will update that in first post shortly.
Default 07-05-2016, 02:59 PM
Thanks for all the help Terry. Is map 4 the same as having it set to map 0 or is there any gains vs no jb4 with map 4? Im still not going wot until i can datalog but im going up to 4k rpms normal spirited driving to play with it.
Default 07-06-2016, 10:35 AM
Yes, map4 is stock tuning, but with CANbus enabled for logging.
MattPro MattPro is offline
Car: 13 F10 550iX
Default 07-06-2016, 04:12 PM
Was not expecting a free upgrade, this is even better news. Any links on the new BCM yet?
