luv135i luv135i is offline
Default Backend flashes and targets - 05-01-2015, 02:00 PM
With all the flashes we now select 4/2 which targets 17 psi on map 2. How can all three flashes safely try to target the same 17 psi? Especially the pump map. Maybe i am not fully comprehending.
Duperstar Duperstar is offline
Car: 2009 535i xdrive
Default 05-01-2015, 03:41 PM
Main difference is that each flash runs different timing with pump being the lowest (lower than stock) then race, then e85. Also changes to the fuel scalar for different fuels.
2009 535xi - JB4 G5 ISO -BMS Race Flash- BMS Intake - ER CP- Forge DVs- Active Autowerke intercooler- Gone
Activehybrid 3 - JB4 EWG/OBD- CTS Turbo Intake- VRSF CP- Bavsound Stage 1- current
