Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default mph logging in log file - 06-15-2019, 03:53 PM
Anyone able to get value above 158 mph on the logging ? I notice in the logs that even if speed above 158 mph in the log it keeps solid at 158 mph while speed is more.
Attached samples of logs that car actually above 158 mph but the value remained 158 mph all the time as the max value reached.
Also would appreciate an 2nd opinion on the logs of you spot anything or advise anything
Those logs not 3rd gear 2k to WOT logging runs it's full pull roll runs from tonight friendly races with friends
Outside temp is not the best during this time of the year
But its was a nice win against the 600 repsol and other leo edition bike will share the kill video later in the kill section
Default 06-15-2019, 05:33 PM
255kmh is a CANbus limit for speed so it won't go over that.
