(#1076)
1maudiz 1maudiz is offline
Car: 2015 A3 2.0
Smile UPDATE - 10-15-2021, 08:23 PM
Switched from map 5 to map 2 and now I’m probably going to need a motor ����
Ran great missfired and died took plugs out saw the tip to one was broke off changed plugs and now my whole top end is knocking badly 49k miles on the car
Trying to find a stock down pipe and send it to Audi to hopefully get warranty work done … PRAY FOR ME GUYS THIS SUCKS!!!!
santiagoafull santiagoafull is offline
Car: Audi s3
Default 10-16-2021, 08:11 AM
Originally Posted by 1maudiz
Switched from map 5 to map 2 and now Iím probably going to need a motor ����
Trying to find a stock down pipe and send it to Audi to hopefully get warranty work done Ö PRAY FOR ME GUYS THIS SUCKS!!!!
Car? S3? year?
Default 10-16-2021, 08:29 AM
Some misfire codes require them to be cleared a few times. You can try disconnect the battery for a while.
If you taking it in dont clear the codes.'
Where the plugs stock? We have never seen tips come off on stock plugs. They can burn the tip away after long use but dont fail.
2021 VW Golf 8 R
Car: 2015 A3 2.0
Cool Update - 10-17-2021, 01:02 PM
Car is a 2015 A3 With the 2.0 and yeah stock plugs Iíve personally never seen a tip come off a plug too! Cleared the codes no more codes for the missfire,
I can upload a YouTube vid if you want to see the sound itís making
it itís kinda crazy for only 49k
Question for you guys when I take this car to Audi for warranty work should I keep the new plugs I put in and keep quiet that a plug failed?
Say ďcar was missing so I tryed new plugs and noticed that it was making a sound tooĒ? (Having the girlfriend take the car in)
My biggest struggle right now is finding a used stock DP
Right now the car had a ******* down pipe and I would think that Audi would flag the work and not cover the issue if they see the ***************
Default 10-17-2021, 01:29 PM
Note sure about the plugs. DP would be a issue.
2021 VW Golf 8 R
Car: 2015 A3 2.0
Icon1 Thanks - 10-18-2021, 10:40 AM
Yeah thatís what I figured thanks hopefully I can get this fixed soon till then
Hally83 Hally83 is offline
Car: 2021 Mk4 Skoda Octavia RS 245HP
Default 11-24-2021, 02:34 PM
Hi George, do you support the new 2021 Mk4 Skoda Octavia RS Australian spec? It’s got the EA888.3 with IS20 not the garret turbo. I’m picking it up tomorrow.
Default 11-24-2021, 03:37 PM
Originally Posted by Hally83
Hi George, do you support the new 2021 Mk4 Skoda Octavia RS Australian spec? Itís got the EA888.3 with IS20 not the garret turbo. Iím picking it up tomorrow.
The Group 2 unit will work on it. Will be best to email some logs to me once its up and running.
We missing a few OBD parameters on it that will will add on a future firmware update that will be specific to those motors. We have done a few MK8 GTI's already that have the same new/old motors in them. It seems South Africa also got the same spec with the IS20 and I managed to get one in and test on it.
2021 VW Golf 8 R
Car: Audi s3
Default 11-25-2021, 08:20 AM
Excellent George!
What would be the updated list of cars that support the JB4 gen3 "B"? Thanks in advance!
Default 11-25-2021, 12:23 PM
Originally Posted by santiagoafull
Excellent George!
We might confuse things by calling it a 3B as that is already a different motor that is fitted in the 140kw models.
We going to sell the Group 2 for the Australian and South African market as is from the site and then down the line create a market specific firmware for them so all the OBD channels will work. They seem to be the same as the MK8 R Euro spec so once we have solved those it will be easy to test as I am in South Africa and have access to the cars.
2021 VW Golf 8 R
RPHD26 RPHD26 is offline
Car: VW Golf GTI PP MK7
Default 12-01-2021, 09:32 AM
Hi, So I have a mk7 Golf GTI PP in the UK and have got an induction kit + Scorpion non res catback. Currently just been using map 2 with 99RON. Would a custom map 6 see better gains / drivability with these mods?
Default 12-05-2021, 03:52 AM
Yes, on 99 we can run more boost than map 2.
2021 VW Golf 8 R
Raks9201 Raks9201 is offline
Car: 2019 VW Polo AW GTI
Default 2018 8v2 S3 Fuel pump not priming (Intermittent issue) - 12-13-2021, 12:59 AM
Originally Posted by Raks9201
Hi George
I installed the jb4 in my Audi s3, I noticed after the install my car won't start sometimes with the first turn. Note I don't have the keyless option and have to physically turn the ignition. I noticed this happens intermittently and seems to only has happened on maps 3/4/6 & 8. It will just hang like there is no petrol, not the same noise you hear when the battery is flat. I switched into Map 0 this morning and I am waiting to see if it happens again.
Have you ever come across this fault before? If yes why and what is the solution?
Warm Regards,
Hi George
I think I prematurely agreed that this problem was rectified. After changing the fuel loop to 45 I still got the starter issues after a while. I then ran the car on Map 0 for around 2 months and the problem disappeared completely. After changing it to map 1 on the weekend everything thing ran fine initially until the same issue started again. It seems to start fine in the morning however after a short drive and stop, on the restart, it had a hanging starter like there is no fuel. Once I turned off and tried again it started again. Please assist me, I hate not having my jb4 on.
Warm Regards,
Car: Audi s3
Default 12-13-2021, 01:43 PM
George,
I just sold my S3. I bought a 2018 Audi A3 40TFSI (2.0T 190CV). Is it compatible with the JB4 GEN3 B that I was using in my S3 8V? this car has DQ381. The stickr on the box says: JB4-MQB-2.0-AWD and check box "other" says "B".
Thanks in advance George
Default 12-14-2021, 05:41 PM
George,
You can run it in map 1. Dont connect plug C on the side of the intake manifold or the AFR connection.
2021 VW Golf 8 R
Car: Audi s3
Default 12-14-2021, 06:14 PM
Sorry: I did not understand what I should NOT connect:
1) Plug C (intake manifold)
2) AFR wire.
Correct?
Dq381 I can't use map 3?
Thanks George !!!!
Default 12-15-2021, 04:54 AM
2) AFR wire.
Correct?
Thanks George !!!!
Map 1 on Gen3 firmware is the same as map 3 on Gen3B firmware so that is the recommended map.
Map 4 has too much boost for this motor.
2021 VW Golf 8 R
Car: Audi s3
Default 12-15-2021, 07:01 AM
Ok George.
To install: plug C not install? Sorry dont understand this
Default 12-15-2021, 07:22 AM
Ok George.
No, that is not used at all and leave stock one in place.
2021 VW Golf 8 R
danbfree danbfree is online now
Car: 2017 Golf TSi 1.8L
Default 12-17-2021, 06:32 AM
Hey George, Map 3 is fine with good fuel without the AFR wire on the 1.8, right? After buying from a Golf R owner I'm getting perfect trims, stock AFR's and no timing corrections. I'm hooking up the AFR wire later as he had the full AFR passthrough plug for MK 7.5 and my T fit connectors arrive later today, but these 2 pulls (trimmed to one chart) look good right? Not sure how to post links here, had to cripple it to post.
datazap . me /u/danbfree/map3?log=0&data=1-3-4-6-11-14-15-18-25-26-27-28
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
danbfree
