Car: bmw e90 335i
JB4 and BEF problems 30FE and 3100 Codes -
04-22-2018, 12:19 PM
Hi i got the jb4 and fuel pump BEF and i'm having problems. Every time I step on it I got 30FE code for Boost Over Traget, 3100 Low Boost Mode Engaged which lowers my boost to a limit of 5 psi and 29F4 for ******* ********* detected. Last one doesn't worries me cause I really got ******* *********. This slows my car really BIG TIME!
This is driving me crazy, even if I step on it on the highway for passing a car it comes up. Need help on this.
Does anyone know a solution for this?
04-22-2018, 02:16 PM
Your going to have to post your logs and do you have all your settings correct that they list for jb4 with a bef
04-22-2018, 02:26 PM
Would need JB4 log for any tuning advice.
Car: bmw e90 335i
04-22-2018, 02:30 PM
Using map 5 on jb4, no changes made. And BEF Fuel pump, running 30% e85. no settings touched or change.
04-22-2018, 02:37 PM
Well thats probably your problem. If you loaded a bef and didnt update the settings, they are wrong.
04-22-2018, 02:38 PM
BEF requires 4/2 in dash.
Car: bmw e90 335i
Logs -
04-22-2018, 02:49 PM
Car: bmw e90 335i
04-22-2018, 02:50 PM
I got 4 2 in dash since the first day I loaded the BEF
04-22-2018, 03:10 PM
Logs are too short to evaluate it. Longer runs.
What turbos? Lower menu12 to 2000rpm.
Car: bmw e90 335i
04-22-2018, 03:17 PM
i'm out of town till next weekend. My car sits on a garage the full week. I only use it on weekends. Next weekend I'm going to do some longer logs and post them here.
These are factory turbos, VRSF upgraded *** less down *****, VRSF Front Mount intercooler, VRSF charg epipe with blow off valve.
Car: bmw e90 335i
04-28-2018, 09:42 AM
OK, here are some logs as of today. It did it only once in a few runs around town. Hopefully I get it in one of these logs.
Car: bmw e90 335i
04-28-2018, 09:43 AM
Last one
Car: bmw e90 335i
04-28-2018, 09:44 AM
Last one of today logs
04-28-2018, 10:12 AM
Logs are too short for me to see much. If you want to capture partial throttle stuff you need to manually start recording.
But did lower menu12 help? If so then you can lower it further to evaluate.
Car: bmw e90 335i
04-28-2018, 10:49 AM
OK, i'm completely new to JB4 I had COBB before, still got it just not using it. Giving a try with you guys and see if I can get more HP out of my car. So I don't know where is menu 12. I need some directions to go there and lower it. Can I access from the app or has to be on the steering? Most of the time this problem happens when I gradually step on the accelerator, Revs and boost gradually going up and then it lights up the half engine light and lower the boost. As soon as I clear the code from the JB4 app, boost goes up again with no problems.
Car: 07 E90 335i
04-28-2018, 11:35 AM
http://www.n54tech.com/forums/showthread.php?t=10605 Post# 3Has info you are looking for. Scroll down to the video it shows you how to access it with your steering wheel.
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: bmw e90 335i
04-28-2018, 02:32 PM
thanks
Thread Tools |
Display Modes |
