CapitaineBeaver's Avatar
CapitaineBeaver CapitaineBeaver is offline
Car: BMW 230i xDrive
Default B46 Ewg and Fuel connector question and install ??? - 09-16-2018, 04:03 PM
Hello everyone,
I want to order the EWG harness connector for my 230i xDrive with B46 (B48) engine.
First question is there a visual guide for the EWG connector harness installation ? Also just to confirm I would need to order the : “JB4 F-Series EWG addon connector BMW B48/B58” ?
Also do I need to order the : “JB4 Fuel Pressure connector B48/B58 small style” ? E85 is not readily available in my area so unless it’s required by the EWG connector I don’t think I would require it.
Thank you for all your help !
'18 230i xDrive // Black Met // Coral Red // M-Sport // 719M Black // BM3 // BMS Intake // BMS OCC // Dinan Axleback // Roof Rack // 365 days of fun
Default 09-17-2018, 05:26 AM
The EWG connector will connect to the actuator on the turbo itself. That's the correct one in your description. No need for fuel wires, that's fine.
Default 09-17-2018, 05:39 AM
Thank you Payam, will place my order soon !
Do I need to get a Special firmware to go with the EWG connector (since the N55 gets a special firmware).
Default 09-17-2018, 06:03 AM
And regarding the install, I was more talking on the connector side of things and not on the EWF itsef (since it easily reachable on the B48 engine).
Default 09-17-2018, 06:21 AM
It's pretty easy, just open Jb4 case and remove harness from board. No special firmware needed.
Insert the pins in the locations on the Db25.
The purple wire (going to the male pin on the wastegate harness) connects to position #9 on the DB25 connector.
The blue wire (going to the female pin on the wastegate harness) connects to position #16 on the DB25 connector.
Default 09-18-2018, 04:19 AM
Thank you again Payam ! EWG connector is ordered (and ordered pedal tuner as well). Now if you could ship my package ultra fast so I can get it before the weekend that would be nice : . Thanks for your help again
Default 09-18-2018, 05:11 AM
I'll have it out today
Default 09-18-2018, 02:02 PM
Order is shipped out and should be delivered tomorrow
Can't wait to try out the pedal tuner and install this EWG connector to see if we can fine tune this baby a little more.
Default 09-22-2018, 01:58 PM
EWG Wires installed. Not too bad after all ! Will be trying map 3 and map 6 over the weekend to see if anything better will come out !
Default 09-24-2018, 06:10 AM
Awesome!
blue blue is offline
Rr
Car: 320i
Default 04-19-2019, 06:57 PM
Hi CapitaineBeaver,Can you give me some help? I can't find where the EWG and fuel lines should be plugged into the engine.
