(#1051)
santiagoafull santiagoafull is offline
Car: Audi s3
Default 09-05-2021, 12:09 PM
It will run fine with those mods in map 3. It has a bit less torque than map 2 but more peak power from 5000rpm and higher.
Ok thank you George!! my DSG DQ250 6 speed: could the clutches slip? does not have tune.
Then there would be no risk of excess or heat or breakage in IS38 with map 3, right? any recommendations for map 6?
THANKS A LOT!!!!!!!!!!!!!
Default 09-05-2021, 12:20 PM
No concerns for the DSG and clutch slip at all.
Its fine with stock ********.
2021 VW Golf 8 R
Car: Audi s3
Default 09-05-2021, 01:10 PM
thanks for your quick responses and for now very happy with the JB4!!
the last one: with DP + MP should I have more hp?or is it just that it gets to RPM earlier? sound is better with DP + MP
viperfan7 viperfan7 is offline
Car: 2017 Golf GTI
Default 09-10-2021, 04:12 PM
Originally Posted by Anton335
What’s the point of tunning TCU and running JB4? The whole point of JB4 is retaining warranty. Go with ECU tune if flashing TCU, or get BMS pedal tuner to help out with throttle response. Plays well with JB4!
Just out of curiosity, bit how does the pedal tuner help with throttle response?
Default 09-10-2021, 04:30 PM
The factory programs a delay from when you have pedal input to when the ECU reacts. The pedal tuner alters this delay making the engine more responsive to pedal input.
2021 VW Golf 8 R
Car: 2017 Golf GTI
Default 09-15-2021, 01:53 AM
Ah ok, I thought it just intercepted the signal from the pedal to change around the pedal curve
Default 09-15-2021, 06:18 AM
In practice this is what it does. It ramps up voltage pushing altering the throttle position table on the ECU side.
2021 VW Golf 8 R
speedfreek speedfreek is offline
Car: Audi A4
Default BMS Pedal Tuner - 09-18-2021, 04:23 AM
Looking for BMS Pedal Tuner for b9a4 did not see them for sale on your website. I already have your Jb4 installed.
Default 09-18-2021, 09:41 AM
The B9 A4 has a digital pedal sender and we dont have a Pedal tuner compatible to it unfortunately.
2021 VW Golf 8 R
Car: Audi s3
Default 09-30-2021, 02:48 PM
Hi george, after some not very strong accelerations, these faults appeared, which I read with the VAGCOM:
15015 - Turbocharger Bypass Valve Control Circuit
P0033 00 [032] - Malfunction / Open Circuit
26279 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [032] - Implausible Signal
Could it have been when I connected the JB4 wiring harness?
Thanks in advance! is greatest JB4, very happy
Default 10-01-2021, 10:27 AM
Hi, the fault relates to the diverter valve which we do not attach to so most likely the cause o the problem. See what it does in map 0.
2021 VW Golf 8 R
Car: Audi s3
Default 10-01-2021, 10:30 PM
Ok Ok so I try map 0 and read with vagcom if it comes back?
It is rare that the diverter has been damaged in just a couple of accelerations, really? Is it weird that the diverter has been damaged in just a couple of accelerations? it would not be normal. The JB4 cheats the diverter?
Car: Audi s3
Default 10-02-2021, 07:19 PM
Cleared with VAGCOM and not return errors. In some days re-check
Default 10-03-2021, 03:48 PM
Its a electrical malfunction so its not the actual DV that has failed but the wiring to it by the looks of things or possibly a contact issue at the plug.
2021 VW Golf 8 R
Car: Audi s3
Default 10-04-2021, 07:58 AM
Ok George,
Thank you for always being there giving support, I am making you very good publicity of JB4 in Argentina. After-sales is where everyone fails. This communication channel is important when deciding which brand to buy.
Greetings
Raks9201 Raks9201 is offline
Car: 2019 VW Polo AW GTI
Default 2017+ S3 8v2 Intermittent Starter Issue - 10-12-2021, 06:17 AM
Hi George
I installed the jb4 in my Audi s3, I noticed after the install my car won't start sometimes with the first turn. Note I don't have the keyless option and have to physically turn the ignition. I noticed this happens intermittently and seems to only has happened on maps 3/4/6 & 8. It will just hang like there is no petrol, not the same noise you hear when the battery is flat. I switched into Map 0 this morning and I am waiting to see if it happens again.
Have you ever come across this fault before? If yes why and what is the solution?
Warm Regards,
Default 10-12-2021, 06:23 AM
Originally Posted by Raks9201
Hi George
Warm Regards,
It might happen if the fuel open loop is set to high. Check if its 45 which is what is recommended for the facelift S3.
2021 VW Golf 8 R
Default 10-12-2021, 06:28 AM
Hi George
Thanks for the prompt response, I set it on 55 as recommended somewhere in this forum. I will change it to 45 now. However, if I am running map 3/4/8 does this still use the fuel loop I set on Map 6?
Default 10-12-2021, 06:56 AM
Hi George
Only the map 6 boost chart is for map 6. The rest of the settings are global and work in all the maps.
2021 VW Golf 8 R
Default 10-12-2021, 07:02 AM
Thanks, George, this all makes sense now. Thank you so much
Car: Audi s3
Default 10-12-2021, 02:30 PM
George, do you have a custom map to Audi S3 8v, with DP, inlet, turbo muffler delete, KyN panel, spark plug cold RS3 (now gap .24 correct?)
I read this a few more pages back:
1500 14
2000 16
2500 17
3000 17
3500 17
4000 17
4500 17
5000 16
5500 15
6000 15
6500 15
7000 15
It´s correct?
thanks in advance
1maudiz 1maudiz is offline
Car: 2015 A3 2.0
Default MAP 5 - 10-12-2021, 08:16 PM
HEY JUST WONDERING ON MORE INFO WITH MAp 5 NEXT TO THE OTHER MAPS IVE BEEN RUNNING IT WITH FULL BOLT ONS AND E30 mix 2015 A3 2.0 HAD NO PROBLEMS BUT JUST WANNA KNOW REALLY… THIS IS THE MOST HP MAP RIGHT ?
Car: Audi s3
Default 10-13-2021, 06:33 PM
George, is it possible to use MAP8 of JB4 as a way to consume less gasoline? for example in heavy or stuck traffic?
Default 10-14-2021, 05:18 PM
Typically it wont make a difference. If you getting on boost you want more torque so map 1 will give best consumption as it needs less pedal input.
2021 VW Golf 8 R
Yes, from all the ready maps this is the strongest. Peak boost is 25 tapering to 20psi.
2021 VW Golf 8 R
