wjjkoevoets's Avatar
wjjkoevoets wjjkoevoets is offline
Car: BMW M235i
Default 01-13-2017, 08:19 AM
Originally Posted by qwiktim
Thanks, tell me if the logs come up..... I've been trying to get the posted for about and keep getting errors
The last 4 ones with the 2nd/3rd gear runs did
You may also want to have a look at the link fryj00 posted which does indeed do a good job of explaining the FF/PWM relationship and why it's important that these two are closely matched.
For other parameters refer here:
http://www.n54tech.com/forums/showthread.php?t=21269
BMW ///M235i (EBII) - JB4 - BM3 - One sneaky Wagner high flow boi - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Proud ex-owner of an:
MG TF 135 - 80th Anniversary Edition (Starlight Silver) - Stock
Default 01-13-2017, 07:33 PM
Try lowering your PID gain to 20 and doing a couple more logs.
qwiktim's Avatar
qwiktim qwiktim is offline
Default 01-14-2017, 12:23 PM
Set PID to 20, surging better but still over boosting considerablely, as well as dipping low.....so the car surges but not as bad now. Here is my settings page
https://postimg.org/image/rgffmk8if/916a47e6/
Logs will be below.
2007 n54 335i
qwiktim's Avatar
Default 01-14-2017, 12:28 PM
My half engine light cam on at the end of every pull, but after 30 seconds of slowing down and driving it goes out by itself. I used to have to restart the car to reset that half engine light.
2007 n54 335i
Default 01-16-2017, 10:49 AM
Do good 3rd gear logs from 2K to redline at WOT without downshifting to assist in the learning process and lower FF to 50.
qwiktim's Avatar
Default 01-18-2017, 07:09 AM
Below are two long pulls........still surging and overboosting, doesn't seem as bad, and the half engine light came on on one of the pulls......
2007 n54 335i
Default 01-18-2017, 10:43 AM
Still not doing proper logs....no further comment until you do proper logs as described above.
qwiktim's Avatar
Default 01-18-2017, 12:22 PM
Then please tell me what a proper log is. You only want 3rd gear?
2007 n54 335i
smallba's Avatar
smallba smallba is offline
Car: BMW 328i xDrive
Default 01-18-2017, 12:42 PM
Yes, He stated wants a 3rd gear pull from 2000 rpm to WOT. From your logs your shifting from 1st through 4th.
qwiktim's Avatar
Default 01-18-2017, 12:47 PM
I though give it everything as far as the road was would give you more info than you could use sorry. If I'm cruising 2-3000 rpm in 3rd gear and floor it I can't keep it from kicking back to second gear........ how would you suggest a get a 3rd gear on pull?
2007 n54 335i
qwiktim's Avatar
Default 01-18-2017, 05:24 PM
So if I understand you, you want a full 3rd gear pull, which in my step tropic car is impossible ....... I have to be at 4000 rpm or it will kick back to second gear. Here is much of a third gear pull that is possible with my car.
2007 n54 335i
luv135i luv135i is offline
Default 01-18-2017, 07:40 PM
How does every other step car do it on this forum? You cant start at 2500 and floor it just slightly above the kick down button? Or if you cant stop yourself from hitting the kickdown, get the kickdown blocker I guess
Car: BMW M235i
Default 01-19-2017, 05:19 AM
I assume your car has a manual mode. Put it in manual so you can start in 3rd gear and keep it there. I would also do a 4th gear pull if possible.
qwiktim's Avatar
Default 01-19-2017, 09:13 AM
I tried everything I could do to get what you wanted but in my car is impossible. Not matter what gear I am in while in manual mode I can control when it upshifts, but cannot control it from kicking down when you roll into the throttle .......it kicks down no matter. This is the only logging on long I got this morning
2007 n54 335i
Default 01-19-2017, 11:05 AM
You need to control your right foot or get one of these. http://www.burgertuning.com/downshift_blocker_BMW.html
qwiktim's Avatar
Default 01-20-2017, 06:14 AM
so youre saying the compuper sees the pedal at 100% even when it's not quite there?
ill mm order one today if that's the case.
2007 n54 335i
qwiktim's Avatar
Default 01-20-2017, 11:48 AM
Meanwhile, I made a spacer out of small pvc using feeler gages to measure clearance between the pedal and the bracket making the spacer exactly that thickness before the kickdown switch clicked. In M/S mode no matter what gear you are in it will not kick down but still shows 100% throttle...nice tip.
Since it is raining here I did get a few 2000rpm to redline 2nd I gear pulls.......see if they help........I'll do other gears when it dries up
2007 n54 335i
qwiktim's Avatar
Default 01-21-2017, 10:11 AM
Unfortunately, best I could do....... there is no area within 60 miles from here to over over 130....... ain't happening unless I drive an hour. Anyways I tried to get 4th gear pulls and they all kick to low power codes at........it's 4th gear limit is 4000 rpm .....setting off high boost codes and throwing the half engine light on, seeing no purpose for that I let off........pleeeeeeeeease tell me I've given you enough to go on.....my resourse here in Ohio are quickly covering with snow and only getting worse. This car has to be really for the fort import race. Please tell me you see something
2007 n54 335i
Default 01-21-2017, 10:26 AM
If not equipped with a BEF menu4 must be set to 3. That is a big problem in this log.
It's easy to spot because the throttle is closed, ECU PSI matches actual boost, etc. Seems like an epidemic of these lately. Why are you guys setting menu 4/2 for non back end flash applications? lol
qwiktim's Avatar
Default 01-21-2017, 10:45 AM
Please lengthen me....... how do I tell I'd has a back and flash or not, how to I tell if I'm in the map you meant?
2007 n54 335i
qwiktim's Avatar
Default 01-21-2017, 10:55 AM
Or at this point, can someone send me their log that shows what what's what's , dci, jb4 v5, and basic basic bolt ons on desigened maps for this applications and let that be a starting point?
2007 n54 335i
Default 01-21-2017, 10:56 AM
Change menu4 in dash to setting 3.
qwiktim's Avatar
Default 01-21-2017, 07:08 PM
I have never set mine to map 4, it does it on its own
2007 n54 335i
JayJ JayJ is offline
Car: 135i N54
Default 01-22-2017, 01:08 AM
That's not what Terry means.
Go into your steering wheel controls / JB4 menu. Make sure the speedo dial is on 4 and the rev dial is on 3.
I'm assuming you haven't used the steering wheel controls before? If not make sure to watch a YouTube video how to do it correctly.
qwiktim's Avatar
Default 01-22-2017, 04:53 AM
I use the steering wheels all the time. I will try that this morning
2007 n54 335i
