Car: E92 335i
04-13-2015, 10:19 PM
So I haven't updated my interface on the jb4 in a while. Currently running 27/3. Am I sol on doing the last estate update
Car: 335i E92 2009
04-15-2015, 04:54 PM
I think we've shipped with the above Dwp and open loop for the last year or two but open loop will adjust itself up if needed.
The open loop 80 value will adjust itself yep, but the wastgate value of 80 always fixed as 80, the new default value is 60 should we keep it 80 or follow the new value of 60?
Maybe a silly and newbie question  but I appreciate to know what's would be the difference in performance between 80 or 70 or 60 on the wastgate other than the rattle? Which is the best value to performance if no rattle on the turbos?
04-15-2015, 04:55 PM
I prefer 60 as its a bit smoother than 80 and just as responsive for me. Some people like 100 for maximum response. Some need 15 to avoid rattle. It's menu 10 in dash so use/adjust to whatever works best for you.
Car: E90 335xi
04-16-2015, 10:52 AM
Uploaded SIO 28.82 using the new firmware 4/6/15.
I did reset all values (CPS, Meth, Max Boost 3rd, ...) using the screenshot on page 1 (see below).
The only value I did not reset is the Default Wastegaste Position (DWP), which is set to 80 since I've installed JB4 2 years ago. Looks like the new default value is 60. Not sure I should change from 80 to 60.
Thank you Terry.
2008 Jet Black 335xi E90 6AT | Alpina B3 TCU Flash | BMS Backend 7/1 Pump Flash | JB4 G5 ISO 31.5 | BMS DCI | BMS CP | VRSF 5" FMIC | BMW Performance Exhaust | VMR V718 / Kumho | Best 1/4 mile: 12.37@110.4 MPH | Top speed: 0-270 km/h | YouTube
04-16-2015, 01:00 PM
@v1nc86 reference Terry's post #3127 above
Car: 2010 335i
04-16-2015, 01:09 PM
Terry after doing the firmware update I love it. I am noticing a little more pshhh noise or pressure release noise when I shift around 2500rpm into a higher gear (6MT). I've never heard this sound before.....
335i LMB E92 6MT MSport Logic7
Car: E90 335xi
04-16-2015, 01:52 PM
Yes, I had already read Terry's post #3127. That's a good and easy explanation. I will give it a try (change DWP from 80 to 60).
Thanks.
Car: 2007 BMW 335i
04-16-2015, 03:00 PM
The latest version of the interface keeps giving an error message when trying to install on Windows XP. It's related to .NET framework 4.0 - is the latest version no longer compatible with Windows XP?
My XP is fully up-to-date with Windows/Microsoft update...
Car: 355i
04-16-2015, 05:56 PM
I tried downloading the firware and I'm getting a msg that it's corrupt. Is there another link?
Car: '10 335xi
04-16-2015, 06:25 PM
I just updated about 15-20 minutes ago, everything worked fine.
Car: 2010 335 Xi
04-18-2015, 09:16 AM
Terry, why did you stop adding a "last updated" date to the first post? You had done it for a little while, but quit. That really helps for those of us that aren't on the site every day.
-Greg
2010 335xi 6AT | Black Sapphire Metallic | Black Dakota Leather | Alpina B3 Flash | BB Open Flash | JB4 | BMS DCI | Tons more to come...
Live in Central Ohio? Looking to have some coding done? Shoot me a PM.
04-19-2015, 05:47 PM
Car: '07 335i
04-19-2015, 08:52 PM
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Car: 2008 Sapphire black 135i
04-19-2015, 11:40 PM
More updates I see...
Any differences for someone running map 5 on pump gas? (FBO car)
Currently running firmware 28_5b
'08 135i 6-Speed... BMS Pump Flash, BMS JB4 G5, BMS 3" ***, BMS OCC, RB PCV, VRSF 5" Stepped FMIC, aFe DCI, Racewerks Charge Pipe w/ TiAL Q BOV, Modified Berk Exhaust
Car: 08 bmw 335i
04-21-2015, 04:24 PM
Just upgraded to the iso board and have a couple of questions. Do I still need to cut the diode or are the newer boards already just plug and play? I also noticed that my service engine soon light came on after the install. I'm assuming it's for *******DP but i'll have to check on a laptop tonight. Any ideas?
2008 e93
-MHD e60 custom map, VRSF DP, VRSF CP, tial bov, wally 255, Drilled/slotted rotors, Hawk pads, VRSF FMIC, M3 control arms, VIS CF hood, ECS CF lip
04-21-2015, 04:27 PM
They are plug and play. On the codes read the fault in dash or via laptop.
Car: 2007 E92 335i AT (05/07 Build Date)
04-21-2015, 04:30 PM
Terry I just reset my adaptations with the jb4 and now the car is surging like a mad man at idle. I tried the foot pedal reset method and it didn't work. Would really love to get this fixed tonight as I don't want a rental car for work tomorrow.
04-21-2015, 04:36 PM
That happens sometimes when you reset the throttle adaption. Turn on ign, engine off, and keep clearing codes/resetting adaptions, until it works.
04-21-2015, 04:40 PM
I have INPA setup on my laptop, is there a better way? Also I'm a bit concerned that tomorrow I'll have a N54 for sale.
Car: e92 335xi
04-21-2015, 05:08 PM
This was off another forum, was having similar issues and this cleared them up:
after adaptation reset:
30sec key off
30sec key on/engine off
30sec key off
start car.
04-21-2015, 06:05 PM
It's been about an hour and a half since I did it through the jb4, a guy on a different forum had the same problem so he did this.
1. Never touch the brake pedal & leave the key inserted the entire time
2. Insert key and push START Button
3. Press and HOLD accelerator pedal for 30 seconds.
4. WITHOUT RELEASING THE ACCELERATOR PEDAL, push the START Button (remember without touching the brake, so the car doesn't really start yet.)
5. Release accelerator pedal
6. Wait 30 seconds
7. Start car normally
Worked for me. I guess I'm going to try resetting adaptations through inpa. I don't know I love doing things that I know I can't afford.
Car: '10 x6 35i
04-21-2015, 10:15 PM
I updated the firmware to the latest 28_8 on my X6 2 days ago, thankfully it seems to fix a previous problem of 30ff code in map 4 that used to pop up randomly .
What I need to know is if there is a difference in setting the duty bias 0 or 50?
04-22-2015, 04:05 AM
0 and 50 are the same
JB4G5 ISO/BMS E85 Flash, vrsf dp's, vrsf 7" fmic, vrsf cp with tial, 255 walbro inline,e60,alpina trans flash
04-22-2015, 07:43 AM
Hmm she ran pretty hard today, or maybe it's just the good weather.
Car: '10 x6 35i
04-22-2015, 09:23 AM
just in a few words, how is 0 and 50 the same??
thanks
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
