Cptnslo Cptnslo is offline
Car: 2020 Toyota Supra
Default 2020 Supra Map 2 log to look at please - 11-20-2021, 03:55 PM
Can someone take a look at this. Only mods are a ******** (down pipe) and the jb4. I don’t initially put the map 3 on but got a bit of hesitation under first heavy throttle pull so I uploaded to map 2 and took this log at the drag strip. Car pulled fine but those boost numbers look way to high and I’d like it checked before I even consider going back to map 3. This is also on 93 octane.
Thank you!
Cannon @ BMS Cannon @ BMS is online now
Car: Evo VIII
Default 11-22-2021, 01:25 PM
Very odd settings. Please go back to default settings as seen on the link below and record another log. Lots of timing corrections.
https://www.n54tech.com/forums/showthread.php?t=31429
Default 11-22-2021, 01:53 PM
in regard to setting it to the default settings I saw mention using map 4 but the images show map 6 with those manual corrections. I just want to make sure I am using the correct ones.
Car: Evo VIII
Default 11-22-2021, 03:21 PM
Everything still applies on all maps, just not boost levels.
Default 11-22-2021, 03:23 PM
ive made the adjustments and I will get a log after work and upload it. Thank you!
Default 11-22-2021, 04:24 PM
Here is the updated log. This was in 5th gear
Car: Evo VIII
Default 11-22-2021, 05:03 PM
Log was not taken properly. Please provide a WOT log from 2k rpm to redline on a private race track. Thanks
Default 11-22-2021, 05:29 PM
Hopefully this works better Iím battling traction issues in that gear but hopefully this is better.
Default 11-24-2021, 07:30 PM
Bump
Default 11-26-2021, 01:31 PM
Please take a proper log...start in 3rd gear at 2K rpms and GO WOT...you are not going WOT and you are running map 6 with boost targets at 0. I'd suggest logging on map 4.
Default 11-26-2021, 01:45 PM
Steve, I was told to run default settings per an earlier post and according to the link the default settings are what I have attached which is the zero boost targets and specifically lists map 6.
VipinLJ VipinLJ is offline
Default 11-26-2021, 03:24 PM
Yes. Your settings are correct. But map 6 boost values are 0. The other settings affect all maps (not just map 6). When you change the map 6 boost values, that only affects map 6 (whereas duty and fuel bias and other values affect all values including map 6). So you set all the values to default (like in your picture) and then choose map 4 (or whichever map they ask you to log on). Don't choose map 6 since you haven't set boost (boost is 0 as per default values).
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
Default 11-29-2021, 02:25 PM
Nailed it!
StlSpeedn StlSpeedn is offline
Car: 2020 Supra
Default 12-15-2021, 06:21 AM
Hello - Total Newb on this platform and just installed jb4 yesterday on my 2020 supra.
Question: Is it ok to run map 1 fully stock on 91 pump? Can I post my log here for someone to look at?
Car: Evo VIII
Default 12-15-2021, 11:30 AM
Yes!
