15MCSJCW 15MCSJCW is offline
Car: 2015 Mini Cooper S JCW
Default 25psi on JB+ - 05-07-2019, 06:26 AM
Hi guys and gals. This is my first post on here. I Have a 2015 MCS w/JCW tuning kit (ECU Remap, and high-flow catback), a K&N Panel filter, and a JB+. I also installed a nm boost-tap and a Prosport Premium boost gauge. I run 93 octane Sunoco gas only. Last night I installed my JB+ at a 4 o'clock setting. At some point last night my car hit a peak boost of 25psi. Should I be concerned? This seems crazy high to me, as the most I have seen without the JB+ is about 15psi. I live in Ohio at about 600ft above sea level. Any information would be greatly appreciated. Also, does anyone think with these mods that I should go with a step colder of a plug?
Default 05-07-2019, 08:15 AM
It depends on the RPM you're hitting, but without a full data log it's difficult to know. You can always turn the dial back if it doesn't pull smoothly.
Default 05-07-2019, 08:23 AM
It pulled just fine. My concern is catastrophic engine failure.
Default 05-08-2019, 08:46 AM
You've want to evaluate it with logging tools, checking timing, and air/fuel determine whether it's safe. Since you're flashed you have a unique situation so I'd suggest starting mild with the JB+ setting.
