(#376)
JeFizz JeFizz is offline
Car: 2018 Alfa Romeo Giulia Ti Sport Q4
Default 11-10-2021, 01:21 PM
Hybrid turbos sound very interesting for the platform!
On the post IC temp I still need to get a car in here to keep working on that. Worst case I can setup the JB4 to read it off the sensor directly if we can't find CANbus signals for it. Any volunteers who want to lend me your car for a day? Happy to pay for a rental.
Wish I could help out, but I'm in MN. lol
Default 11-29-2021, 12:09 PM
Changed IAT to reflect charge air temperature (post intercooler), hopefully. Load up and log V7_T4 to test it out.
Default 11-29-2021, 12:42 PM
nice. I'll check it out.
BBSBB BBSBB is offline
Car: Giulia 2.0 RWD
Default 12-04-2021, 02:07 PM
Loaded 7_T5 and made few runs at +1C ambient temp. I also tried logging via Multi ECU Scan via OBD splitter (with JB4 Windows app/USB plug not connected to JB4) yet MES seems to freak out under WOT when logs get jagged. MES IAT temps were in range 37-41, JB4 logs when converted to Celcius : 27-35
MES: Dropbox - 2 MES.csv - Simplify your life
JB4: Dropbox - 211204_0222 ERR.csv - Simplify your life
JB4 (with unit conversions): Dropbox - 211204_0222 ERR.xlsx
Car: Giulia 2.0 RWD
Default Logging - 12-06-2021, 05:49 AM
Hey @Terry, I've recently installed JB4 and did quite of lot of road tests with lots of logs. A few discrepancies with MES caught my eye when comparing MAP0 JB4 logs. Hope it may help you make few fixes.
I have firmware version 29/7//5 (the most recent BETA that I downloaded on December 3).
Here're the issues I've found:
1. Boost and DME_BT seem to be reported incorrectly, from JB4 log it looks like boost target is consistently not met, yet it doesn't seem to be the case. See screenshot Name:  JB4.jpg
2. MPH reported seems to be lower than the actual speed - when comparing Dragy runs (e.g. 60-130MPH) while Dragy reported time in logs I didn't see MPH go above 130
Here's the log file from the screenshot: 1 - map 0.csv
Unfortunately I was not able to record MES logs with JB4 plugged, though I have a logs from a different day (+8C ambient, JB4 log was made at +1C ambient). Here's the XLS file with MES log: MES, +8C.xlsx.zip
In the XLS file if you scroll right you'll see side by side boost, boost target and MPH values for similar RPM which are reported by MES and JB4, MES absolute pressure in mbar converted to PSIG, as well as KPH to MPH (as well as adjusted to RPM point in JB4 log).
Here're some notes/remarks:
1. In MES the car constantly hits the target boost. Judging by the values in MES I suspect that JB4 is underreporting Boost and might be overreporting boost target.
2. MES and JB4 logs were made on different days and might it be the case that car is malfunctioning and on the day of testing it actually didin't hit the targets? That same day the case has shown better results than without JB4. Yet I don't have MES logs from the exact same day I believe the car is fine which is confirmed by better performance.
3. I don have ECU remap, my Giulia is not stock, same ECU remap was logged by MES and JB4
4. Pay attention to the 5th and 6th row in comparison table, JB4 reports same 98MPH while RPM went up from 5446 to 5628
5. MES has 0,8 second refresh period, the values in the single rows are not a freeze frame, i.e. it reads values one by one and within one row the might be a discrepancy
On a separate not, JB4 seem to round ignition timing to 0.5, making the rounding finer (e.g. to 0.1) could be a great feature.
I've got tons of logs from MES and now from JB4, happy to assist and provide more info. You can PM me if that is more convenient.
bhvrdr bhvrdr is offline
Default 12-15-2021, 09:11 AM
1. Boost and DME_BT seem to be reported incorrectly, from JB4 log it looks like boost target is consistently not met, yet it doesn't seem to be the case. See screenshot Attachment 104815
Here's the log file from the screenshot: Attachment 104816
Unfortunately I was not able to record MES logs with JB4 plugged, though I have a logs from a different day (+8C ambient, JB4 log was made at +1C ambient). Here's the XLS file with MES log: Attachment 104817
I went out and did controlled condition testing. 5th gear run within 5 minutes of each other and controlled for starting IAT so boost doesnt get impacted by that.
Here are the results:
5th gear pull with stratified IAT on same day / same session
Default 12-15-2021, 09:26 AM
On the boost reading we scaled it to a mechanical gauge. Since it's an absolute pressure sensor the reading will vary depending on what ambient pressure the logging tool is using. Next time I have a car handy though I'll take a look.
sehinger sehinger is offline
Car: Alfa Romeo Stelvio Ti Sport 2018 2.0
Default Newbie - here are some logs - 12-19-2021, 12:07 PM
Current setup -
2018 Stelvio Ti Sport
GFB Diverter
3" Ragazzon Catback
Sprinter Air filter
It felt strong and I haven't had any CEL's since installing JB4.
Here are some logs after 2 runs today on Map 2. Looking for feedback and areas of improvement.
Default 12-19-2021, 04:57 PM
Originally Posted by sehinger
Current setup -
GFB Diverter
3" Ragazzon Catback
Sprinter Air filter
Looks good!
Next time try 5th gear from 2k rpm to redline in manual mode.
Car: Giulia 2.0 RWD
Default 01-07-2022, 12:26 AM
@Terry, is there a capability to limit boost at higher gears rather then at lower gears as it is possible now?
Giulia 2.0 has lower boost targets at gears 1 through 4, at 5th boost target is maximal and it is typically when CEL occurs. Limmiting boost at gears 5 and above would help with that issue and allow utilizing maximum boost in the widest speed range.
I do understand in the UI of JB4 app (Windows) there's no such field (one can input boost limits for 1st, 2nd and 3rd) though if there's smth to change in a settings file in HEX and run some CMD line tool - I'd be willing to try.
Default 01-07-2022, 09:58 AM
Sure we can work up something for that. Post up some logs of what you're referring to.
Car: Giulia 2.0 RWD
Default 01-08-2022, 03:31 AM
Here's the log:
As you can see, 3rd, 4th, 5th and 6th gears have boost levels going up:
1 211229_0302 100-200.csv.zip
P.S.: Since December I've flashed 3 firmware beta versions into JB4, though it doesn't seem that CSV log file has firmware version changed.
Default 01-10-2022, 09:51 AM
It's not gear that is increasing boost, it's following IAT, since the targeting is load based not boost based. Note when IAT drops at the end boost follows.
Car: Giulia 2.0 RWD
Default 01-10-2022, 10:08 AM
Makes sense.. Thanks!
Default 01-12-2022, 07:00 AM
Ongoing Hybrid Turbo validation with jb4. Bottom line its going awesome. Avoiding all the issues the tuners have been facing with limiters and wastegate maps trying to tune the hybrid.
Alfa Romeo Giulia 2.0l with 400hp Hybrid Turbo - boost and intake temperatures -- 29psi!!! - YouTube
Default 01-12-2022, 09:07 AM
Looks like it's coming along nicely!
Normally you'd want to scale off a mechanical pressure gauge, since electrical gauges are subject to variances such as the zero position and voltage scaling...
Car: Giulia 2.0 RWD
Default 01-23-2022, 02:38 AM
@Terry, thinking of adding BMS WMI to my JB4 on 2.0 Giulia. A few questions:
1. Are there any installs on 2.0 Giulia you know off and can share detail (insights into installing, feedback)?
2. How is the mounting supposed to look like? Where to pot nozzle, what kind of adapter to use etc?
3. Giulia has intercoller mounted on the intake manifold, which means that if nozzle is onstalled before throttle body somewhere on the charge pipe, the nozzle will be spraying in hot area before the IC. On the internet forums people say there's no sense to put WMI nozzle before the IC, yet on 2.0 Gilua there's no other way to install (it doesn't seem there's any room to try and do port injection and have 4 nozzles on the mainfold).
4. JB4 to BMW WMI connection, I beleive it is just 2 control wires going from JB4 brick to WMI (plus 2 power wires coming to WMI pump). Is that right?
5. JB4 setup, using Windows app and Meth tab should be enough to have all configured?
6. Can Map6 be used with WMI?
7. How do I try and test WMI (see whether pump and nozle work OK, connections do not leak) not having everyhting connected and set-up on the car?
08fordgt 08fordgt is offline
Car: 18 Alfa Romeo Giulia Ti Sport
Default 01-24-2022, 10:28 AM
Hello,
First time posting. I'm Keith. I’ve read through the entire thread. It seems that you guys keep Terry very busy lol. It’s great to see awesome customer service. I just ordered my JB4 and look forward to the gains. I've only had my car, 18 Giulia Ti Sport Q4, for almost 2 months and I've already done EC V2 intake, turbosmart DV, and supersprint sport exhaust. I can't wait to do some acceleration times even though I have the heavy sunroof option.
