qwiktim's Avatar
qwiktim qwiktim is offline
Car: 2007 335i
Default Over boost then half engine light, anybody have ideas? - 01-12-2017, 08:45 AM
2007 335i with JB4
Map 0, all good , target is 8 or so and it's exactly there....no problem
Map 1, says it should be a 13.5lb map but hits 17 and half engine light and back down to stock boost.
Map 2, should be a 14.5 target but logs show it calling for 17, and it hit 21.7 this morning, half engine lights.
The only codes that come up AR over boost and cut engine power.
Stock turbos and waste gates
Charge pipe with Tial bov, did this mod after the over boosting
JB4 5
Dci
New plugs and injectors
Never had any issues until the JB4, with blue tooth adapter so I could log.
Here is a map from this morning, map 2
https://postimg.org/image/qfcra3ikp/
JayJ JayJ is offline
Car: 135i N54
Default 01-12-2017, 09:33 AM
You will need to post the csv file of your log. Maybe also post a screen shot of your user adjustments. Is there a flash on? What setting / value is in dash menu 4 set to?
Once you have posted the above info, I'm sure the knowledgeable ones will revert back with some assistance.
Default 01-12-2017, 10:27 AM
JB4 CSV log required for tuning advice.
qwiktim's Avatar
Car: 2007 335i
Default 01-12-2017, 11:09 AM
I have full csv files on the 21.7lb on map 2 and a cvs file on 4 that ran great at about 8.5 psi and no lights
........ I need to email them because I can't shrink them down enough for the whole files to be clear. Where can I send them
Also you're kinda losing me asking is there a flash on and what values map 4 are set to, the serring s reen is pretty much all black wit no number or valuse unless you click on one...please juse be a ltitle more descriptive so i know what youwant and eh where it is......I just got the jb4 G5 and with no intructions...... are there certain specific items on the setting pages you need that I can screenshot? Sorry, I'm trying to learn this.
wjjkoevoets's Avatar
wjjkoevoets wjjkoevoets is offline
Car: BMW M235i
Default 01-12-2017, 11:30 AM
Relax, we all have to start somewhere
You shouldn't have to edit the files (actually, don't touch them at all and upload them as-is so Terry and others can check properly). You can attach them here using the forum's attachment manager.
The focus will be on WOT parts of your logs anyways. the rest is usually ignored as it's not really relevant. I can't imagine your logs being over 1MB in size.
BMW ///M235i (EBII) - JB4 - BM3 - One sneaky Wagner high flow boi - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Proud ex-owner of an:
MG TF 135 - 80th Anniversary Edition (Starlight Silver) - Stock
qwiktim's Avatar
Car: 2007 335i
Default 01-12-2017, 11:33 AM
Sorry, I bought this car 6 months ago and had zero problems until this mod.....frustrated and apologize
Car: BMW M235i
Default 01-12-2017, 11:40 AM
No problem.
The logs will allow us to see parameters which usually give insight as to what the problem might be, hence the heavy focus on them. Let us know if you experience problems uploading the logs to the forum.
qwiktim's Avatar
Car: 2007 335i
Default 01-12-2017, 11:56 AM
See if these worked...and I fought this unit used so I don't know if anyone messed with it.....
Car: BMW M235i
Default 01-12-2017, 12:25 PM
The format of the uploaded logs look good. Before I start, I would like to suggest waiting for Terry to chime in. I have an F-series car, which differs quite a bit from the E-series.
I think the problem is obvious:
The difference between FF and PWM is HUGE. PWM will try to stay close to FF. Higher PWM (oversimplified) means more boost and since PWM is trying to stay close to a FF that is set WAY too high, you get overboost. Ideally, the FF and PWM lines should be identical.
My advice?
1. Wait for Terry or someone else to confirm this or correct me
2. Lower your FF parameter (I'd start with 60, others might give better ideas)
The JB4 automatically adjusts the FF parameter, but if it came from a car where FF being over 100 was required for proper boost and you're placing it in a car that can do with something like 60, you're going to have a bad time :P
EDIT: As a reference, here's my FF/PWM curve which is almost as it should be (FF is too low at high RPM due to poor duty bias settings, but you get the idea):
qwiktim's Avatar
Car: 2007 335i
Default 01-12-2017, 12:40 PM
While we wait, what is FG and PMW and where are they adjusted from.... I see nothing like that in setting.....
Car: BMW M235i
Default 01-12-2017, 12:43 PM
In my JB4 app it's called "FF/Wastegate Adaption".
EDIT: To clarify, you can't actually directly edit the PWM value. You sort of control PWM with your FF value, because PWM will try to stay close to the FF curve.
qwiktim's Avatar
Car: 2007 335i
Default 01-12-2017, 02:23 PM
Gotcha........if I have to adjust.....where do I do that, because on my settings pages there is nothing like that.
Car: BMW M235i
Default 01-12-2017, 02:27 PM
Sorry, could you perhaps post a screenshot of your settings page?
qwiktim's Avatar
Car: 2007 335i
Default 01-12-2017, 02:46 PM
They may not be in order but it took 4 screens shots to get it all in
https://postimg.org/image/6xgbc1pg1/22fba22c/
https://postimg.org/image/miq0clzxt/dbf385a8/
https://postimg.org/image/9tro9yv21/d415ebff/
https://postimg.org/image/wj2wwysxj/12e65c42/
Car: BMW M235i
Default 01-12-2017, 02:56 PM
Sorry, should have been more clear. You can find the FF option in the "User Adjustment" section. Your phone will have to be connected to the JB4 to save the settings.
qwiktim's Avatar
Car: 2007 335i
Default 01-12-2017, 03:02 PM
Found it!!! So it looks pretty high at 114
https://postimg.org/image/lzihmlonz/6e0fa86c/
2007 n54 335i
Car: BMW M235i
Default 01-12-2017, 03:17 PM
Yeah, this doesn't necessarily indicate a problem, the current value is just not suited for your car.
You need to lower this value (ex.: 60) to get your FF curve down.
With the current value being high, your PWM line is WAY below the FF line in the graph, because the JB4 knows it's pushing way too much boost. But PWM is not allowed by design to deviate too far from your FF line in order to keep boost down. So we need to drag the FF line down to less ungodly values so PWM can stay as close as possible to FF. Enough to meet boost targets and not too high to overboost.
Setting it to 60 may even result in underboost (i.e. your PWM line will constantly be higher than your FF line --> refer to my graph at high RPMs, PWM is higher than FF = underboost), but you can the tinker with FF to find the optimal value. Alternatively, if it's underboosting due to too low FF, you can do multiple runs and wait for the JB4 to "learn" the FF to its optimal level
qwiktim's Avatar
Car: 2007 335i
Default 01-12-2017, 03:25 PM
Thank you so much, I'll change that value and make a map 2 pull and log it.
One more question.......9 out of 10 or more when I start the car thwn hit connect on the jb4 on my phone, hit connect, it goes through the whole connecting and handshake deal but no displays show up.......it will read codes, but gives me no gauges or logging ability.........problem 2
...... sorry but greatly appreciate the help
2007 n54 335i
Car: BMW M235i
Default 01-12-2017, 03:30 PM
One more question.......9 out of 10 or more when I start the jb4 on my phone, hit connect, it goes through the whole connecting and handshake deal but no displays show up.......it will read codes, but gives me no gauges or logging ability.........problem 2
No problem, again, I understand your frustration. You bought something thinking it would make the car go faster, not have it throw malfunction error messages at you and make the car go into limp mode
I am sorry, I'm afraid that is something I can't answer as I've never had the problem myself. That's something the folks from BMS will have to answer for you. Maybe you could verify if you have the latest JB4 firmware on your JB4 and update it via Bluetooth if it's an older version. May fix some other "invisible issues" as well in the process.
When you do get it working in the meantime: looking forward to your new logs!
qwiktim's Avatar
Car: 2007 335i
Default 01-13-2017, 07:27 AM
https://postimg.org/image/dvd6dknrz/75a44af1/
Screens shot of where it is all set as of now
2007 n54 335i
qwiktim's Avatar
Car: 2007 335i
Default 01-13-2017, 07:46 AM
I have 4 csv files from this morning tithe surging boost, above and below target....
2007 n54 335i
qwiktim's Avatar
Car: 2007 335i
Default 01-13-2017, 07:48 AM
I have 4 csv files from this morning with surging boost, above and below target....
2007 n54 335i
Car: BMW M235i
Default 01-13-2017, 07:56 AM
EDIT2: Ignore what I previously posted, let's try again
So the logs look better, but 2nd gear is not a very good gear to test. If possible, try doing a 4th gear log from 2000 - redline (slowly push the pedal to 100% so you're not strangling your turbos at low rpm). I've also found 5th gear better for tweaking, but I understand this is not always possible
Try setting PID Gain to 10 (limits the amount of deviation allowed between the FF and PWM curves).
qwiktim's Avatar
Car: 2007 335i
Default 01-13-2017, 07:59 AM
Thanks, tell me if the logs come up..... I've been trying to get the posted for about and keep getting errors
2007 n54 335i
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 01-13-2017, 08:02 AM
FYI, here is a link to Terry's lesson on adjusting the relationship between FF and duty bias for the sake of boost control:
http://www.n54tech.com/forums/showthread.php?t=29893
2011 E92 N55 xDrive 6MT
